Question about Dishwashers
Dial gets stuck about 20 minutes into cycle - by then it is in the wash cycle - have to manually move it forward to get it unstuck.
  • wahktheline May 17, 2011
    Yes, I think it follows with what someone else mentioned so I will try the cleaning to see if works.
  • 4,323 Answers
Hi
First take the bottom panel out and clean the drain pump assembly. If the issue returns after it is cleaned then it means the timer is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on May 17, 2011
GE Washer stuck in wash cycle and not draining.
humming is usually the result of bad motor windings , are u saying it washes for 20 minutes or just stays on that cycle without doing any washing? a non moving drum can be a bad motor coupler or belt if belt driven.
Mar 30, 2015 | GE Washing Machines
My normal cycle doesn't light up on the dial
Hello sisterw - If only the normal cycle is not lighting up on the keypad but all the other options do, then the washer may be experiencing a wiring failure. Try resetting the unit by unplugging it or flipping the breaker off. Wait approximately ten minutes. Restart the unit and if it proves to be ineffective contact a professional to move forward accurately to properly diagnose the control board as well.
Dec 08, 2012 | Frigidaire Affinity ATF7000E Front Load...
I own a 1999 chevy silverado z71 4x4....just moved to north dakota....the truck sits outside, started every day runs for 20-30 minutes, however no longer (last 2 weeks) goes forward....reverse is...
maybe cold got a vavle stuck in the vavle body maybe will come unstuck if dont have to go into it .is it a 700r-4 trans.??if is check detent cable maybe out of ajustment .
Dec 26, 2010 | Chevrolet Silverado 1500 Cars & Trucks
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
STICKS on cycle, wash, etc. If manually moved
Do you mean the timer or control dial sticks. If so then it may be the timer mechanism itself.
Make sure that when you are skipping a turn on the timer that the machine is actually performing that particular task of the cycle. For example if the timer gets stuck before the drain cycle, and you manually skip forward to it, that it actually drains the water out.
If so then it is most likely a worn timer mechanism which sticks.
Ash
Oct 23, 2009 | Frigidaire Dishwashers
Dishwasher not working
sounds like the heater is not working. it's washing while waiting for it to heat to correct temperature.
if you are not electrically minded i'd get an engineer out or ring one for a quote.
Jan 27, 2009 | Dishwashers
Hotpoint bwm129 gets stuck mid cycle and dial does not move round
YOU NEED TO ESTABLISH IF YOU ARE USING A HOT CYCLE IF THAT IS SO YOU MIGHT HAVE E PROBLEM WHERE THE ELEMENT IS NOT COMING ON THEREFORE THE THERMOSTAT WILL NOT FUNCTION RESULTING IN THE TIMER REMAINING STILL.YOU NEED TO CHECK THE ELEMENT IF THATS THE CASE.IF YOU ARE USING THE COLD CYCLE AND IT IS STUCK ON THE SAME POSITION FOR A LONG TIME YOU MIGHT HAVE A FAULTY TIMER BEST YOU HAVE IT REPLACED IF THAT IS THE CAUSE.LET ME NO IF YOU NEED ANY MORE ASSISTANCE.GOODLUCK.MOHAMED
Sep 15, 2008 | Hotpoint BWM12 Front Load Washer
Dishwashers Logo
170 people viewed this question
Top Dishwashers Experts
