Question about Sears Refrigerators
Freezer freezes but refrigerator doesn't cool
  • Rizerd May 18, 2011
    Can you describe the damper control? Is it a squeeze type apparatus with spring like things on it. How should it open up and how can I see if the vent is plugged?
    Do you have a picture of the damper control area.
    PLEASE SEND MY INFO TO MY EMAIL ADDRESS: rkarch@mcn.org.
    Thanks, Richard Karch
    Brigadier General:
  • 3,917 Answers
Hi
Check the back wall or floor of the freezer section for frost. Check the freezer (evaporator) fan to see if it is running. Check the condenser coils (under the unit) for blockage from dust. Check the condenser fan (under the unit) to see if it is running. If you have frost in the freezer there is a problem with the defrost system and the freezer will start to warm eventually as well as the fresh food section. If that is the problem you can check the defrost terminator, defrost heater/s, and the defrost timer or adaptive defrost control If used on your unit or the main control board if so equipped. These things usually require dismantling the freezer and other areas of the refrigerator to be checked. You could defrost the freezer by disconnecting the power to the refrigerator and letting it sit for at least 24 hours with both doors wide open to allow the frost to melt completely but it will build up again in 1-2 weeks and start the warming up again.
If the freezer is between zero-10 degrees and the fan motor is running usually indicate the airflow is not getting into the fresh food section. You might check the damper control to see if it's opening up and/or the vent clear.
If you remove the back wall inside the freezer and find that the evaporator coils have ice built-up on them, this usually indicates a defrost problem (defrost heater and thermostat or defrost timer (or adaptive defrost control on newer models).
If the evap. coils are more or less clean, then it's probably the air diffuser (also called damper control). The diffuser is located between the freezer and the refrigerator sections.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on May 17, 2011
  • e-Guru
    e-Guru May 18, 2011
    Sure.
  • KD Grayson Heating,Air conditioning & Refrigeration
    The thermostat that runs the compressor is ok to max, however
    the other setting should never be set to max as this actually makes the freezer colder! counter to what it indicates, it says colder freezer! the freezer is 100% of the refrigeration effect, so if it makes ice and the ice is dry the systems fine, its the airflow, set to medium and it will work fine.
May tag side to side fridge the fridge is too cold. the fridge has started to freeze
Hello Daniella,
Interesting problem to have.
Your FREEZER temp should ideally be set at zero... or just immediately below... and the REFRIGERATOR at 33°F or immediately above freezing.
For my own comfort... after fighting with my formerly friendly refrigerator... I purchased the TAYLOR "Classic Freezer and Refrigerator Kitchen Thermometer-REFRIG/FRZR THERMOMETER" from eBay... ... less than $6 each
After breaking one of my incredibly expensive (Taylor - recording) glass "green-house" thermometers (oh well... still cheaper than a repair... by a LONG SHOT...!!).
Your local variety store or Amazon are probably a better choices... (I'm a long time buyer on eBay... greasy old car parts).
Your refrigerator cooling is completely a by-product of your FREEZER operation... adjusted by the clever use of fans and airflow.
Sometimes a sudden change is REFRIG cooling can be attributed to a significant shift in HOW you have your packages arranged in the FREEZER... but life is typically not that easy.
Before you actually rip your refrigerator apart and start trouble shooting... IF possible... It is best to unload everything and completely defrost your unit... open , dry and powered off
Plug it all back in and start over completely anew.
If then... it is still failing...
The thermometer(s) will help you to determine which side is not cooperating with YOUR ADJUSTMENTS...
For actual trouble shooting... once you have determined if it is the freezer or the refrigerator... find the appropriate temperature sensor on your wiring diagram... that is the cheapest part to experiment with... BUY IT.
Try using the specific part number on an online search... get at least three prices... and look at SEARS Parts prices... for ABSOLUTE worst case pricing... (same part... terrible price!).
Got it?
Sears Parts... No!
Your primary logic board... will be the worst/high cost item
that could be causing your OVER-COOLING problem.
Good luck and happy hunting
Nov 08, 2015 | Refrigerators
Freezer defrosting
You may have to reset the defrost timer.
Nov 23, 2017 | Whirlpool Refrigerators
My whirlpool frost free fridge freezer's alarm keeps going off, ice-cream doesn't freeze?
Check condenser is clean, fans working, thermostat set correctly, try to check internal temp with digital thermometer
May 17, 2012 | Refrigerators
Refrigerator doesn't get colder than 55 degrees.
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Aug 19, 2011 | Kenmore Refrigerators
Water leaking out of the bottom of the freezer and water freezing in the back around the drain hole, which doesn't appear to be clogged
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 08, 2011 | Refrigerators
The freezer compartment doesn't work properly.Ice is formed on the back and food won't reach freezing point. ????
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
heatman101
Jul 06, 2011 | Refrigerators
Freezer high temp light is on. So is fast freeze. It's been plugged in at least 24 hours but not freezing.
FREEZER HIGH TEMPERATURE WARNING LIGHT DOESN'T GO OUT.HOW TO CANCEL OR RESET?FOR HOTPOINT FFA74.THANK YOU
Mar 11, 2011 | Hotpoint FFA70 Bottom Freezer Refrigerator
Refrigerator freezing lettuce. Adjustments result in freezer section too warm. I can't seem to find the correct settings. I can't locate my manual. This appliance is 25 years old or more.
a refrigerator thermometer is a good investment (usually available at grocery stores) .. i have two to make it faster to adjust things (one in freezer and one in refrigerator) ... first set the freezer with the temperature control .. set the freezer to 0 degrees F (adjust a little at a time until its close (wait several hours or a day between settings) ... then you may have another control called "air" or "refrigerator" .. you set that one for 37 deg in the refrigerator .. it usually takes a few days to get it right .. but without at least one thermometer you are flying blind, its nearly impossible to do correctly .. you can use any thermometer that is accurate down to 0 degrees, so you dont have to buy one if you already have one .. once you get it right you might want to mark the adjustments incase someone changes them ..
Nov 21, 2009 | Televison & Video
FRIGIDAIRE FREEZER MODEL # LFFU1465DW3 WON'T FREEZE
Make sure freezer door seal is completely sealed. No gaps, Also, if you are up to the challange, you will need to remove the freezer panel, test thermometer, thermostat, for voltage and resistance. Also check that the flapper that seprates freezer from fridge air.; Is not frozen.
Jun 11, 2009 | Frigidaire Freezer Refrigeration White...
Refrigerators Logo
615 people viewed this question
Top Sears Refrigerators Experts
geob91
richie46
Are you a Sears Refrigerator Expert? Answer questions, earn points and help others
