Question about Compaq AlphaServer DS10
PERROR = 00a0020000000081
i am trying to boot up a DS10 Alhaserver and get the following Error:
Error detected by Pchip 0
Lost Error
PCI Read Data Parity Error
What does it mean?
Thanks
Best regards,
Harun
  • Galen Tackett May 11, 2010
    This looks like a problem with the maybe the CPU, something on the PCI bus, or maybe memory. If you are familiar with poking around in the hardware I would first try carefully blowing or vacuuming out any dust from the motherboard and re-seating your memory. This may be all it takes to fix your problem.
    If the problem is still present after re-seating the memory, we can try to determine if you have some bad memory. I'll go into that after you've tried the next step.
    Next, remove any PCI cards except maybe your video card and see if you still get the error. If the problem goes away, then we're making some progress. Get rid of any dust in the PCI card cage and reinstall any PCI cards that you removed. If the problem comes back, we'll have to eliminate the PCI cards one by one. If it doesn't come back, problem solved...
    Let me know how this goes. Good luck!
3 Suggested Answers
  • 4234 Answers
SOURCE: DS10 with SBS PCI Expansion
Version 7.1-2 is an older version of the OS. I will have to check, but I think that V7.2 will resolve this. What version of TCP/IP are you using? Back in the day when I supported TCP and VMS, there were some timing issues that causes odd behavior. If you can provide the details about your configuration, I can check and get back to you. If necessary, an examination of a forced crashdump may be needed.
A rare opportunity to work with VMS again!!
Good stuff.
Dan
Posted on Aug 01, 2008
  • 1623 Answers
SOURCE: an error code jfb0 Bus
replace or remove whatever ram chip is faulty, that error refers to a crc check on ecc memory. Or you could just turn off ecc parity checking in the bios. But that simply defeats the object of having ecc memory in the first place
Posted on Feb 24, 2011
Acer 5534 will not boot up....tried recovery disk....but nothing......error message PXE-E61-media test failure..........no bootable device
Hello:
Your Acer laptop is not detecting a bootable device, for sure your hard disk is:
1.- Malfunctioning and has lost its master boot record.
2.- It can be ruined and must be replaced.
In the first case, primary and recovery partition are bad, as you mention the recovery process failed (ctrl +F11). First, press F2 during POST, when "a enter Setup message" is prompted on the bottom of screen to check if the hard disk is listed on the Main BIOS properties. If detected, the hard disk can be recovered booting from DVD-ROM. In the BIOS setup utility, you need to select boot from de DVD-RW. Insert Windows 7 setup disk and it will check for possible boot errors, choose repair when prompted. Follow the instructions. The system will restart.
If the hard disk was not detected in BIOS properties, you should ask Acer for guarantee.
You may review this link for further information: http://www.acerlaptoprepairs.info/aspire-5534/
I hope this helps. Thanks
Jan 30, 2011 | Acer Computers & Internet
When I try to turn my computer on i have a blue screen message saying "A problem has been detected and windows has been shut down to prevent damage to your computer." I can't login or anything. I have even...
From your request, the question is very general.
Code Stop 0x0000007B, it means "inaccessible boot device": Windows is not able to read from the device it's supposed to be booting from. That device would normally be your hard drive - but if you're getting this during Windows installation, it could be something wrong with your CD or DVD drive..
The Stop 0x0000007B error message will be displayed on your screen with a lot of other information in what is know as the "Blue Screen Of Death" or "BSOD".
Different PCs have different "IDE or Sata interface default settings" depending on the OEM manufacturer specifications. Check your OEM motherboard require any BIOS updating.
If your PC is a desktop, remove all the PCI devices installed on the PCI slots.
If you can access to the CMOS BIOS, reset the settings to default, save the settings and reboot your computer.
If the your PC can access to windows, do a "chkdsk /f/r" from the "Command Prompt".
If not you have to reinstall the OS.
Jul 08, 2010 | Microsoft Windows XP Media Center Edition...
Error code 0F00:137B
GO TO BIOS SET UP VERIFY WHEATHER HARD DISK IS DETECTED OR NOT IF NOT CHANGE ID CABLE OR PLUG TO ANOTHER ID PORT ONCE GOT DETECTED TRY TO BOOT IF NOT BOOT IN SAFE MODE
Sep 07, 2009 | Dell Dimension 3100 PC Desktop
Bought graphics card upgrade yet will not detect
The board should recognise this card ,however connect card with pc off and reset your cmos jmper hold for few seconds or take battery out,replace boot up get into bios ,normally delete button,reset your time and date and save try reboot
Jan 14, 2009 | ASUS P5VD2-MX SE Motherboard
C PROGRAM
#include <stdio.h>
int main ()
FILE * pFile;
int c;
int n = 0;
pFile=fopen ("test.txt","r");
if (pFile==NULL) perror ("Error opening file");
else
do { //DO
c = fgetc (pFile);
if (c == '$') n++;
} //DO
while (c != EOF);
fclose (pFile);
printf ("File contains %d$.\n",n);
return 0;
Aug 31, 2008 | Computers & Internet
Good stuff.
Dan
Aug 01, 2008 | Compaq AlphaServer DS10
El driver de sonidop deboared msi no se deja instalar
vcs tem o drve de audio da pchip Nome da Placa Mãe PCChips P17G
May 18, 2008 | PC Chips PCChips P17G Motherboard - V1.0,...
Acer Aspire 4720 RHEL4 Installation
again install linux in between the installation there will be option select linux boot loader , and one more think linux partition space should more then windows partition
Mar 26, 2008 | Acer Aspire 5100 Notebook
Unable to Install Red Hat Linux Enterprises 4
when the time of installing only you have to take linux boot loader then it will show both operating systems otherwise i think the problem is monitor configuration in linux installing
Mar 24, 2008 | Computers & Internet
ALPHA SERVER DS10 with OPEN VMS 7.3
check the computer memory Ram and the processor
Feb 18, 2008 | Compaq AlphaServer DS10
Compaq AlphaServer DS10 Logo
161 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
