Question about GE WBSR3140DW Top Load Washer
Cant get new drive belt on - GE WBSR3140DW Top Load Washer
    Problem Solver:
  • 14 Answers
It is a killer to do. I promise it does fit, even though it may seem too small. The easiest way to do it is to take the screws out that hold the bottom panel on, (just the ones that are right up front) and let the bottom panel fall open so you can reach in better. Start the belt on the motor pulley, get it as far as you can on the tranny pulley, and start rotating it until it snaps on.
Hope that helps!
Posted on May 17, 2011
I HAVE A CRAFTSMAN 1000. I AM TRYING TO PUT NEW DRIVE BELT ON AND CANT.DO I NEED TO TAKE DECK BELT OFF TO DO IT?
most probably as most drive belts are above the deck belt owing to the fact that the deck height can be shifted
Jun 21, 2016 | Craftsman Garden
What size belts for varidrive
If you're talking about a main drive belt (the one that turns [drives] the rear wheel), drive belts are usually measures as width (how wide) and number of "teeth".
An example is here:
http://www.jpcycles.com/product/600-0541
this belt is 1-1/8" wide, by 128 teeth.
Dec 27, 2013 | 2007 Vespa GTV 250 ie
I got a new belt for my washer, but cant get it back on seems too small but it is the right belt.
I have foun even with the Drive Belt/Motor tension bolt tension released it is difficult to walk the drive belt back on the Clutch pulley. As you can see there is not much room to work. From another post on a different forum http://appliantology.org/forum/5-the-laundry-appliance-repair-forum/page__prune_day__100__sort_by__Z-A__sort_key__last_post__topicfilter__all__st__180
See post 22 for drive belt demension as best I could measure.
Mar 28, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I need a belt diagram because mine broke and i cant figure out how the new one goes on
Accessory Drive Belt 3.0L (2V)/3.0L (2V) FF Engine
Accessory Drive Belt 3.0L (4V)
Accessory - SHO
Water Pump - 3.4L SHO
Mar 17, 2011 | 1996 Ford Taurus
Cant find a diagram for the serp belt. I replaced the alternator on a 01 windstar w/ a 3.8 V6 and need to know how to find and loosen the tensioner
For 2001 Ford Truck Windstar 3.8L SFI 6cyl
Fig. Accessory serpentine belt routing-3.8L engine (click for zoom)
Using a 15mm wrench attached to the drive belt tensioner pulley, rotate the tensioner clockwise to release the tension. Remove the drive belt from the pulley. When installing the new drive belt, ensure that the drive belt is routed correctly and note the position of the indicator mark on the tensioner.
Fig. Drive belt tensioner wear indicator marks
Hope helps (remember to rate thsi answer).
Mar 02, 2011 | Ford Windstar Cars & Trucks
I have a murray riding mower and I cant for the life of me see how you take off the engine drive belt. I have already cut it off and ordered new belts, but how do you put it back on? I cant see how you get...
Drop the deck and you will see the drive belt. One idler pulley you have to take completely off. But belt on in reverse order. Look up the manual it you have problems.
Jun 05, 2010 | Garden
When selecting the carpet cleaning mode, it appears the belt is slipping (due to the noise) over the drive pulley. How do you access the drive mechanism to replace belt or inspect drive pulley and belt...
On those units you must replace the clutch assy. you cant just replace the belt. there is also a special tool used to get the new belts on the brushbar. If you would like me to walk you through this repair let me know.
Feb 27, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
MY VACUUM IS NOT PICKING UP
Hi This is quite complicated but I'll try and simplify this for you:
If this is a Panasonic upright then there are two drive belts as you know. Once you take off the sole plate (where the beater bar is) by undoing screws and the beater bar is looking at you, you would have to take off the smaller belt motor pulley first before putting on a new larger drive belt. If the smaller belt is still intact and you only need to replace the larger belt, you'll still have to take off both belts to put on the new drive belt.
Motor pulley belt has to be taken off first then the old drive belt, then grasp the beater and slide on new larger drive belt before having to attach the motor pulley belt and then the larger belt onto the motor pulley. Once all belts have been attached ensure that the beater bar is pushed in correctly before you screw the sole plate back on.
Apr 03, 2009 | Panasonic Vacuums
Whirlpool wahsing machine
If yours is a whirlpool DIRECT DRIVE than it has no belt, may be why u cant seem to find one.
Dec 02, 2007 | Whirlpool Ultimate Care II GSQ9669L Top...
GE WBSR3140DW Top Load Washer Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
