Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Does the RCA TV model D52W20 have a digital tuner? or will I need a cable box to watch TV? At our location they just switched the signal. we just had a tube TV with the cable line in the back and up till last week were able to recieve all the channels.
    Master:
  • 346 Answers
Greetings Pete - No, your display is what is called HDTV ready, meaning it needs a separate tuner AKA set top box.
You need to get the cable box, plug in the component video cables into your TV (usually provided) and plug in audio cables and you're viewing HDTV. See below:
Happy Viewing!
Regards,
Mikeywaf
Posted on May 17, 2011
Testimonial: "Thanks"
Can not tune tv since change over
The KV-32FS100 only has an analog tuner (NTSC). Unless there is a low-power analog station still broadcasting in your area, you will not be able to watch OTA stations. (I've got one in my area that barely comes in.) If your local cable still sends an analog signal, you won't need a set top box to watch that subscribed service.
Otherwise, you need a set top box to watch TV. A digital to analog converter (the boxes that were available with the government coupon before the switch over) will give you over the air stations. The basic models only provide SD output; there are a few HD models available. Otherwise, you can use a satellite reciever, cable box (for digital cable service), or something like the Boxee or Sling with tuner. (There are a few different models of the Boxee; one added a tuner with a USB dongle. The newest model of the Boxee has the ATSC tuner built in.)
Note: OTA digital signal quality is either a strong enough signal for the tuner or no signal will be present. You need to point the antenna in the correct direction to receive the signal from your local transmitters. The type of antenna and its placement will also change the number of watchable channels. You can use antennaweb.org or tvfool.com to get more information. Antennaweb assumes an outdoor antenna but gives a conservative list of stations. If the signal is split to several devices, you may need an amplifier to get a watchable signal. (Sometimes amplifiers fail and you won't receive any stations, so test without the splitter or amplifier by using a direct cable to one TV.)
I hope this helps.
Oct 26, 2012 | Sony FD Trinitron WEGA KV-32FS100 32" TV
I don't have signal on my tv and there are no program's to watch as they are all blank. Is just a brand new tv I bought like 2 days ago
What make and model of TV do you have? What is your signal source (OTA (indoor or outdoor antenna), cable, satellite)? How is the TV connected to the source?
The model is important since some "TVs" are actually only monitors and do not have tuners. Then you need to connect to a set top box to watch anything.
Assuming the TV has an ATSC (digital) tuner for OTA, check that your antenna is pointed in the correct direction for the stations in your area. Use antennaweb.org or tvfool.com to identify the direction. Antennaweb assumes an external antenna and gives a very conservative list of stations. TVfool tells you the type of antenna needed to get any station (assuming no trees or tall buildings that might block the signal). Depending on your TV, you will need to enter the menu in order to correctly set the incoming signal type and scan for channels. Digital signals are either enough for the tuner to interpret or not available. If your signal is split between several TVs you may need an amplifier to get enough signal. Sometimes, the amplifier may fail and filter out all stations in certain frequencies. (Older TVs often only had a NTSC tuner; there are very few NTSC stations still broadcasting. They are low-power and thus you may not be able to watch them if they are far away.)
If you have cable without a box, which type of cable signal is coming in? Digital cable is QAM and not all TVs have a clearQAM tuner (that reads the unencrypted signal).
If you are using a set top box, make sure to set the TV to the correct input (HDMI, component video, composite video, coax and the correct number if there are multiple inputs). Make sure that the box is also on. If the set top box requires the TV to be set to a specific channel (3,4,60), make sure to go to that channel.
I hope this helps.
(For the US, the digital OTA tuner is ATSC and QAM for cable. In other countries, different signal formats are used.)
Oct 22, 2012 | Televison & Video
I have a RCA D52W20 rear projection HDTV. This TV was purchased in2005. I cancelled my cable and I just hooked up a digital antenna but the TV isn't finding any channels. What do I need to do? I was...
HDTV indicates the number of lines that are shown by the TV. (HD means that at least 720 lines can be displayed in a given picture.) To receive OTA signals, you need an ATSC tuner (digital) of sufficient power (with a clear path to the transmitter) these days. The RCA D52W20 was released in 2002 and only has an NTSC (analog tuner). You will need a digital-to-analog converter to receive OTA TV (unless any low power analog stations remain in your area).
Please note that the basic digital-to-analog converters that were available with the government coupon back in 2009 were SD (480i lines of pixels used) units. HD d-t-a converters exist but are more expensive.
I hope this helps.
(the phrase "digital antenna" is meaningless; check with tvfool.com or antennaweb.org for the direction of local transmitters. TVfool.com will give more information on the type of antenna (indoor, outdoor, amplifier) that you will need to receive channels in your area. Antennaweb assumes an external antenna but is very conservative in the stations that it will indicate that you can receive. Antennas are given a color rating based on how far away the transmitter can be to get a watchable signal. Since digital signals are either enough for the tuner to interpret or you get a "no signal" message, you often need a stronger signal than was needed to receive a watchable analog channel.)
Sep 27, 2011 | RCA Televison & Video
Does my tv have a built in tuner? its a 2003 model#D52W20 AND CAN I ORDER THE MANUAL FOR IT?
Yes ,this set has built in tuner,located on the SSB board next to the Deflection board.
Bottom 2 chassis onthe right is the deflection and on the left is the ssb board and right behind ssb board is the AC power supply board.
You can ship these boards for repair if you are unable to Fix it yourself.
PTS 1-800-844-7871
UED 1-800-648-6657
Retrevo.com For Manual
Encompass Parts might have service manual 1-800-638-3328
Jul 21, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have an RCA HDTV 52" Rear Projection tv.. do
No they do not have digital tuners inside them. They are meant to be monitors to converter boxes, cable boxes, and satellite television receivers.
Jul 19, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a Jensen TV, Model Number TS2050J. I need to know if it has a QAM tuner built in.
Hi.
No, your tv is an older model sdtv with an analog only NTSC tuner.
Newer model have an ATSC/Qam digital tuner, but not your model.
This means that if you want to watch tv, you'll have to get a converter box. It will have the ATSC/QAM tuner i it, and it converts the signal into lower definition NTSC, and then sends it to the tv through either coax cable, or rca cables.
Once in a great while you might even find one that has s-video output, but those usually are expensive.
I hope this helps you out.
Feb 08, 2011 | Jensen TS2050J 20" TV
Do I need a digital convertor box to get the DTV signals or just the antenna?
You will need a digital-to-analog converter box and an antenna. The TV only has an NTSC (analog) tuner.
I hope this helps.
Oct 01, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
So you are telling me I need a digital converter for this TV to g
Who was not watching the months of public service announcements? You need a Digital-to-Analog (ATSC-to-NTSC) converter box to receive over-the-air (OTA) signals in most parts of the country. You do not need one for most cable and satellite box outputs--they are NTSC or HDMI. Some low-power, typically religious, stations are still analog. Note OTA may be high definition (HD) or standard resolution (SD) but will be digital.
To get HD on your HD set you must have OTA (HD TV tuner, not converter), cable (QAM TV receiver), satellite (HDMI or 5-wire RCA),or Blu-Ray with HDMI or RCA.
-Ken
Aug 18, 2009 | Hitachi 46F510 46" Projection HDTV
Configuring I/O cable box, VCR, DVD.
Unfortunately you would need a second digital cable tuner to do what you are trying to do.
The digital tuner only outputs one channel at a time, selected by that box, so you can only record or watch that one channel at a time.
Many people are switching to dual tuner DVR's to cure this dilemma.
Feb 17, 2008 | Televison & Video
RCA 52" tv. model # D52W20
The silver box is called the TUNER. Call an RCA distributor, such as Union Electronics or Herman-Panson and order it by description by asking for the tuner for your model number. Have the location number on the board, just in case.
Sep 01, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
323 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
