Question about Sport & Outdoor - Others
How to fix the squeaking on my proform Xp 520 razor elliptical
SOURCE: Proform 520
Not sure what's happened here. treadmill won't turn on when red key is inserted. checked electrical plug to make sure it worked. I couldn't see that there's anything wrong with the red key. Have any ideas?
Posted on Sep 12, 2009
  • 103 Answers
SOURCE: Have proform 850 elliptical, unit jerks at bottom of travel
This is caused by a loose crank arm. The key assembly is loose. (#32 on your parts list) The covers will need to be removed to access this. Be sure the crank arms are realigned against the frame when completing the repair. Good luck, Tim
Posted on Nov 13, 2009
maxtreadmill
  • 832 Answers
SOURCE: my proform 10.0 ze elliptical has developed a
It sounds like the sleeve bushings maybe dry usually penetrating oil will take care of this problem. If not you may need to replace bushing then go to iconfitness.com to customer service then to replacement parts you'll get part# and Pricing
Posted on Feb 28, 2010
ercupa190
  • 12223 Answers
SOURCE: how to change bearings in proform xp 160
see the next video:
sincerely. God bless you
Posted on May 03, 2012
ercupa190
  • 12223 Answers
SOURCE: Proform 480 LE Elliptical screen does not work, but everything else works properly
5_3_2012_7_37_07_am.gifclean the contacts batteries for OXIDE, very well, see if some wires is loose.
Try to RUN the software calibration for diagnose and troubleshooting.
Proform 500 le elliptical
I would suggest that there is a wiring fault or dry joint. you need someone who is tech savvy to check inside the head.
Jan 28, 2014 | Exercise & Fitness
Proform hybrid trainer squeaks - elliptical portion only. Everything tight. What do I do now?
Locate the site of the sqeak. Then spray WD40 or similar spray lubricant thoroughly in and around the screws in that area using the straw attachment. I did just that and it took care of the problem.
Aug 07, 2013 | Proform Hybrid Trainer Elliptical
Proform xp 580 trips the breaker as soon as you turn it on
Treadmills have up to a 15 amp power draw. They are like space heaters, Proform often recommends having a dedicated 15-20 amp circuit for a treadmill. Ellipticals have less power draw.
I repair most Icon products, is this a new problem with an old treadmill? If it is a new treadmill, call the number in the front of the manual, if they can't fix it over the phone, there is a good warranty on it. At least for a little while. ;-)
Jan 21, 2013 | Proform XP 580 Trainer Treadmill
My elliptical trainer is starting to squeak. What should I do?
Don't worry; this is a common problem in elliptical trainers. Over time, parts of the machine may start to squeak. I am going to attach a how-to guide that will explain what to do when this happens.
http://www.livestrong.com/article/269134-how-to-stop-an-elliptical-from-squeaking/
Aug 02, 2012 | Exercise & Fitness
My proform 10.0 ze elliptical has developed a repetitive squeak in the rear drive...any ideas for a quick fix?
Feb 22, 2010 | Exercise & Fitness
I have an older proform elliptical and the battery cover cracked.
Go to FitnessRepairParts com and type in your exact model number in the search box at the top to view the parts list for that model. You may be able to find a cover there. Or you can contact support if you can't find your exact model number, they are very helpful
Feb 16, 2010 | Proform PFTL79807 - 850 W/ Gamefit...
My Proform elliptical is not working
clarification: when I get on the stepper there is not resistance. I'll get to a point when my feet will bascially fall right around....like something is loose or broken
Oct 17, 2009 | Proform XP 590S TREADMILL Drive Motor
Proform XP110 R recumbent bike makes clanking noise.
I have the same problem with my XP 110. After taking the ENTIRE thing apart and independently testing every single moving mechanism, I found out that it wasn't the motor, pedals, armbars, or any internal mechanism. Instead, it was the front stabilizer foot that made the annoying noise. There is a plastic mechanism around the front stabilizer legs that holds the front wheels in place (for moving the elliptical). Whenever a rotation forward occurs, the plastic squeaks and the noise resonates to make it sound like the pedals or motor is squeaking. I am still trying to find a solution to fixing the feet, but may end up ordering a new set from the manufacturer. Good luck with your elliptical!
Mar 22, 2009 | Exercise & Fitness
Sport & Outdoor - Others Logo
91 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
