Samsung SMT-C7140 HD-receiver & Personal Video Recorder. Makes occasionally irritating sound. Con not be put in stand by position for quick restarts. Sometimes TV loses sound and image for some seconds. Does it need an upgrade, if yes, how to do that?
SOURCE: Direct TV/Olevia 247 audio skipping
I have the same problem with comcast HD, completly useless talking to them, they do nothing to assist
Posted on Jul 01, 2008
Agent Aaron
  • 265 Answers
SOURCE: Samsung lcd hdtv won't receive signal from fios hd receiver
Hey nothingsfree,
You may not necessarily have anything incorrectly set up, but there are a couple of things that I would suggest trying.
First, you'll want to make sure that your TV is set to the correct input source. Some TV's will require that the input source be changed in order to display any signals from an external device, like your HD-DVR. This can typically be done by accessing the main video menu using your remote control.
According to information provided by the manufacturer, you should be able to change the input source for this model TV (Samsung LN46A750) by doing the following:
* Press the "Menu" button on your remote control
* Press the "Up" or "Down" arrow button to select "Input," then press "Enter"
* Press "Enter" to edit the "Source List"
* Highlight the signal source for the HD-DVR, and press "Enter"
Next, you may want to try updating the TV's firmware. In some instances, simply updating a TV's programming can eliminate any potential hardware or software conflicts between two devices. To update the TV's firmware you will need access to a computer and a USB flash drive. Step-by-step instructions and the firmware update itself are available through the following website:
http://www.samsung.com/us/support/download/supportDown.do?group=televisions&type=televisions&subtype=lcdtv&model_nm=LN46A750R1F&language=&cate_type=all&dType=D&mType=FM&vType=L&prd_ia_cd=02010100&disp_nm=LN46A750
Make sure to read all the warnings and disclaimers available though, as your TV may already have a more up-to-date firmware version than the one that can be obtained through Samsung's support page.
Should neither of these address the issue, you may wish to see if connecting your HD-DVR to a different HDMI input solves the problem. Much like computers, TV's have been occasionally known to have faulty inputs or loose internal connections.
If all else fails, I’d suggest contacting the manufacturer for further assistance. In many cases manufacturers are able to provide over-the-phone troubleshooting support, in addition to having access to a wider variety of possible remedies for hardware problems.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Posted on Jun 23, 2008
rlamkin
  • 44 Answers
SOURCE: 46" Samsung TV loses sound.
R U using HDMI? If so that be the problem.
Posted on Jul 03, 2008
  • 210 Answers
SOURCE: I need a wiring diagram to connect a samsung tv,
all you have to remember is out of one into the other IF got Ariela on house that goes into sky then out of sky in to DVD recorder and out of that and into tv
on back of sky hd if you are going to use HDMI cable put cable into sky box and other end into tv ( you will have ot put tv on HDMI input/source)
or use scart lead in stead
THIS DEPENDS ON HOW YOU WANT TO CONNECT PLAYSTATION
everything else is colour coded
Posted on Nov 08, 2009
  • 148 Answers
SOURCE: Philips 47
Hi there, they problem is not in the input to the tv (dvd/cable etc) your powerboard/videoboard is overheating! Right away place a fan as close to the back of the tv as possible, this will help cool the circuits down and might considerably prolong the usefullness of the tv..The next step in it breaking down is total powerloss, or a blinking powerlight, eitherway this is your solution;The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol! If this helped (or not )please rate, thank you!d4195d7.jpg
Posted on Feb 04, 2010
Can I use a HD receiver as input for the Toshiba XS35? Will it record HD signals? Will it record anything if the receiver is HD? I want upgrade my exisitng Bell Canada TV receiver box to HD - can I...
Yes you can record any TV show HD or SD, however it depends on what connections you use and what the recorder does with the input signals. You can record HD shows but not in HD resolution if you connect using composite video (yellow RCA cable) you just get a down-converted resolution, probably 480. You must use a HDMI or a component video connection for HD BUT if the recorder cannot record HD video, it should just record it in SD resolution but it should record the input signal. DVD is not HD, you would have to go to Blu-ray for HD and there are not many Blu-ray recorders around. The hard drive has the potential to record in HD but the recorder would have to process HD signals and you would have to connect with HDMI or component video. I would say your Toshiba will record an HD show but in SD resolution. I don't think the recorder has an HDMI input or a component video input. Just composite and S-video inputs. To actually record in HD you should look at another recorder.
Mar 19, 2011 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
How do I connect to Sharp HDTV and Comcast cable
Your dvd recorder only has rca, red white yellow inputs it wont allow you to record in HD, although you can play your comcast box any hd, regular digital through and record. Hook up the comcast box if HD through preferably HDMI if not get one from comcast. The HD box is the only box that allow HDMI, component and regular RCA and some RF out. This way you can play HD to your set but also record through RCA or RF again will not allow for HD record unless its TiVo. Hope this helps
Jan 07, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
HOW DO I INSTAL A TOSHIBA EXTERNAL DVD RECORDER TO SAMSUNG SMT-190DN..
If your are going to install the dvd recorder into your other device, follow this few steps.
  1. Place your external DVD Multi-Recorder drive in the stand. Otherwise, lay it down horizontally if you're not going to be using the stand.
  2. Turn on device.
  3. Plug one end of the USB cable into one of the dvr USB ports. Then connect the other end into the external DVD Multi-Recorder drive.
  4. Plug the power cord into the AC adapter. Then connect the cord into the drive's jack. Connect the other end into the power outlet.
Hope this helps
Nov 23, 2009 | Samsung 4 Channel Dvr
Connections for TV Cable box and DVD recorder??
are yellow video, red and white audio
Oct 20, 2009 | Televison & Video
Does the pioneer sx315 receiver work with the samsung led?
From memory, this amp does not have HDMI.
If this is the case, use an optical fibre cable for your connections.(Audio)
And if you want every thing to run through your amp you will also need to use component video cables (red/green/blue)
I would suggest the following.
Blue Ray to TV with HDMI.
HD Reciever to TV with HDMI.
TV AUDIO OUT to AMP with Optical Fibre.
This way, whatever is displayed on the tv, the sound will come throught the amp.
Hope this helps.
Sep 05, 2009 | Pioneer Audio Players & Recorders
Direct tv hdbox & Plasma TV & DVD SSound system & DVD recorder
Need to make sure you have the red,white,and yellow rca connection cables ran from the samsung dvd player to the red,white,yellow input on the back of the dvd recorder. Once you do that make sure you put your dvd recorder on line 1 input. If you look closely on the back of your recorder it should say line 1 input. If your recorder isn't on that input you can put the recorder on line 1 input by using dvd recorder remote and pushing the input button. Make sure you don't push the tv input button the dvd recorder remote there should be a seperate input button or a way to toggle the inputs on the recorder. Once you verify all that turn on your tv and go to the input on your tv that you watch the dvd recorder on and you should see what your recording on the tv.
Nov 20, 2008 | RCA RTD155 System
Device code for Samsung SMT-H3050 HD Cable Box
I use an old universal onkyo remote. 0035 Is a Panasonic code but worked the smt-h3050
Hope this helps
May 26, 2008 | Bose Cinemate Digital Home Theater System...
Samsung HP-S4253 black screen, with sound
Its the broadcasting company and there "new technology" Have had an over the air box to get local HD channels and lost my PBS station, turned out to be a new signal incompatibility. The same is with my HP-S4253. Must not have the latest SW to process the new signals
Feb 19, 2008 | Samsung HP-S4253 Television
No audio from Samsung DTB-H260F
I have a sr605 Onkyo receiver and just hooked it up to a new Mitsubishi 73" and I could not get the picture to work, sound did though. Here is the problem the Onkyo is HDMI 1.3 but TV calls for HDMI 1.3a. There is a big difference between the 2 and the Onkyo will not work with TV. The newer model TV'S say in the manual Category 2 V 1.3a. You need to make sure that all your parts are compatable. It makes a big difference.
Dec 05, 2007 | Mitsubishi HD-6000 DTV Receiver / Video...
Televison & Video Logo
229 people viewed this question
Top Televison & Video Experts
Electro Med Services...
