Question about Kodak Carousel 4600 Slide Projector
How do I properly install the carousel? It's not advancing I think it's not on properly.
  • 2,510 Answers
It is a while since I have handled one, but as I remember, you have to line up the number 1 slide position with the slot in the projector and then it clips into place with a little pressure.
Posted on May 17, 2011
Kodak 850 Carousel Projector tray won't advance
The Carousel 850 is 40-45 years old. The symptoms you describe indicate the timing is off. Timing is an "adjust & test"..... try a SMALL adjustment and then test it.... adjust again & test again. Repeat until you get smooth tray action. See the attached illustration:
May 16, 2013 | Kodak CAROUSEL 850 KODAK
Carousel stopped turning
see this causes and fix it. God bless you
ough the carousel is usually driven by a small motor that's unrelated to the heating function of the microwave, the microwave cabinet needs to be opened to repair it. So we recommend that you seek the assistance of a qualified appliance repair technician. Inspect the plastic drive coupling that the tray sits on, as well as the ring-and-roller assembly, to make sure that they're working properly
Sep 24, 2012 | Tappan Microwave Ovens
Carousel doesn't work
Try re-timing the mechanism. It is probably a tooth out.
Jul 11, 2017 | Denon DVM-1800 DVD Player
Why doesn't the slides advance?
I can only guess, but it is most likely caused by a worn or mis-adjusted cycle contact. I have attached an illustration to show you the proper orientation of the cycle contact. Good Luck !! Jim7390f9e7-725d-4085-9769-5537112e57b1.jpg
Aug 10, 2011 | Kodak Ektagraphic III-E-Plus 35mm 140...
My Kodak Carousel 650H has a stuck slide and the tray won't move. The stuck slide is lined up with the "gate index." I tried releasing the tray but only one side of the tray releases. The...
Two steps.
1) Look down into the center of the carousel. There should be a round, flat silver knob with an elongated notch in it. Take a coin (US 5-cent piece or similar) and use it to turn the knob. This releases the catch on the metal plate under the projector. You should then be able to lift the carousel off. Be careful: some slides will fall out as the slot is not aligned with the carousel body properly once you do this.
2) Make sure the locking ring on top of the carousel is in place (or else take out all your slides. Turn the carousel over and gently rotate the metal plate covering the bottom of the carousel into position. You will hear/feel a "click" when it's in place.
The projector may have jammed because there are two slides stuck in the viewing slot--check for this before you put the carousel back on the projector. If it jams a lot the metal plate under the carousel may be bent.
Jul 17, 2011 | Kodak Carousel 4600 Slide Projector
The ink cartridge carousel is jammed. Is there a clutch release to spin it manually? I think one of the ink cartridges is not installed properly and is hanging up on something.
Power off.
Open top cover
press the end of a paper clip into the guide which is left of the operator panel and below the right side hinge.
Rotate the carousel manually.
Be Careful. This must be done with power off.
Feb 23, 2011 | HP LaserJet 2550Ln Printer
Removed carousel midway by lifting release as a slide fell down,
With the tray removed, cycle the projector in Reverse button 5-6 times. If it is just a mechanism jam from removing the tray mid-cycle, this will cure it. To set the tray back to Zero, FIRST make sure the locking ring is in place and tight on the top of the tray. Then turn the tray upside down & release the latch and rotate the bottom plate back to it's home (Zero) location.
Apr 26, 2010 | Kodak Carousel 4600 Slide Projector
I just purchased an older Kodak slide projector with a carousel on top. Everything works fine but the carousel won't advance. When you click the next button, the plastic arm that should advance the...
By the sounds of your description, your projector needs an adjustment to the slide change mechanism. This is best done by a factory-trained dealer, who has the service manual. Sorry I can't be of more help. Happy New Year!
Nov 14, 2009 | Kodak Carousel 5600 Slide Projector
Have an HP 2820. The carousel on this will not turn. It originally had an issue where you could drop three toners in and they would place correctly until you got to the fourth and it would not drop all...
HI,
Open the top cover of printer and try to clean up the carousel motor solenoid clutch. There are one foam tape - cean or better replace it.
hp2820-oxw21mgdz5ogf1oadn2pd4nf-3-0.jpeg clean or better replace foam tape. (It is just for make less noise.)
hp2820_2-oxw21mgdz5ogf1oadn2pd4nf-3-2.jpeg After that control carousel home position left and right gear home position marks must have same position.
Mar 26, 2017 | HP LaserJet 2820 Printer
Kodak Carousel 760H wont advance or reverse
You have jammed the slide change mechanism. Turn the projector off. Remove the tray using the emergency release slot in the center hub of the projector. Turn the projector on and cycle it a few times in reverse, then in forward. That usually clears a mechanism jam.
Nov 23, 2008 | Kodak Carousel 4600 Slide Projector
Kodak Carousel 4600 Slide Projector Logo
91 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
