Question about Toys
I need touch up paint for my crib. I tried 2 different ones in the store, a marker, a paint , and stain, and they wont stick to wood. model number 3806-sq
  • 407 Answers
The best way to match colors is to take a part of the crib to a Lowe`s,or Home Depot.They have machines that can match any color perfectly.
Posted on May 17, 2011
Can i paint my garage doors?
Clopay's steel garage doors can be painted with any high quality exterior latex paint. Wood garage doors must be painted/stained on all sides prior to installation. Most models are available factory primed. Clopay recommends wood garage doors be re-painted every 1 to 2 years (more frequent refinishing may be required in high moisture areas).
Oct 02, 2014 | Building Materials
How to stain fiberglass entry door?
You cannot use regular stain on a Fiberglass door. Stain is made to soak into wood. It cannot soak into Fiberglass. It will peel right off in several months depending on the weather. A solid stain may would work for a while, but it will not hold up as well. Whereas stain is made to soak into wood, paint is made to sit on top of surfaces. There are some nice paints that look like stained wood if that is the effect you are looking for. But if you want the new finish to last on your door, use paint. Make sure you clean the door thoroughly with a degreaser, prep solvent or paint thinner
Apr 29, 2014 | Jeld-wen Door. Ascot 3/4 Lite Oval Primed...
Where do I find high temp paint to use on a gas stove?
Auto parts stores have manifold and engine paints for high temp use, or the hardware store has barbecue and wood stove paints, usually black. Your stove may have been enameled (Melted glass powder process, like ovens, old sinks and bathtubs).
Jun 05, 2012 | Kitchen Ranges
Instructions for simmons crib model 12449185
Simmons has received more than 800 reports of bracket hooks breaking. In one case, a 6-month-old hit his chin on the side rail when the mattress dropped.
Simmons is offering a free repair kit, which includes replacement brackets and instructions. The repair can be made easily in the home.
Most of the recalled Simmons cribs were made in 1998. Those sold at Sears were made in 1998, 1999 and 2000. Only "98" cribs of all models are recalled, except for Sears cribs. For Sears cribs (which are model numbers 025260 and 065060), the years "98" "99" and "00" are recalled because the problem bracket hooks were used all three years. The brackets on all other Simmons cribs except for Sears changed to different type attachments after 1998. The cribs were sold under the name "Little Folks". Simmons and the two-digit year of manufacture are written on a label affixed to the crib's headboard. The year is the two-digit number following the model number. "Little Folks" is on another label affixed to the headboard. The cribs are constructed of maple or ash, and are painted or stained in more than a dozen different colors, including natural, golden and white. "Simmons" is written on the top rail. Simmons will help consumers identify if their crib is recalled.
Discount, mass merchandise, juvenile product and department stores, including Sears, sold the cribs nationwide from January 1998 through December 2000 for between $200 and $600.
Consumers should stop using these recalled cribs immediately and contact Simmons to receive free replacement brackets by overnight mail. Consumers can contact Simmons anytime at (800) 421-2951 or at www.simmonsjp.com/recall.cfm
Oct 23, 2011 | Simmons Mattress Matino - Natural Maple...
I painted a picnic bench with latex, and it peeled. I scraped off some of it, and much is left on. Is oil base paint over this a good solution?
Hi there. Try to remove as much of the old paint as possible. You should sand down the wood and paint a little bit to rough up the wood and only then paint over it. Paint sticks much better to roughed up wood. Oil based paint would also be a better solution. The best solution is to use stain, if that's an option. Alex
Jul 13, 2011 | Garden
I am looking at buying a Wagner Max HLVP sprayer. The jobs are staining a modest stretch of fencng and a larger staining project of an overhead pagoda-type structure. Is this a good choice or would you...
I was a painting contractor for last 10 years of my work career.
If you are using HVLC cup gun, you will have to select correct tip,
You will need to thin the latex 50-50 with water, and keep paint strained to keep out all clogging.
If the tip is not reversible, then expect disassemble each time clog happens.
And you will be continually re-filling the cup.
And then if the surface is rough, the spray won't flow into the holes.
You have a mess coming your way.
Painting a fence: A roller is the only way to paint/stain rough surface.
Buy big hairy 1" roller cover from Sherwin Williams. Don't get the cheapo 1/4" thick roller cover because it doesn't hold any paint. The big roller holds a big volume of paint.
Now if fence is rough, like cedar, you need to thin the stain.
About 1.5 gallon water per 5 of stain ... and suddenly you have 6-1/2 gallons of stain which means you bought too many gallons of stain.
So don't overbuy the stain. And pick up 2 plastic bucket for mixing.
Empty gallon of stain into mixing bucket > put water into empty gallon > put lid on gallon and shake up > pour water into mixing bucket with stain > to mix: pour mixing bucket of stain back and forth between other mixing bucket until stain is mixed. Do this work on the grass where it won't run out onto concrete surface.
Put roller and frame on a wood pole that you took off the push broom. Now roll that stain onto every surface the roller can touch. Think of it like picking up quarters. If it was money, could you get the roller on that spot >> the answer is yes. Don't try to smooth it out and make pretty. Throw the stain on any way the roller can turn. Customers used to call that 'slapping it on' and I used to say, 'that's how it works, lady.'
Use a piece of masonite at the bottom. If you get stain on anything, wash it off immediately and use a wire brush on concrete surface or towel on smooth surface.
Wait for a day, because stain looks 100% better next day. And then go back with a brush and hit the spots you couldn't get with the roller. It will be faster and cheaper and fewer headaches than trying to spray latex stain with a HVLP cup gun.
To clean the roller: Leave it on the roller frame and wood stick. Turn on water hose and get the roller spinning until it's clean. Do this away from everything you don't want stain on.
Dec 13, 2010 | Garden
Convert our Morigeau Lepine Crib to a toddler Bed?
I called the store in pittsburgh where we bought our crib (Babyland) - since Morigeau is out of business, they said i can either get some kind of generic metal frame adapter at any hardware store, or there is a store in chicago www.lazarsfurniture.com - they told me that the store will do wooden adapters to match the colors of the original crib. I contacted the store by email and they said they "no longer have any inventory for Morigeau", but I'm going to call them to talk with a person and see what they can do.
we are sooooo kicking ourselves for not having purchased the conversion kit when we got the crib itself. oh well...
Nov 24, 2009 | Baby Gear
Paints and stains
GF Salad Bowl Finish
Create a beautiful and safe finish on wooden bowls, cups, spoons, countertops and butcher blocks or any wood surface that contacts food. Easy to apply (just wipe on with a soft clean cloth) it achieves the sheen and durability of a varnish. Dried film is non-toxic for food contact 72 hours after drying. Additional coats can be re-applied at any time if maintenance of item becomes necessary
On Line store: generalfinishes.com
I don't know about paints, but there are stains, such as raw linseed oil, that work just fine for food-safe surfaces.
suggest you do some exploring; plug in'food-safe stains "in your search engine.
Hope this helps...
Jul 23, 2009 | Delta Woodworking Delta Rockwell 14 Inch...
I bought a used simmons crib and it does not come with manual. I think the model looks like the Pali Katie Crib. Here is the model number 0177201 00 243. Do you have the manual or can you direct me where I...
www.simmonsjp.com I believe there is a recall on this crib model.. you should check it out..can contact Simmons anytime at (800) 421-2951 or at www.simmonsjp.com/recall.cfm
Most of the recalled Simmons cribs were made in 1998. Those sold at Sears were made in 1998, 1999 and 2000. Only "98" cribs of all models are recalled, except for Sears cribs. For Sears cribs (which are model numbers 025260 and 065060), the years "98" "99" and "00" are recalled because the problem bracket hooks were used all three years.The brackets on all other Simmons cribs except for Sears changed to different type attachments after 1998. The cribs were sold under the name "Little Folks". Simmons and the two-digit year of manufacture are written on a label affixed to the crib's headboard. The year is the two-digit number following the model number. "Little Folks" is on another label affixed to the headboard. The cribs are constructed of maple or ash, and are painted or stained in more than a dozen different colors, including natural, golden and white. "Simmons" is written on the top rail. Simmons will help consumers identify if their crib is recalled.
Jun 12, 2009 | Pali Katie Crib
Simmons crib
http://www.simmonskids.com/ also you may want to call this number.. i believe your crib had a recall.. can contact Simmons anytime at (800) 421-2951 or at www.simmonsjp.com/recall.cfm
May 26, 2009 | Pali Katie Crib
Toys Logo
219 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
