Question about Optoma MovieTime DV10 Multimedia Projector
The low lamp life indication message is constantly on at startup of projector until I press the menu button. I have changed the lamp but the message continues to show up each time I start the projector. I even went into the menu and selected not to warn when the lamp life is low but no change. How do I get the message to stop?
  • John Rennish Dec 07, 2011
    Replacement bulb is from lampexperts.com. I've had good luck with their bulbs in the past. I've taken it in to a local repair shop to have the color wheel replaced since it started making that insufferable noise. They replaced the color wheel and said they reset the bulb so it wouldn't have that problem again. It's been 3months now and haven't had the problem and the color wheel is working well also. Thanks. Perhaps you could post directions how to reset the lamp hour monitor to help someone else resolve this problem and I could file it for future reference. Thanks!
Reset the "Lamp Hour" monitor from the on screen display "management" menu tab. Where did you buy your lamp?
Posted on Dec 06, 2011
The machine starts, eventhe vent, but no image appears. All the lights, except the POWER SAVING one remain lights on.
  • Plug the projector into the wall and put it into standby mode. You should have already replaced the projector's lamp with a new LMP-P200.
  • Press the "Reset," left arrow, right arrow and "Enter" keys on the projector's control panel. Press them in the exact order listed here, one after another, and press each key for less than five seconds.
  • Turn the projector on with the "Power" button. Press the "Menu" key to enter the projector's menu settings.
  • Press the down arrow to navigate to the "Install Setting" menu and press the right arrow to select it. You should see the lamp timer at the bottom of the screen. If you have correctly reset the lamp timer, it will indicate 0 or 1 hours.
  • Press the "Menu" key to exit the menu system.
  • Read more : http://www.ehow.com/how_6900249_reset-lamp-timer-sony-vpl_px20.html
    How to Reset Sony Projector eHow
  • Turn on your Sony projector after replacing the lamp.
  • Press the "Menu" button, go to the "Lamp Setting" option and select "Lamp Timer Reset." The projector should display a confirmation window asking, "Has the Projection Lamp Been Replaced?"
  • Select "Yes." You will receive a message onscreen saying, "Lamp Timer Reset Complete!" Select "Yes" again, and press the "Enter" button to finish.
  • Read more : http://www.ehow.com/how_7196165_reset-sony-projector.html
    Jul 02, 2015 | Sony VPL CS4 Multimedia Projector
    HOW RESET THE TIME OF LIFE HRS TO THE LAMP INSHARP ANC55LP PROJRCTOR
    Reset the lamp timer.
    1,Connect the power cord.
    2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
    "LAMP 0000H" is displayed, indicating that the lamp timer is reset.
    Have a nice day!
    We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
    motherboard, powersupply ... with high quality and competitive price.
    Jerry
    Lampdeng Limited
    Feb 08, 2013 | Sharp ANC55LP Projector Replacement Lamp
    Replaced main bulb in front but lamp button on front of tv is still blinking and tv won't show picture
    The lamp timer on the Hitachi projector must be reset whenever the lamp has been replaced. The "Lamp" indicator on the display will light red or the "Change the Lamp" message will display when the lamp timer needs to be reset. Hitachi recommends that the lamp timer never be reset without replacing the lamp and to always reset the timer when the lamp is replaced. The message functions of the projector will not function properly if the lamp timer is not correctly reset.
  • Turn the power on. Press the "Reset" button for three seconds until the "Lamp xxxx hr" message appears on the lamp timer on the bottom of the screen.
  • 2
    Press the "Menu" button on the remote control while the lamp timer is displayed.
  • 3
    Press the left arrow button. Select "0" and wait until the timer display clears.
  • If this was helpful a vote on the thumbs up for the free advoce would be greatly appreciated. Thanks
    Apr 04, 2011 | Hitachi 60V500 60" Rear Projection...
    Canon LV-S3 how to check hours on the lamp? do I have to have unit hooked up to an input source?
    Lamp Replace Counter
    Be sure to reset the lamp replace counter after Lamp Assembly is replaced. When the lamp replace counter is reset, the LAMP REPLACE Indicator stops lighting.
    Note : Do not reset the Lamp Replace Counter until after the projection lamp is replaced.
    1. Turn projector on, press MENU button to display the On-Screen Menu. Press Point left or right button(s) to move the red frame pointer to the Setting Menu icon.
    2. Press Point down button to move the red frame pointer to "Lamp counter reset" and then press SET button. The message " Lamp replace counter reset? " is displayed.
    Move the pointer to [Yes] and then press SET button.
    3. Another confirmation dialog box appears and select [Yes] to
    reset the lamp replace counter.
    This projector uses a high-pressure lamp which must be handled carefully and properly. Improper handling may result in accidents, injury, or create a fire hazard.
     Lamp life may differ from lamp to lamp and according to the environment of use. There is no guarantee of the same lifetime for each lamp. Some lamps may fail or terminate their life in a shorter period of time than other similar lamps.
     If the projector indicates that the lamp should be replaced, i.e., if the LAMP REPLACE INDICATOR lights up, replace the lamp with a new one IMMEDIATELY after the projector has cooled down.
    ( Follow carefully the instructions in the LAMP REPLACEMENT section of this manual. ) Continuous use of the lamp with the LAMP REPLACE INDICATOR lighted may increase the risk of lamp explosion.
     A Lamp may explode as a result of vibration, shock or degradation as a result of hours of use as its lifetime draws to an end. Risk of explosion may differ according to the environment or conditions in which the projector and
    lamp are being used.
    IF A LAMP EXPLODES, THE FOLLOWING SAFETY PRECAUTIONS SHOULD BE TAKEN.
    If a lamp explodes, disconnect the projector's AC plug from the AC outlet immediately. Contact an authorized service station for a checkup of the unit and replacement of the lamp. Additionally, check carefully to ensure that
    there are no broken shards or pieces of glass around the projector or coming out from the cooling air circulation holes. Any broken shards found should be cleaned up carefully. No one should check the inside of the projector
    except those who are authorized trained technicians and who are familiar with projector service. Inappropriate attempts to service the unit by anyone, especially those who are not appropriately trained to do so, may result in an
    accident or injury caused by pieces of broken glass.
    Dec 24, 2010 | Canon LV S3 Lamp
    I have a Sharp XR-10X-XL projector, i have replaced the bulb but it still will not go on. The Stand by light and the bulb light are both on constant red, I have checked both the heat sensor and the fuse on...
    Have a nice day!
    Jerry
    Lampdeng Limited
    Dec 13, 2010 | Sharp (AN-XR10LP) Projector Lamp for XR10X
    How do i reset my xr-10x lamp life on the projector
    Hold down the MENU/HELP, ENTER and down arrow buttons and press the standby/on button. Keep holding down the 3 above butons until the LAMP 0000H appears on the screen. That will indicate that the timer has been reset. Please note that all 3 buttons MUST be held down when the ON button is pressed. I can tell you that it may take a few tries to get it correct. Holding down the 3 buttons at the same time is tricky.
    Dan
    Jan 08, 2010 | Sharp XR-10X Multimedia Projector
    How to change sharp xv-120zu bulb
    Jun 07, 2009 | Sharp (RLMPF0005CEZZ) Projector Lamp for...
    Lamp life indicator reset
    Click Sanyo Support to download Instruction Manual copy and check page 39 for details about Lamp Reset procedure.
    Apr 30, 2009 | Sanyo PLC-XT16 Multimedia Projector
    How to reset the timer on a sharp BQCXVZ1001 when changing bulb
    Jan 05, 2009 | Sharp BQCXVZ100001 Projector Lamp for...
    Lamp replacement
    Hi there
    You need to reset the lamp timer.
    Mar 11, 2008 | 3M (EP7640ILK) Projector Lamp for MP7640
    Optoma MovieTime DV10 Multimedia Projector Logo
    101 people viewed this question
    Top Optoma Office Equipment & Supplies Experts
    jasbo
    jasbo
    color wheel light...
    Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
