Question about Philips Pocket Memo 9500 (256 MB 1 Hours) Handheld Digital Voice Recorder
Phillips Digital Pocket Memo 9500 died. Won't work even when plugged in.
    President:
  • 1,961 Answers
Hello!
Does the green LED indicator lamp illuminates when you insert the Pocket Memo in the docking slot during recharging?
When the green indicator lamp do not lit when the pocket memo is inserted at the docking slot, then it means that terminal of Pocket Memo can not connect properly with docking station terminal.
If the green indicator lamp illuminates and after a few hours the Pocket Memo did work when turn on, then, it could be a faulty battery. You may try other rechargeable battery or non rechargeable alkaline battery for testing,
Posted on May 17, 2011
Where to send pocket mmo recorder for repair?
Roach Reid Office Systems 2737 Gilchrist rd Akron Ohio 44305 ATTN Mark
Aug 23, 2014 | Philips LFH9500 Pocket Memo Digital...
Philips device won't recognize when docked.
Remove cable from the docking station and plug it directly in to the LFH9600
dictaphone if the system communicated it is possible that the docking station is bad.
Jul 17, 2012 | Philips LFH9600 Digital Pocket Memo with...
Driver for Philips Pocket Memo 9300
Hi, fortunatley I found the old setup/installation-disk! Download and enjoy!!! Gunter
https://dl.dropboxusercontent.com/u/6605634/philipsLFH9300.zip
Nov 26, 2011 | Philips Pocket Memo 9300 Handheld Digital...
Phillips Pocket Memo 381 The button you press in when recording will not press in! Any ideas tThe machine plays back tapes OK
You cannot push it in without a recordable tape in the unit. The mini cassette tapes have a removable erase prevention tab on each side in the front. If removed, you cannot push record. Try another tape. Otherwise the recorder needs repair.
Aug 16, 2011 | Philips Pocket Memo 381 Handheld Cassette...
Cannot run philips LFH9398 pocket memo on my mac
the philips models are not MAC compatible. However, they normally show up as a folder and you can copy files.
Apr 29, 2011 | Philips Pocket Memo 9360 Handheld Digital...
Our 9500 series Philips digital pocket memo will not clear the old files when complete. As a result, we are unable to download new files. Any help would be appreciated. Thanks! Jill
Hello You need to Use Philips SpeechExec software for automatic
download, conversion and routing of files
recorded with a Pocket Memo dictation
recorder. How and which files are downloaded after a
recorder is connected can be configured in
the settings menu of SpeechExec or with the Configuration Wizard
Configure the download process
from the Pocket Memo
Pocket Memo is connected can be configured in
the settings menu or the Configuration Wizard.
1 Connect the Digital Pocket Memo to the PC
using the USB cable.
2 Click Settings > General Settings on the
menu bar, select DPM/DT Configuration >
DPM Settings from the list on the left side.
3 Click the Start... button. The DPM configuration
dialog is displayed in a new window.
4 Select Download in the left pane.
5 Select which files will be downloaded
(download file type):
• All files
• EOL (recordings marked as finished/endof-
letter)
• File selection (SpeechExec prompts the
selection of specific files to be downloaded)
• File with keyword 1 (specify a keyword)
6 The download settings also allow the user
to specify if files will be deleted on the
Pocket Memo after they are downloaded.
7 Click OK to save the settings and confirm
the transfer of the new settings to the
Pocket Memo.
Apr 05, 2011 | Philips Pocket Memo 9500 (256 MB 1 Hours)...
Where is the on/off switch for teh Philips 9350 pocket memo
Move teh 4-position switch to the stop position and push back the movable center part of the cap.This locks the 4-position switch and the device switches off.
MANUAL
Sep 29, 2010 | Philips Pocket Memo LFH9350 Digital Voice...
Phillips 281 pocket memo
Go to www.dicatation.philips.com and download manual for model 381. It works exactly the same.
Mar 02, 2009 | Philips Pocket Memo 281 Handheld Cassette...
Philips Pocket Memo 9500 (256 MB 1 Hours) Handheld Digital Voice Recorder Logo
280 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
