Question about HP LaserJet 4345mfp Printer
I have a hp4345mfp on the display it is showing a error internal disk not found we do not have a hard drive can we turn off the hard drive thank you my email is
  • HP Master
  • 1,915 Answers
All HP MFP's have an internal harddrive and will only function as printers if that drive fails. You need to replace the harddrive. It is mounted on the formatterwhich is accessed on the back. First remove the sliding panel and then open the metal door. These are right where the fax and data cables plug in. You can replace the drive with almost any 2.5" IDE harddrive that you can find. The standard model will be either a 20, 30 or 40 gig, I have installed up to 160 gig drives with no problem. Do not order a drive from HP as they will charge several hundred dollars for a drive you should be able to get at any computer shop for less than $75.00. Be cautious removing the drive from the plastic mounts as they are easy to break.
Posted on May 17, 2011
When i switch the laptop, i hear a knocking sound from hard disk and the computer displays non - system disk or error disk plz help
Good Day Kawindwe!
I am sorry but I think the hard disk is on its last leg. A knocking sounds is the first symptoms of faulty hard disk. It is better to replace it.
The non-system disk error is displayed when the CMOS BIOS failed to detect the hard disk.
There is a small chances of making your hard disk work again. It worked for me before maybe it might work with you too.
First, turn off your Laptop. Remove the power supply adaptor from your Laptop. Remove the battery. Press and hold the power on button for at least 5 seconds to discharge remaining volts on your unit. After awhile, return the battery, plug in the power supply adaptor and turn on Laptop. See if that recognize again your hard disk.
If the first did not fix it, try this one. Turn off your Laptop. Disconnect your hard disk and then reseat the connectors properly. Then, turn on your device. Did that fix your problem?
Kawindwe, in case that fixed it, I recommend you back up your files cause the hard disk will not last that long.
Jun 10, 2011 | Computers & Internet
DELL INSPIRON 1545 (Windows 7) My laptop is displaying the message below when switched on: Internal hard disk drive not found. To resolve this issue, try to reseat the drive No bootable devices...
Hi
It seems that the Hard Disk is disconnected from it's connectors
It needs to be fixed and installed correctly.
To do that, there are screws in the back, remove them and disconnect the hard disk, and reconnect, fix it correctly.
If it's difficult to you, go to technician to do that.
Please, Tell us your results.
Good Luck
May 20, 2011 | Dell Inspiron 1545 Notebook
When i turn on my Acer Aspire One D255 it says: "check cable connection! PXE-M0F: Exiting Intel PXE ROM. No bootable device -- insert boot disk and press any key"
The PXE ROM is part of your system's network interface controller. It is being entered on your system's startup to look for a bootable image on a physical network connection and if found, to boot from that image. If there is no network cable connection to your system or if there is but no bootable device is found on that connection, the result is the error message that you got. As to why your system is entering the PXE ROM can be explained by looking at your system's Setup Utility,,,
Press F2 while powering up to enter the Setup Utility and use the cursor control keys to go to the Boot tab which then shows the Boot priority order. The default order is as follows...
1. IDE0
2. IDE1
3. USB FDD
4. USB HDD
5. Network Boot : LEGACY PCI DEVICE
6. USB CDROM
Your system's internal hard disk drive should be listed beside IDE0 and it will be accessed first to look for a boot record. If the drive fails to boot, the next devices in the list will be accessed accordingly until either a bootable device is found or the last item which is USB CDROM. If a USB CDROM is plugged in on one of the system's USB ports, it will be checked for a bootable record and if not found or no CDROM is plugged in, then the system displays the last part of the message -- insert boot disk and press any key.
Press F12 while powering up enters the Boot Menu which has the Boot Option Menu. This menu should show by default the following...
1. IDE 0: (the name/type information for your system's internal hard disk drive
2. Network Boot: LEGACY PCI DEVICE
If there is no hard disk drive information shown beside IDE 0, then the possibilities are that
1. there is no internal hard drive present
2. there is a hard drive but it has failed
If there is hard disk drive information and pressing enter to select it does not result in an operating system startup, then the drive's startup partition has been wiped and so it has no bootable image.
If there seems to be an internal hard drive present but it has no bootable image, you may attempt recovery from the installation images in the hidden partition. The recovery allows restoration of...
1. operating system to factory defaults
2. applications (selectable)
3. drivers (selectable)
Press Alt and F10 keys together while powering up and the Acer logo is showing to enter Acer's eRecovery Management. Follow the instructions to do the recovery.
Feb 09, 2011 | Acer Aspire One Netbook 8.9" Notebook
My PC displays: "please insert a disk drive" while
this error is identicated that your hard drive connector not connected properly, open your computer, disconnect your had drive and connect again, if this way not work and still show that message it mean your hard drive was broken, you need new hard drive
i hope this helpful
thank you for using fixya
Feb 03, 2011 | IBM ThinkPad T22 2647 Notebook
When I turn on my acer aspire one d250 it says Check cable connection..! PXE-E63: Error while initializing the NIC PXE-M0F: Exiting Intel PXE ROM No bootable device -- insert boot disk and press any...
1. IDE0
2. IDE1
3. USB FDD
4. USB HDD
6. USB CDROM
Press Alt and F10 keys together while powering up and the Acer logo is showing to enter Acer's eRecovery Management. Follow the instructions to do the recovery which will erase all user data and restore the operating system to its factory default when you purchased the netbook.
Jan 03, 2011 | Acer Aspire One D250 (99802378332) Netbook
As soon as I turn on my laptop a message says that the internal hard disk drive was not found and that I should reseat the drive.
Yes that is the first thing your should try.
When the computer cannot detect the hard disk or a boot disk then you get this error message. Please click on this link to determine the fault and solution to this problem :-
http://www.fixya.com/support/r6244569-no_bootable_device
Oct 18, 2010 | Dell Inspiron 1525 Notebook
It says Error0200 Fixed Disk Failure
Hi
thank you for your query
This error means unfortunatley your hard drive is now faulty and will not boot up, i know this as i have seen this many times
I would recommned that you book the laptop into a reputable PC shop as it will need replacing and windows reinstalling
If this has been useful please leave positive feedback/vote/testimonial as
this will help me greatly - Thank you again
Feb 13, 2010 | IBM ThinkPad R40 2722 Notebook
Dell screen comes on and trys to load up
Hi
Seems like the hard drive has failed, or there is no hard drive in the laptop, replace it with a new one.
This part of the service manual shows you how to replace it:
http://support.dell.com/support/edocs/systems/latd610/en/sm_en/hdd.htm#wp1123687
Dec 21, 2009 | Dell Latitude D610 Laptop Computer -...
Graphics, missing hard and disk drives,
YOUR MAIN BOARD HAS A PROBLEM JUST TAKE TO A APPle service center
Jan 03, 2009 | Apple Computers & Internet
HP LaserJet 4345mfp Printer Logo
329 people viewed this question
Seeker5211
Seeker5211
