Question about Toro Lawn Mower With Toro Power Tools
TSN #7900699 Toro gts2 21 power drive model 16401 where is the oil drain plug?
  • 69 Answers
SOURCE: have a toro mower model # 16401 and the front left
You should be able to look up the mower and parts at the Toro website.
Posted on Oct 22, 2009
  • 85 Answers
SOURCE: where do I have access to drain oil from my TORO
If you've ever seen the inside of these engines, you would understand & follow the mfg. instructions.
Tipping the mower on its side, with the dipstick down, put a drain pan under the dip stick & remove the dipstick, this does a couple different things, it gets all the oil out, also it dumps the sludge off the bottom of the crankcase
Posted on Nov 08, 2009
vincob
  • 718 Answers
SOURCE: where is oil drain plug on toro 22'' mower- tecumseh engine
IF you do not see the drain plug o the side of your engine, than most likely it is located on the bottom of the engine you will most likely have to remove the guard that covers the belt if you have self propelled lawn mower and the plug should be under the guard. Good Luck
Posted on Jul 18, 2010
  • 6468 Answers
SOURCE: where is my drain plug on my toro lawnmower
there is one on the bottom of the engine i just run mine out of gas the turn it on it's side and drain it from the dip stick tube
Posted on Apr 13, 2012
hunter19_46m
  • 7482 Answers
SOURCE: my toro lawnmower model 20331 won't start. I replaced the fuel, oil, and spark plug but it still won't start. whats wrong with it?
Hi dana
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting a bright blue spark at the spark plug.
You do this by grounding the plug on the head of the engine and cranking the engine or by pulling the crank rope...watching the plug for spark.
If you are getting a nice blue spark then skip A below and go to B.
A...If you do not get a nice blue spark then you may need to replace the electronic module.
Note: If you have to replace the module be sure to measure the position it is in, it is critical to starting.
Take a picture for later reassembly.
B...Also take some fine grit sandpaper (not emery) and lightly sand the flywheel where the magnet is located to clean any rust or corrosion from the magnet area.
Then follow the procedure below:
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper and or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of sharp instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line/s condition...after a while they will degrade and need replacement.
Check/Clean/Replace your fuel filter if you have one.
When you remove your fuel lines from the carburetor be sure to make a drawing or take a picture of how the lines are connected to the carburetor.
Also a good time to take a picture for later reference for reassembly.
If the mower is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Bud
Posted on Oct 30, 2012
Have a GTS 5.5 here,and cannot find the drain plug in order to change the(OLD) oil. Had the blade and cover off,and saw no bolt or plug. Also didn't see a plug on the side. Any help appreciated.
Well If You Cant find drain plug [should be a square drive]
Then I would turn the thing upside down [empty gas tank first of course]& drain it thru the filler plug. Perhaps the drain is an inset hex bolt and you must REALLY clean the underneath, dig around for it!
Jul 14, 2014 | Toro Lawn Mower With Toro Power Tools
Toro 6.75 mower has a recessed plug impossible to remove with socket or wrench. Model 20371 but I know there are other models of Toro with this design.
if your wanting to chang oil the shops tilt it on there side and drain threw filler pipe they dont mess with the plug
Jul 30, 2013 | Toro Garden
Where is my drain plug on my toro lawnmower
Apr 12, 2012 | Toro Power Lawn Mower
How do I change the oil on my Toro Personal Pace mower? Do I need to remove some cover?
The oil drain plug should be under the deck. You probably have a bracket in the way that you need to remove. Once you remove the bracket you should be able to access the drain plug. Piece of advice do not cross thread the drain plug and do not over tighten it. You should only turn the drain plug 1/2 a wrench turn above finger tight.
Jun 15, 2011 | Toro Power Lawn Mower
Want to change oil. Is the oil drain under with a 3/8 socket drive drain plug ?
Hi lfancisco...
Yes the oil drain plug is under the mower, normally a square plug,socket drive to remove to remove the oil from the machine.
Please take time to rate me...Free answer
May 16, 2011 | Toro Power Lawn Mower
Where is the oil plug for changing oil in the Toro recylcer 700 series. I can't find it anywhere
Hi marybasrai...
Look under the mower to find a square plug/allen key plug and remove that plug will allow you to drain the oil from the mower
Free answer, Please rate me
May 07, 2011 | Toro Power Lawn Mower
To much oil.is their a drain plug for the oil.if not how do i get it out.
Most of these do not have a drain plug..
Just tip the mower up on it's side to drain out the fill tube.. (per owners manual for most self propelled Briggs and Stratton mowers)
You can verify if you wish by going to the Toro site.. get your model number first.
Disconect the spark plug wire before tipping it.. just for safety.. and have a few rags ready..
Best of luck!
Apr 17, 2011 | Toro Power Lawn Mower
Where the heck is the drain plug?! Yerf Dog Fun Cart 3203
The drain plug is located under the mower where the blade shaft comes out it may be covered in caked grass clippings scrape them of with a screwdriver or putty knife to reveal the square oil plug.
Aug 07, 2009 | Toro Lawn Mower With Toro Power Tools
Oil Drain Plug Location
that is the drain plug sometimes hard to get loose but should come out it is in bottom of engine above blade.
May 07, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
