Hello! I have a Whirlpool Duet Seam Washer #WFW9600TA that after 3 years has started with the SUD and F 35 error codes. I have been studying FixYa and have discovered this has to do with an Analog Pressure Switch. I have called Whirlpool for a part number and was put on hold and was never gotten back to (30 mins+) Would you happen to have that part # ? Also, is there anything I will need to do after I install the new part, like a special start up procedure or something? Thanks M
    Problem Solver:
  • 14 Answers
W10156252 - Nope, just put it in, and away you go. :)
When you pop the pot off of your machine, it is a small brownish box, about 1x3 with a black hose coming out of the bottom. It is located on the right panel towards the rear
Posted on May 17, 2011
Testimonial: "Thanks! You guys are great and so helpful. Keep up the good work! M"
Sud and f 35 code
Hello & Welcome to FixYa
F35 error means that there is some sort of issue with the steamer electronic board and analog pressure sensor has gone bad. Check that the hose is firmly attached with the washer and is not blocked. You can also check the water level pressure switch operation. Please get back to me if you have any other questions.
Kevin
Dec 18, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool Duet Washer, washer starts and then stops code F35
Kevin
Nov 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet steam WFW9600TW00 code F35
Kevin
Oct 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What does f 35 mean or sud on my washer machine
Kevin
Jul 31, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
My kenmore washer showes sud code
If it is similar to the Whirlpool duet,
Try using less soap (hi eff machine)
try using more fabric softner
to clear the occasional Sud warning, I run the machine on "quick wash" with no detergent/additive. gives it two more quick spin cycles in 30-35 minutes, usually clears it.
Jul 14, 2010 | Kenmore Elite 45986 Front Load Washer
Error code F 35 and SUD code
Save yourself a lot of time and money and replace the analog pressure switch. This will solve your issues by taking care of both error codes at the same time.
The Appliance Pro
Jun 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
WHAT IS ERROR CODE 35 OR ERROR CODE 37? ON MY FRONT LOADER.WFW9600TA00
does it say f35 and sud?
you need a new pressure switch
sounds like a new washer is it 1-2 years old?
Jan 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer stops during begginning of cycle with F 35 reading .
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 13, 2009 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Whirlpool duet washer flashing sud then f21 ????????
The "SUD" error is in direct relationship the other error code. "F21" is a Long Drain error. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
If something is preventing water from pumping through the drain pump, you will often get a "SUD" error as air is developed in the pump. Make sure you double check all the drain lines as well.
If you have questions, or require additional assistance, please let me know before you rate the solution. I hope this helps you.
Jan 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
202 people viewed this question
Top Washing Machines Experts
