Hhjjj i have a problem with sitecom wireless router, its not connecting to my modem, in essence, its nt browsing and specifically, its not connecting to the 192.168.0.1
  • dorismichaud Dec 27, 2008
    Have Netgear wpn824. Already using it for wireless connection to XBox 2360, a laptop and hadwired to a PC and a MAC. Son wants to be able to use internet on his new PSP. How do we add that. The main connection of the router is to a MAC.
Trying to connect to home internet with a
portable Play station /psp but cannot find the web key adress
it is asking for
Posted on Aug 30, 2008
I got a problem in connecting my samsung galaxy GT-7500 to sitecom extender 300N .. I have tried to change the IP address but it doesn't work with me . Any help plz?
Which modes are you trying to use this Sitecom? If you have the Sitecom as your Access Point (AP Mode), then you would need a LAN connection to your internet gateway (DSL, Cable Modem, etc). I didn't see any LAN hook up so I assume you are trying to use it as a wireless repeater. So you need to configure the unit differently. The 3rd mode is called Bridge mode. Again, you need to have a LAN hook up to your local network with a router or network switch.
Because your Tablet is connecting to the Sitecom okay, which mean that you either have the Sitecom setting for AP mode or Bridge mode. And the reason it didn't give you access to internet because there is no internet gateway connection to the Sitecom (LAN). I hope this answer your question (or confuse you totally).
Feb 15, 2013 | Computers & Internet
Sitecom WL-342 Wireless Router won't access internet.
Make sure there is a network cable going from your ADSL modem into the WAN connection of the router.
If the ADSL modem is wireless, then it is also a router in whihc case you will want to bypass the WL-342 all together.
Thanks,
Pat
Apr 01, 2010 | Computers & Internet
I have a new Sitecom 341 wireless N router setup and working fine with other laptops in the home. My dated acer travelmate can see the modem and reports excellent connections, but is not serving pages in...
Theres a few things to try here 1) the acer may not like the type of wireless security you are using , WPA needs to have the correct hardware to work - log into the router and remove the wireless security and see if it will now connect - if it does, try putting the security back on and see if now connects - if not, you may need to change the security to WEP or use MAC Filtering 2) It may be that a firewall is blocking access to your network - try disabling the firewall 3) You may need to remove the wireless profiles on the PC and then reconnect and re-enter the security password - read here on how to do that http://mgmcc.forumotion.net/networking-tutorials-f17/removing-an-existing-wireless-profile-t109.htm
Mar 19, 2010 | Sitecom xDSL/Cable Broadband Router DC-200
I have a Sitecom 300n modem router. My MacBook pro finds it and can connect to it wirelessly, but every 5 mins or so when browsing the web just stops so I have to stop the connection and re connect to it...
Make sure the latest wireless card driver is installed in the computer.
Locate the wireless router higher and away from concrete and brick walls, foil insulated walls.
Locate the wireless router away from cordless phones and microwave ovens these can cause interference.
You could be getting interference from other wireless access points or wireless routers in your area. Check the wireless broadcast channels in your area, and select one that is unused or one that has the weakest signal strength.
For further information, please click on this link and follow my instructions.
http://www.fixya.com/support/r3559120-wireless_router_disconnecting
Jan 16, 2010 | Computers & Internet
I just installed my router sitecom 300Nx2. One of my already installed communication programs which was originally working now can not connect. Please advise.
Need a bit more information here but I suspect your "communication program" used to dial using a modem and now it's needs to connect via the router
Oct 24, 2009 | D-Link DI 514 Wireless Router (DI-514)
Same old question, but I cannot get a connection between my Netgear wireless router WGR614 to my cable modem.I follow the set up via the router's wizard. But no luck. Even unplugged the modem for 15 mins...
Can you pls confirm if you have cable or PPPoE connection. Also, please connect the modem directly to the computer and let me know the results:
A. Click on Start—Programs—Accessories—Command Prompt.
B. In Command Prompt window, type in 'ipconfig' and hit 'Enter'. Note down the IP Address, Subnet mask & Default Gateway here.
Once I have this information, it will be quite easy to configure the router.
Oct 09, 2009 | NetGear WGR614 Router
Everything appears to be working, but not internet connection
Turn off the firewall in both the router and the modem. try again-- once it is working ...just turn one of them back on..
May 16, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Wireless router 300M no acces to the internet
You need first to configure the router to work with your modem, if you have the setup CD of the router just that one and then follow all the steps on the setup CD after you're done running the setup CD of the router power down modem and router for 1 minute then plug the modem first wait for about 30 seconds and then plug the router back , after that check if internet is already working........
Nov 07, 2008 | Sitecom xDSL/Cable Broadband Router DC-200
Computers & Internet Logo
197 people viewed this question
David Payne
David Payne
