Question about Frigidaire Washing Machines
Don't know how to match up the old part wiring
To who ever can HELP !! This is a electric junction block on a Chevy 4wd 1990 -95 with a 5.7 !! I would like to know where they go , color code's ect ect !! New harness , Old one burnt ! I "Don't want
If the new harness is an oem match then you can just go to autozone or where ever, and get a haynes manual. It has the wiring diagrams with color codes in the last section. Good luck.
Feb 04, 2013 | Cars & Trucks
Very bad am radio reception, how do i fix?
If it's interference from the high tension wires,you probably need new spark plug wires with good resistor type plugs.
Now,also a bad antenna or a poor match of frequency to the antenna from the rec eiver can cause weak reception.Anyone who knows electronics can match the antenna to the receiver. don-ohio
Sep 14, 2011 | 2005 Dodge Magnum
Not sure how to replce spark plug wires from the distributor need help please send info
change one spark wire at a time on the distributor.buy new set of spark plugs wires remove them from box.match old wires with new wires to use the correct length to each cylinder.now if you need to change distributor cap.mark location distributor cap.number tag plug wires on the distributor cap so you can remove plug wires on distributor cap so you can replace cap and rotor and put wires back on the distributor cap in correct place.remember change one plug wire at a time so you wont get confuse.
Apr 15, 2011 | 1992 Ford Tempo
I have an old Bryant heat pump. I got a Hunter 44860 2 stage heat/2 stage cool but I am having problems with the wires. These is the Bryant set up (the wire colors do not match)...
This should help you. You need to know if your thermostat is powered by the unit or independently and which way your reversing valve switches (I,m not sure on a Bryant, but probably Your old O wire goes to your new O terminal. They should pretty much match up, the new stat just has more options. Thermostat wiring
Jun 09, 2017 | Hunter Fan Company 5/1/1 Programmable...
Im installing a new stereo and need a wireing digram
You'll need to determine which of these connectors match yours, then follow the appropriate diagrams:
Nissan Audio Wiring - 1985 to 1994:
Nissan Audio Wiring - 1995 onwards:
Let me know how you get on...
Cheers,
Scott
Nov 12, 2009 | 1994 Nissan Pathfinder
Replace oxygen sensor for 4cyl 01" Accord - wires don't match
Don't put a universal oxygen sensor in your vehicle. You will have nothing but problems, and you will have to put an OEM one in it anyway.
May 30, 2009 | 1996 Jeep Grand Cherokee
Have new switch for belle 110v cement mixer
This should be pretty easy. you should have either two or four wires in the box and two or four hook ups on the switch. the wires in the box must stay aligned with the matching colors so if your switch has four connections but you only have two wires hook them up to the post opposite each other top to bottom. (they need to both be on the same side) if you have four wires but only two switch posts wire nut the two white (or blue) together and switch the black (or brown). The important thing to remember is the power needs to come in on go into the switch or breaker first.
let me know if this wasn't helpful
Mar 21, 2009 | Electrical Supplies
I have a 1988 chevy astr van and need to know how
The easiest way is to purchase an installation kit that is matched to your vehicle, and comes with a pigtail plug that inserts directly in to your existing radio connector, and the pigtail wires match up color for color to your new unit
Feb 23, 2009 | Kenwood KDC-MP238 CD Player
Stove top dual infinite switch
If the new switch is a substitute, should have come with instructions.
If no instructions, I would suggest matching the markings on the switch next to each terminal.eg, match terminal marking on old switch as L1 to marking on new switch as L1. The markings are industry standard and should match from old switch to new switch.
If you need further assistance, let me know
Regards,
reg501
Jun 24, 2008 | Cooktops
Washing Machines Logo
42 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
