Question about Homelite Garden
I have 62b blower. It will not start. It is less than one year old. What could the problem be?
  • 1,476 Answers
Mgkdq,
Generally these kinds of units sit more than they are used so they can absorb moisture in the fuel tank and make starting hard. Gasoline does not stay fresh for more than a couple of months and loses octane and volatility. Also your unit is a two stroke which will foul it's spark plug sooner than a four stroke motor. I would get a new spark plug and install it. Being careful remove all the gas from the fuel tank, wipe it out with a clean cloth (if possible) or leave it open for several days to dry any water up. Refill with fresh gas, preferably high octane (greater than 93 octane) with the proper oil mixture/ratio (this should be available in your owner's manual). Remove the air filter and replace it with a new unit or clean it per the manufacturer's instructions, if your unit has a cleanable filter. Remove the spark plug and with it hooked to the wire, and the metal end resting on the motor fins, spin the unit over and watch for a spark. It should be blue/white and a good size and snap. If the plug sparks fine, reinstall the plug and following the manufacturer's recommendations try to start the unit. If these were the only problems your unit should run fine.
Thanks for using FixYa and for the great rating.
hardrocko
Posted on May 17, 2011
My Amana gas dryer is less than a year old and it heats, but does not blow. I took the vent off and it is clean, but no air comes through the vent
If less than a year old it should still be under warranty. Sounds like the blower motor is faulty, but no point paying for a repair if the manufacturer will cover it
Jan 13, 2018 | Amana Dryers
My blower just stalled and will not run it is less than a year old and now the pull cord is very tight but it will turn and start but it will not run for mor than a few seconds
Have you changed the fuel.? If it had been stored for a long time with fuel in it then it could have gone stale and will need replacing. Also the 2 stroke oil can gum up carbs as the fuel left in it evaporates. Possibly clean carb, check fuel is getting into the cylinder.
May 09, 2013 | Husqvarna Backpack Leaf Blower 350 Bt Yard...
I have a goodman ar24-1 blower motor that will not start. I have changed the capacitor, checked the thermostat, spun the blower motor but still will not start. Outside unit runs but no blower. Any ideas?...
Check the relay or sequencer that controls the blower if it has one of those. If the fan is controlled by a circuit board then you problem may be there. If it is controlled by a circuit board then you can check for power at the fan connection when the fan is supposed to be on. Then there is always the possibility that you blower motor is burned out. You can use and ohmmeter to check the motor windings. You said you checked the thermostat, how did you do that? If you install a jumper between the R and G connections the fan should run if everything else is OK.
Nov 14, 2010 | Goodman CKL24AR24 Air Conditioner
Have Poulan BVM200VS 25cc gas blower. It has compression, is getting fire and has fresh fuel mixture. Will not start. Any suggestions? It is less than 1 yr old.
By luvcatzlotz on Sep 08, 2010
Answer: I have the same problem. Thats why the company is called Poulan.. Because thats what you do half the time when you own one. PULLON the starter cord...............
Sep 08, 2010 | Poulan Electrical Supplies
Car will not start
put battery on charge overnight then it go ok
Apr 08, 2010 | 2001 Hyundai Elantra
IT started to vibrate about 1 our ago. The machine is less than 2 years old and the filter is clear.
Vibrations mean something is off balance. Possibly a faulty drum support roller but not likely due to age. Check the blower wheel for something stuck in it or broken fins.
Eric
Jun 08, 2009 | Whirlpool Dryers
I have a monessen LPG fireplace and the blower motor has seemed to stop working. it has a variable rotating switch on it. dont know if anyone knows where this problem is on most models like this?
The problem is likely the fan motor for the forced air blower, which means the entire blower needs replaced. The description of the problem is the same problem we had approximately two years ago when our motor was still under warranty (less than a year old). In our case the motor was replaced without charge. However, the same problem has happened this year which is extremely disappointing since we only run the fireplace from December to April intermittently because it is only a supplimental heat source for the house. You can either look up the model number and part number and order a replacement over the web (less expensive if you are DIY and know what you're doing) or see if the local LPG supplier can repair the part or replace. Good luck.
Dec 06, 2008 | Stoves Monessen Variable Thermostat...
Garden Logo
26 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
