Question about Minolta bizhub 200 All-In-One Printer
How do you kill an incoming fax? We have a 244 page incoming fax of garbled syntax and font and want to kill the printing.
    Guru:
  • 1,481 Answers
Simple......... pull the plug....shut it down....sit and wait for the **** to get over
Posted on May 17, 2011
  • mneu989 May 17, 2011
    One might think the old power cycle routine would fix it, but it doesn't. It's loaded in memory and we can't dump the print job.
How to change print size
Assuming you're referring to the print size of the fonts - letters ..... or the size of the printed page ...
If you're printing from your computer, you'll need to change the size of the font (to a larger font size) on your document before you print, or adjust the print Properties ... to fit to page, or magnify the size of a small document ...
If you're printing a pdf file, you can specify the size of the document using the enlarge (%) before you send it to the printer
Jan 15, 2014 | Epson WorkForce WF-2530 All-in-One...
My fax machine is in auto print off mode how do i switch it to auto recieve mode
Hi; Receiving to Memory Temporarily You can enable memory receiving feature temporarily. Received faxes will not be printed automatically.
  1. Press [ON/OFF] to select <AUTO PRINT OFF>.
  2. ??? The fax starts receiving documents in memory.
  3. ??? To cancel, press [ON/OFF] again.
  4. ??? When <AUTO PRINT OFF> is cancelled, received faxes will be printed automatically.
good luck
Oct 15, 2010 | Canon FAX-JX200
Hello! How to program automatic reception of a fax after 4 calls (at the weekends, when at office anybody isn't present. Thank you. Best regards, Veronika
hi; Receiving Both Documents and Telephone Calls Automatically: Fax/Tel Mode If you set Fax/Tel mode, you can control precisely how the fax handles incoming calls by adjusting the following settings: ??? Adjust the time the fax takes to check whether a call is from a fax machine or a telephone (<RING START TIME> setting). ??? Adjust the length of time the fax rings when the call is a voice call (<TEL RING TIME> setting). ??? Set whether the fax switches to receive mode after the ring time set in <TEL RING TIME> has elapsed (<DEFAULT ACTION> setting). 1 Press [Menu]. 2 Use [{] or [}] to select <DATA REGSTRATION>, then press [Start/Copy]. The LCD displays <USER SETTINGS>. 3 Use [{] or [}] to select <RX SETTINGS>, then press [Start/Copy]. The LCD displays <ECM RX>. 4 Use [{] or [}] to select <FAX/TEL AUTO SW>, then press [Start/Copy]. The LCD displays <RING START TIME>. 5 Press [Start/Copy]. 6 Use the numeric buttons, or [{] or [}] to enter the time the fax waits before ringing when it receives a call, then press [Start/Copy] twice. 7 Use the numeric buttons, or [{] or [}] to enter the time the fax rings while waiting for someone to pick up the Handset, then press [Start/Copy] twice. The LCD displays <RECEIVE>. Note ??? If paper jams, see "Troubleshooting" on page 53. ??? If the Ink Lamp lights up faxes will be received to memory. 8SEC. 22SEC. Use [{] or [}] to select <RECEIVE> or <DISCONNECT>, then press [Start/Copy]. This setting tells the fax what to do if the Handset is not picked up within the specified ring time set in step 6. 9 Press [Stop]. Setting ends and the fax returns to standby mode.
Oct 14, 2010 | Canon FAX-JX200
I'm getting an error 244 or 223 when receiving a fax. the fax only partially prints out
Error 244:
Definitions
  • The user of the remote machine pressed the Stop key, causing the session to be prematurely terminated.
  • The remote fax machine determined that there was a feature incompatibility between the two machines and terminated the session. For example, the local machine wanted to initiate polling, but the remote machine did not support this mode of operation.
Solutions
  • Make sure that the remote machine can accept and use polling.
  • Select a slower reception speed.
Error 223:
Definition
The local machine was unable to receive an entire page even after multiple attempts to receive the parts of the page that contain errors. This situation is usually due to extremely poor line conditions.
Solutions
  • Try to receive the fax at a different time when telephone line conditions have improved
Mar 05, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
HP laserjet 1020 fax incoming fax, machine
hp laserjet is not a fax.It is only a printer.
Dec 09, 2009 | HP LaserJet 1020 Printer
Incoming faxes from multiple locations jamming our machine
I believe there should be a "Clear memory", or "dump fax Memory", in the menu selection.
Press reports and scroll to machine print out. You should get a print out on the machines configuration and help menu to better assist you.
This should dump the memory so you can prepare yourself for new incoming faxex.
Dec 08, 2008 | Xerox FaxCentre F116 Plain Paper Laser
BROTHER MFC 425 CN
Power it off!
Then goto start>printers&faxes choose the printer that is printing, in the new box that appears click 'document' then select 'cancel'
Normally if the printer was left on it would continue printing several more pages, as these have already been cached in the memory, switching off the printer for a while clears this.
Are you using fax software? Are you not able to limit the amount of pages to be printed? or at least be able to reject an incoming fax that exceeds a set number of pages?
Aug 11, 2008 | Brother MFC-425CN Multi-Function Center...
Light print of incoming faxes, cannot read
are copies light too? if not then it is sending fax, but most times it is inferior ink or drum causing the problem sometimes damp paper (try printing on reverse side as well)
Oct 31, 2007 | Brother IntelliFAX 2600 Fax
Minolta bizhub 200 All-In-One Printer Logo
106 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
