How to remove a bra wire from under drum - Washing Machines
  • Canwoodjc
    Canwoodjc May 17, 2011
    what make and model
  • Washing Mach... Master
  • 8,220 Answers
Find the heater and remove it. Then fish out the wire and re install the heater.
Posted on May 17, 2011
Bra wire stuck between inner and outer drum how to remove Hotpoint WMF760
Depends where it is stuck. If near the very front you can sometimes get them by removing the door seal to gain a small access between drums. Other ways is remove the outlet pipe from the bottom of the drum or easiest and most probable area where it stuck is remove heating element. Provides a better view and bra wires normally get stuck on them.
Jan 24, 2010 | Washing Machines
How do i reemove a bra wire caught in between the outer drum and inner drum of a hoover nextra 6 washing machine
Hi
Disconnect the machine from the power source and also disconnect the inlet hoses.
First start by opening the top hatch. You can do this by first opening the lid. there are 2 screws under plastic caps in the corners, under the lit. Open the screws.
See if you can lift the top hatch back. If not, you need to open the screws, or sometimes no. 7 bolts, in the back of the machine. These join the top hatch (plastic part) to the machine body (metal part).
When you raise the top hatch, there will be a power connection with earth wire, and a presure hose which connect to the bottom of the control panel. You can disconnect these. Take note, as you need to put them back on later.
Once you remove the top section you have clear access to the top of the drum. There is a plastic rim on top of the drum which you need to remove. Sometimes they are screwed on, and sometimes they clip into place. The old hoovers were clip on plastic. The newer hoovers are more like Simpson and have screws.
Once you remove that, look down in between the inner and outer durm and see if you can see the bra wire. If you can get to it with a long object it will be alot easier, than having to remove the inner drum. If the bra wire is free and just sitting on the base, just tilt machine to its side and with the help of a few people turn it upside down.
Removing the inner drum is a pain, and I do not suggest you do that yourself, unless you have the right tools.
However I can help you with it if you can not get to the wire. Let me know.
Regards
Ash
Nov 20, 2009 | Washing Machines
Bra wire's trapped between inner and outer drum,
If you cant pull wire out from inner drum with long nose pliers, Remove heating element and use torch to inspect bottom of washer. Most of the time the obstruction makes its way to the bottom. Use whatever tool necessary to remove spring.
Sep 25, 2009 | Hoover AAA160 Front Load Washer
Bra wiore inside drum
HAVE YOU A GOOD BRIGHT TORCH? IF SO I REMOVED MINE WITH A TORCH IN MY TEETH & A SMALL FLAT ENDED SCREWDRIVER, IF YOU CAN SEE IT TURN OFF ALL POWER TO THE MACHINE FIRSTLY THEN USING THE SMALL SCREWDRIVER COAX THE BRA WIRE TOWARDS THE NEAREST HOLE IN YOUR DRUM & THEN FEED IT THROUGH AS BEST AS POSSIBLE & THEN GRAB IT WITH EITHER FINGERS OR PLIERS IF IT IS A STRUGGLE TO PULL IT OUT.
DONT LEAVE IT IN THERE & THEN OPERATE IT AS IT WILL JAM IT & BLOW YOUR EXPENSIVE MOTOR WHICH ARE APPROX £80 OR HIGHER & YOUR PUMP IF IT JAMS IN THE BLADES BEFORE REACHING YOUR FILTER ..
May 22, 2009 | Hotpoint Aquarius WMA56 Front Load Washer
How do you remove underwire lodged between drum and outer case
hi to remove bra wire from between drums ? you might try this 1st ? if you diconnect water supply hoses and unplug power supply then remove rear panel from machine you will have access to the large rubber drain hose from outer drum down to discharge pump ? ok hose is held by spring wire clips both ends remove clips then hose you may find bra wire either in hose or close to drum drain if you need ? feel inside drom via drain hole ? or probe with a piece of coat hang wire ? you may even find the mysterious missing sock/ thong / etc when you disconnect the hose too?? any debri has to lay in bottom of outer drum and so a little patience will locate them using this method instead of removing the main front door sealto drum for access to same area also with rear panel off you can check belt tension ? hope this helps/inspires you ? best wishes from uk
Feb 26, 2009 | Hotpoint First Edition FEW12 Front Load...
Bosch Maxx WFL2061 Scraping sound when rotating the drum
under wire of a bra caught in drum , I have taken out hundreds,Close Ireland
Nov 12, 2008 | Washing Machines
Bra wire removel
Dont know what model you have. Search the net for a repair manual for your model machine. Some are downloadable. Then remove the tub to get to the bra wire.
Apr 12, 2008 | Washing Machines
Bosch Classixx 1200 Express - metal got under the drum
This video will show you how to get into the drum through the heating element and remove the bra wire on this Bosch front loader washing machine
we have all bosch repairs in our channel
Apr 01, 2008 | Washing Machines
Bra underwire stuck
Switch off machine and unplug it from the wall socket. Remove back plate and identify the heating element. It should be located at the bottom of the outer drum. Remove element and you will have limited access to the space between the drums. Rotate the drum slowly by hand untill the bra wire gets to the bottom of the drum. Remove obstruction with hook or long tweeser.
Oct 31, 2007 | Bosch WFMC6401UC
Obstacle wire stuck in drum (model FLS1183W)
you will have to split the case u will find 6 8mm bolt under the lid remove the 2 rear looking from the front then down the sides u will see 2 round plastic covers remove them by putting a small screw driver in the centre of the lug there r another 8mm bolt in each side use a small screw driver to remove the mains and valve block now the cabinet will split u will need a 10mm socket to remove the heater and a claw hammer to get the heater out of its housing use the claw by caerfully placeing it under the terminal 1side @ a time and the heater will come out u will be able to get the bra wire out from there u may need a set of long nose plyers good luck and make sure u have unplugged the machine b4 u start any dissmanteling
Nov 28, 2006 | Zanussi FS1155W Front Load Washer
Washing Machines Logo
99 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
