Question about Kenmore 42822 Front Load Washer
My Kenmore HE3 front load washer has code F 11 it's stuck there since yesterday, and the door wont open. How can I unlock the door. All my work clothes are in there, and I am afraid they will get rouined. I called Sears but they can't come out right away to help with the issue. Please help me!!!
  • 407 Answers
Here is what Kenmore says.
F/11 Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
My Kenmore HE3 front load - globul1a.gif Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU) globul1a.gif Check the Drive system for any worn or failed components globul1a.gif Check MCU My Kenmore HE3 front load - globul1a.gif globul1a.gifCheck CCU Check Motor globul1a.gif Check Wire Harness
Posted on May 17, 2011
Lights keep flashing and door locks without finishing cycle
Kenmore HE2 Plus Front Load Washer Keeps unlocking ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
Washing machines - Ariston
Jan 05, 2016 | Washing Machines
Kenmore elite he3
most front load washers and dryers have locks on the doors some have a bottom panel that u can remove to manually unlock door using the release before opening any machine please unplug machine from wall sometimes even unplugging it and waiting a few seconds will release door lock from itself
Feb 09, 2014 | Dryers
Can I get my clothes out of my Kenmore Front Load Washer with no electricity?
I dont believe you can. When its locked its locked and with no power it will not be unlocked untill power comes back on.
Jun 30, 2012 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washer door won't unlock
im sorry to tell you but you may need to get a repair man out to fix the lock from the inside of the washer its sort of stoped half way through its washing cycel
i gess the drum suport springs have poped off and thats why it went for a walkys in the first place
Oct 25, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite HE3 front load washer door locking mechanism issue
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Aug 01, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore HE3 stuck in delay cycle and won't unlock or cancel
YOu more than likely have suds in your washer, or an extremely unbalanced load. push the pause cancel button twice, that should unlock the washer. open the washer, and look inside. Is there a lot of suds, or towels that are tangled up? If so, add some fabric softener to the wash tub and do a rinse drain spin (for suds) for the extremely unbalanced load, take the towels (or what ever load you are doing) and put about 1/2 of them in. I have the same washer and have experienced this "problem" once or twice in 7 years. And those were the two culprits. Hope that helps
Jul 30, 2009 | Kenmore Elite 45986 Front Load Washer
My Kenmore front load HE3 washer door won't unlocked after I failed to turn water on while the machine ran for about 15 minutes. I tried unplugged and cancelling it. Nothing works. Please advice. Li
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 28, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Washer is stuck on spin and the door wont open. It is locked.
May 16, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore HE3 stuck in rinse cycle
my wife was doing laudry with he3 and when it quite the door would not open.tried to restart a new cycle and it would not start.I unplugged the washer and let sit for 2 min.replugged it in and it started to work.I hope this helps you.
Apr 22, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore front load He3 washer: door wont unlock
happened to me once - I just unplugged the machine - waited a minute and plugged it back - it - then used cancel button
Feb 27, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore 42822 Front Load Washer Logo
93 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
