I lost the manual and my car was in the mechanic and the battery was dissconnected and i dont know the code please help
    Sergeant:
    Champion:
  • 319 Answers
If the unit was installed in your car as stock equipment, you will need to take it to the dealer service department so they can unlock the security code. Otherwise you will have to replace the unit
Posted on Aug 14, 2008
Please help me to find out Radio code for my fluence 2013. vin VF1LZLET9DC268667:
Hi dont know what brand that car is but try to find it in the manual book if not then on the truck or mostly thry put it on the spare tire look for a sticker if no luck bribg it to a dealer they unlock it for free as long as its in ur name hope this will help
Aug 27, 2014 | Renault Sportwagon Cars & Trucks
Battery disconnected so radio is needing code -do not know the code?
Take the car to a Vauxhall Dealer and they will give you the code after identifying your self
Mar 24, 2012 | Car Audio & Video
I own a 2003 Nissan Altima SE 3.5L. Recently, my car sounds like it is stuck in 2nd gear. The RPM's do not run high but the car sounds like it is racing in second gear. This is an automatic. Help?!
If your service engine soon light is on, go to autozone and have the code pulled up. Sounds like you are in limp mode (safe mode). I suspect it is your mass airflow sensor. Its easy to replace but expensive. I recommend getting one from a junk yard and installing it yourself. if you dont have any mechanical experience dont worry. As soon as you see one it will be obvious you dont need experience. It is in the middle of the big tube that connects your air filter to the throttle body. All you need is a screw driver and disconnect one electrical connector. Again, not worth buying new...they cost over $350 new but only $60 at junk yard.
If you want a quicker way to check, dissconnect the big tube from the intake manifold, in essance letting air run directly to the throttle body without going thru the air filter or mass airflow sensor. If the car runs fine with it dissconnected, its the mass airflow sensor. Buy some mass airflow sensor cleaner at an auto store (its specifically made and named mass airflow sensor cleaner). Try to clean it first...Dont touch anything inside with your finger tho.
Sorry if Im sounding like a school teacher but Im not sure of your mechanical knowledge or ability.
If not none of this works , you will have to pull up the code.
May 19, 2011 | 2003 Nissan Altima
Can I get my car radio code for free? The radio is working fine, but i need to dissconnect the battery, I will lose the radios code when doing this. There isn't a code with the cars info. It's in a 2002...
Can I get my car radio code for free? The radio is working fine, but i need to dissconnect the battery, I will lose the radios code when doing this. There isn't a code with the cars info.it is a renault clio expression 16v 53 plate help please any answers? xx
Jul 27, 2010 | Car Audio & Video
Lost code for unican 1000 i have lock of but dont
Click below to get to the manual you need. when you get there find your model number and slide across the page till you get to the PDF under the Manuals column. Click again and either save or open the file.
Hope this Helps,
RSMITH972278
P.S. PLEASE RATE ME
Sep 29, 2009 | Locks & Locksmithing
Code p1441 failed canister purge solenoid
More than Likely The Soliniod is Defective, and Replacment Will Correct the Problem, You Must Reset ECM After Part Replacment, Do this By Dissconnecting the Battery @ Negative Cable for 1 Miniute then Reconnect it, this will turn OFF the C E L <= Check Engine Light . Hoping this Helps you , and Please Dont forget to RATE Me , ALOS Feel Free to REPLY with any Concerns you have Regarding this or ANY OTHER Auto Problems you have. Have a Good Day
Aug 20, 2009 | 1997 Chevrolet Blazer
My navigation
does it say : program can not be read please conntact your dealer.
and your 3 buttons on right side of the screen dont work and also your calendar? I have a same problem because i dissconnected battery.
Jun 06, 2009 | 2006 Lexus Is 250
Jensen vm9512 -- is there a master unlock code
MY UNCLE WORKED FOR JENSEN FOR MANY YEARS AND HE HAS A SOFTWARE THAT CAN CRACK THE CODE OF ANY RADIO OF ANY BRAND USING THE SERIAL NUMBER OF IT, IF U LIKE POST YOUR SERIAL # AND MAYBE HE COULD HELP YOU OUT.
Aug 28, 2008 | Car Audio & Video
22 people viewed this question
 Grubhead
Grubhead
