Question about Samsung DV218AEW Electric Dryer
Samsung dryer dv419gw xaa I have a drum belt thats shredding apart and came off once.I reinstalled it. When I get a new belt. Is their an easy to install it. Or do I have to remove the drum.
  • 686 Answers
SOURCE: Installing a drum belt on an Amana NDE2335AYW
call me if you'd like and i'll walk you through it Jim 417-926-0106
Posted on Feb 27, 2009
SOURCE: My Samsung Dryer (DV218AEB/XAA) Error code HE
invalid heating temp when running. call for service.
Posted on Sep 18, 2010
SOURCE: Our dryer (Samsung Model DV218AGW/XAA)
I had the same issue with a Samsung DV209AEW/XAA.
What I found was the belt had come off and the spring on the drum belt pully had come off.
After I disassembled the whole top and front to figure out I could not access what I needed from there I discovered I needed to enter in from the vent is.
Anyway here is some info:
Rear Access:
1) On the back where the Vent comes out you have 4 total screws. 3 of them are on the outside edge and the fourth is more of a middle mount that holds the tube to this bracket. Remove all four screws now you can lift and lean this plate to remove it.
2) This will also free up the vent tube and it can be pulled and cleaned also if you desire.
3) With these items out of the way you can now access the pulley for the belt and other items.
Posted on Nov 23, 2010
  • 3 Answers
SOURCE: I have a samsung dryer
This photo is from a Samsung DV409AEW, but I assume they are quite likely the same. I also turned the drum (clockwise, which is the wrong way) and the same thing happened. The thud in my case was the spring that holds the tension pulley arm in place falling to the bottom of the dryer. If your situation is the same, spinning the drum caused the belt to come off of the idler pulley and the tension spring fell off. It seems to happen frequently based on web searches.
Again, assuming the DV409Axx is the same, you can get at it from behind. There should be 3 screws (2 on the top and 1 on the bottom) of the plate that holds the vent pipe output assembly. That assembly can then be removed. There will be a vent pipe extension that comes out with the assembly.
Once inside, see if the spring is off, and if so re-attach it per the photo below. It is counter-intuitive that the spring pulls the arm down, rather than to the left. Hopefully this will be your issue.
Putting the pipe extension and outlet assembly back in can take a bit of fiddling... but if you lay on the floor, you can actually shine a flashlight in the crack to see what you're doing.
Hope this helps!
Posted on Dec 01, 2010
  • 291 Answers
SOURCE: have a samsung dryer model DV209AEW/XAA. I "hand
Check to make sure your child lock is off first. Hold the time and signal buttons simultaneously for three seconds. Unlikely, but do check. Some of these dryers have a safety switch that the idler pulley has to engage to allow the dryer to run. I tried to find a schematic for this model but could not get one to tell if you do have a safety switch. Look at the arm of the idler pulley and see if it is contacting the switch actuator correctly. When a belt breaks or pops off, sometimes the arm of the pulley will move to the other side of the switch actuator and will not allow the dryer to run once a belt is reistalled. I would also look to see if a wire was knocked off of the motor switch when your belt came off. Good Luck, Appliance Specialists
Posted on Dec 03, 2010
Samsung elec dryer, Model dv5451aew xaa 01. Drum not spinning. Belt ok. Dr Sw ok. Changed both fuses on heating element. Nothing.
Samsung dryer won't spin, belt is fine - Fixya
www.fixya.com/support/t8946132-samsung_dryer_won_39_t_spin_belt
Apr 14, 2011 - Question about Samsung DV218AEW Electric Dryer. 2 Answers ....Samsung dv410aer/xaa motor hums but drum will not spin. Mar 21, 2014 ...
How to Fix a Samsung Dryer: the Drum Won't Spin
www.ehow.com > Home
From time to time a dryer's drum can fail either by jamming up, a technical error ...Support US Samsung: The Dryer Drum Does Not Spin ยท Repair2000: How to .
Oct 16, 2015 | Samsung Dryers
How do I replace the drum assembly on Samsung DV218AEW//XAA dryer
You may not have a bad drum as that is the least likely item to go bad. What will go bad are drum support axles, support rollers, and bearings that when they go bad will cause the drum to sag and the belt will go loose and may fall off. Please use this link to help you figure which one it is and order the correct part for your dryer; http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/10---/Dryer-makes-noise?r=%2fShop-For-Parts%2fa8b160c26%2fSamsung-Dryer-Drum-Tub-Parts
Good Luck!
Rich Lilja
Oct 01, 2014 | Samsung DV218AEW Electric Dryer
Samsung Dryer Model DV419AEW /XAA Dryer will not
I doubt its the main board. Try seeing if the drum is tight and seeing if the belt broke by spinning it by hand. If the drum is real sloppy and you can't feel motor tension, you need a belt. I would rule out the mainboard until last because the belt is like 89 cents.
http://www.amazon.com/341241-Whirlpool-Kenmore-Dryer-Belt/dp/B00064NH6E
http://www.youtube.com/watch?v=zNATJ8qyqP4
Sep 27, 2013 | Samsung Clothes Dryer Control Panel Main...
Model dv209aewxaa timer counts down but nothing else is runing
Belt came off?? see We fixed our dryer!! so happy!! First We ordered the dryer belt with part # Samsung Dryer Belt 66002-001655. I got it off Amazon at a good price $11-13 at http://www.amazon.com/gp/product/B001KGX...THANK GOD we ordered it just in case because it turned out the belt had NOT slipped off but was SHREDDED apart. The BEST ADVICE to this particular model Samsung VRT steam dryer DV419AEW came from a commenter to another thread . Follow this thread if you have Samsung VRT steam dryer with model # DV419AEW= this threadhttp://www.fixya.com/support/t1210394-sa... The comment at the BOTTOM of the reply made by "dumb-stump". He describes how you take apart this particlar model. I also watched the youtube video on belt placement http://www.youtube.com/watch?v=obaoSDbzY... This shows how to place on pulleys etc once you get belt around the drum.
Jan 29, 2013 | Samsung Dryers
Samsung dv419aew/xaa turns on but drum does not turn, Belt is good and drum retates easy by hand
Can you hear the motor running at all? Do you feel any heat?
Jan 28, 2013 | Dryers
Samsung dv210 will not turn
Belt come off/damaged? Same thing happened to us and the clicking noise was our shredded belt flapping around hitting the drum. see : We fixed our dryer!! so happy!! First We ordered the dryer belt with part # Samsung Dryer Belt 66002-001655. I got it off Amazon at a good price $11-13 at http://www.amazon.com/gp/product/B001KGX...THANK GOD we ordered it just in case because it turned out the belt had NOT slipped off but was SHREDDED apart. The BEST ADVICE to this particular model Samsung VRT steam dryer DV419AEW came from a commenter to another thread . Follow this thread if you have Samsung VRT steam dryer with model # DV419AEW= this threadhttp://www.fixya.com/support/t1210394-sa... The comment at the BOTTOM of the reply made by "dumb-stump". He describes how you take apart this particlar model. I also watched the youtube video on belt placement http://www.youtube.com/watch?v=obaoSDbzY... This shows how to place on pulleys etc once you get belt around the drum.
Jan 20, 2013 | Samsung 7.3 Cu. Ft. Electric Dryer
Have a samsung dryer model DV209AEW/XAA. I "hand
Dec 03, 2010 | Samsung 7.3 Cu. Ft. Electric Dryer
I have a new Samsung electric dryer (DV218AEB/XAA)
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/8-160-1067142-/Samsung-Dryer-not-heating-DV218AEB
Click the link for no drum turning. There is a belt in the machine that wraps all the way around it, the belt has come off or broken.
Oct 08, 2017 | Samsung DV218AEW Electric Dryer
When tumble dryer is switched on the drum doesnt turn. The belt has shredded but not completely. You can turn the drum by hand. Im not sure what has caused the belt to shred or if it is anything else wrong...
you need a new belt and you need to examine the belt tensioner and the drum supports to see if they are o.k. sometimes belts just go bad. and sometimes one of the aforementioned devices cause it to go bad.
Oct 27, 2009 | Dryers
Samsung DV218AEW Electric Dryer Logo
206 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
