Question about White Sewing W3300 Computerized Sewing Machine
I have a White Embroidery machine, used but new to me. In good condition. But I have no manual with it, so I haven't been able to enjoy it as of yet. I have searched a few places but not finding one. model # W3300 serial # M33B115901 I would sure be happy if you could help me out here. The person I got it from can't find her copy. THANK YOU SO MUCH
    Novelist:
  • 233 Answers
I found one on ebay at http://cgi.ebay.com/WHITE-W3300-EMBROIDERY-SEWING-MACHINE-MANUAL-CLEAN-/350462427163?pt=LH_DefaultDomain_0&hash=item519930401b for $9.99. Hurry before it disappears or is taken off!
Posted on May 17, 2011
Testimonial: "Thank you for the direction to ebay, I have bid on it, now I will have to wait and see :-D"
  • debiyakel May 19, 2011
    I won my item on ebay!!! Thanks again :-D
I purchased a serial port that is not compatable with my sewing machine, I also purchased an updated software with Bernina to make my embroidery machine user friendly. however,I am unable to connect
Problem is that the Bernina software you are using expects to talk to a 'COM port and the PC's USB serial interface doesn't automatically default to a COM port. Make sure you have installed the software that was delivered with your USB-to-Serial adapter and look on your PC's 'Device Manager' under 'Ports' - you should see the USB adapter listed and it should be assigned to a COM Port number. You need to check what COM port numbers are accepted by the Bernina embroidery software (sorry, I cant remember and haven't got one here presently) - it should be in the Options menu. You have to ensure that the USB 'virtual COM port' is the same as that which is set in the Bernina software. If the Bernina software doesn't support the COM port allocated to the USB interface, go to 'Properties, Port settings, Advanced, COM port number and set this to the same as the COM port number in the Bernina software - hopefully this should set up the link OK, provided you haven't got a COM port clash - to avoid this, it's usually best to choose a COM port number of 2 or above.
Dec 02, 2011 | Bernina Artista 180
Where can I locate the fuse<
The Pfaff 7570 Creative Designer is a computerized sewingand embroidery machine that has the ability to connect to the computer, andhave embroidery designs sent to the embroidery machine. The sewing andembroidery machine has many features, including hundreds of general sewingfunctions, a separate embroidery module, and on-screen editing features. TheCreative Designer 7570, manufactured in the 1990s, was the first sewing andembroidery combination machine ever made by Pfaff.
1. Usingthe Sewing Machine
1 Turn on your sewing machine using the "On"button located just below the turn wheel on the right side of the machine.Thread your Pfaff 7570. Note that Pfaff sewing machines thread from left toright, not right to left like other sewing machines. The upper tension discsshould be raised at their highest position while threading, and the presserfoot should be raised up until you thread the needle. Drop the presser footright before you thread the needle. The prevents thread problems during use. 2 Insert a full bobbin and retrieve the bobbin threadthrough the thread plate. Raise your sewing foot and needle to its highestposition; hold the needle thread taught with your left hand, lower the needleinto the thread plate using your right hand, and then raise the needle. As youraise the needle, the needle thread will catch the bobbin thread, and pull itup. There should be a loop of thread intertwined with the needle thread. Usetweezers, your finger, or a straight pin to retrieve the bobbin thread that isvisible through the thread plate, and pull it through the plate. 3 Place the fabric under the presser foot, and drop thepresser foot. Choose the stitch you want to use from the top stitch display,right above the top thread feed. Press the '0-9" button located on thesewing machine's front panel, and a display screen will come up. Input thethread number, and press the 'OK' button located on the sewing machine's frontpanel. The stitch will display, and you are ready to sew. Repeat Step 3 foreach stitch you want to use.
2. SettingUp the Embroidery Unit
1 Turn the sewing machine off. Take out the embroiderymachine unit, locate the connection bushing on the back of your embroideryunit, and match it up with the connection bushing on your sewing machine. Theconnection bushing should be located next to a yellow sticker on yourembroidery unit, and somewhat resembles a serial port on a computer. Slide theembroidery unit onto the sewing machine with the sewing machine turned off. Connectto the bushing carefully as you slide the embroidery unit onto the sewingmachine. Use your embroidery unit manual if you need assistance. 2 Insert an embroidery card. Your embroidery unitshould contain an embroidery card labeled embroidery card 1. Use that or useanother Pfaff 7570 card that you own. Turn on the sewing machine. 3 Open the bobbin case area just below the threadplate, and lower the feed dogs by pushing the feed dog switch to the right.Press the card button located on the front face of your sewing machine. Adisplay with pop up; choose embroidery designs or monogram and a new screenwill pop up with your design choices. Choose the design you want, and press"OK." A checklist screen appears. Do everything on the checklist, andpress "OK." Use your embroidery unit manual if you need help. 4 Start embroidery by pressing the foot pedal. At thistime, your hoop should already be attached to the embroidery unit becauseyou've already gone through the checklist. Your embroidery manual displayscolored picture diagrams that are very helpful in understanding everything inyour checklist menu.
Thanks for using fixya
Jul 31, 2011 | PfaFF Creative 7570
Can I use a Bernina card 11253 in my Simplicity Embroidery Machine SE2
Unfortunately these cards are not interchangeable due to proprietary reading/writing software. This is used by the industry to prevent customers from changing brands once they've invested in a library of embroidery designs. However there is a company that makes it possible to transfer information from one type of card to another. I haven't used their product but it may be the solution to your problem.
http://www.secretsof.com/content/2510
May 16, 2011 | Simplicity SE3 Computerized Sewing Machine
I have singer 2259. i dont know how the machine automatically threads the needle. I also want to know can i do embroidery with this machine, if so, how?
You do not have an embroidery machine, or an automatic threader. This is a basic sewing machine, you can free style embroider by covering the feed dogs and, using an embroidery hoop plus the darning foot but you don't have an embroidery attachment per se. Read your manual, if you do not have one go to www.singerco.com and download a free copy under customer support and save it to your computer. Embroidery machines usually start at $600 and up. $600 is a very basic one. If, you want one take that machine back and buy one from a place that gives lessons on it, (check out JoAnn's and private shops). You will enjoy it more if you know what all of the features are.
Jan 03, 2011 | Singer 2259 Sewing Machine
I want to sell my 1991 New Home memory Craft 8000 sewing machine
A good place to see what machines are selling for is Ebay. That's where I sold a sewing machine and an embroidery machine.
It helps to know your product and machine embroidery lingo.
What are cassettes? Floppy disks? These make the machine borderline obsolete.
Memory cards are still around, but most EM now have USB connectivity or USB flash drives.
Satin thread? Embroidery machines use Rayon or Polyester embroidery thread.
Having had the machine recently serviced is also a plus.
Mar 19, 2010 | Janome Memory Craft 9000 Computerized...
I'm new to embroidering. I have BrotherSE-270 Disney. I have read through the manuel several times and am confused about the bobbin thread. Do I use tread specficaly for embrodering or will regular thread...
Your machine probably came with brother embroidery bobbin thread (one spool, white)...I used it until it was gone and did buy more embroidery bobbin thread at a regular superstore (it wasn't brother brand though)...however, I have since used regular thread and not had problems. HOWEVER, be sure it is good, quality thread - none of that $.50/spool stuff. That knots up and simply doesn't look good if it does work. Good luck!
Jul 08, 2009 | Brother SE-270D Computerized Sewing...
I am looking to bye white w3300 and wanted to know if it uses the ped basic
I am looking to sell (2) WHITE 3300 embroidery machines. They got me into business so that I would know if there was a market for embroidery in my area and also to learn alot about machine embroidery.
Mar 07, 2009 | White Sewing W3300 Computerized Sewing...
Instruction Manual
Have a look at this website, if your machine is not listed email them and they will help track a manual down, it's not free but what is these days.
Rob
Mar 25, 2008 | Husqvarna Rose
White Sewing W3300 Computerized Sewing Machine Logo
265 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
