Question about Dell Latitude D600 Notebook
I have a problam with a dell latitude d640 laptop if i press power button flash power led and then trun off
  • 10,421 Answers
Please connect your power adaptor and have your laptop turn on. If the problem is not persist, the problem is on your battery and need replacement.
But if still the same , you need to check and fix BIOS or internal HDD.
Posted on May 17, 2011
My dell powers on then off and the caps lock key led flashes 22 times then stops on
Hi Electrons,
Request you to try following the below steps which might help:
    (1)Turn off the computer.
    (2)Remove all the external peripherals like AC Adaptor, flash drives, battery, etc.
    (3)Press and hold the power button for 30sec which releases the static on the computer (if any)
    (4)Put back the battery and plug in the AC Adaptor.
    (5)Let the computer charge for some time.
    Now try turning on the computer. If still same issue then check if there are any series of beep codes emitted from the computer and see if there are any if there are any diagnostics LEDs being displayed.
Mar 18, 2015 | Dell Computers & Internet
Latitude D830 starts then shuts down quickly.
1. Make sure you are plugged into A/C.. Your battery could be running low.
2. Make sure there is nothing blocking the heat vents. This symptom is typical for overheating processors.
Mar 17, 2013 | Dell Latitude D830 Laptop Computer PC...
Capslock10 times blink with both indiator num/scroll lock are off
It certainly does indicate motherboard issue, sub out the ram memory one at a time and test, if no change! the laptop needs to be checked out for motherboard problems.
Apr 11, 2012 | Dell Latitude D600 Intel Pentium M 1.3GHz...
Just want to know how to tell if a Dell Latitude C610 battery is dead
With dell laptops, there should be buttons near the led lights.
Check the battery charge by pressing the status button or image on the battery near the LED's.
Note: The lights indicate the current amount of charge on the battery. If all the LED's come on when you press the button, the battery is fully charged. If fewer lights are lit, then the battery is partially charged. If any lights flash, or blink, there could be a problem with the battery.
Hope this helps...
Sep 13, 2011 | Computers & Internet
Latitude D600 PC Notebook: dell d600 three light on and of problam...
This is do to the jack were the power button board plugs into the motherboard, i see this alot on d600 and d610, the lights come on for about 3 sec then computer turns off..
this can be fixed by resoldering the plug to the motherboard but most will say you need a new mother board the leads are small and tight together..
Used motherboard on ebay $60-150
May 17, 2010 | Dell Latitude D600 Notebook
Dell Latitude D600 will not boot
This problem can be solved by scanning the computer from viruses.
thanks..
Jan 31, 2009 | Dell Latitude D600 Notebook
What is the button and set of 5 lights on a dell c610 battery for
The LEDs on the battery indicate the charge remaining. Press the button and you should get 5 LEDs with a full charge. The LEDs stay on in a steady state as long as you hold trhe button
The LEDs can also indicate an internal failure of the battery (Usually 1 3 and 5 will flash) if the LEDs flash, the battery is either critically low or failing. If charging it doesn't change the LED flashing them the battery will need to be replaced
Jan 27, 2009 | Dell Latitude D600 Notebook
DELL D600NFULLY CHARGED WHEN ON BUTTEN PRESSED NO ACTIVITY
The Caps Lock LED flashing indicates a Motherboard failure on the system
Jun 17, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
46 people viewed this question
Alun Cox
