Question about Dell 5210n Laser Printer
The printer displays a message of 922.02 Service Fuser Error and it will not print. How do I fix this?
jaylex
  • 417 Answers
SOURCE: dell laser printer m5200: 922 service fuser error
The fuser is not warming up replace fuser.
Thanks J
Posted on Jan 19, 2008
  • 13433 Answers
SOURCE: Lexmark E342n Laser Printer Fuser Error
920 Fuser Error
Indicates that the fuser is below temperature when printing
Do a Fuser Service Check
Posted on Jun 26, 2008
  • 300 Answers
SOURCE: I have a Lexmark X422 It
This means Fuser failed to reach
standby temperature.
The only answer is to replace the fuser, part number 56P0648 110 VOLTS, 56P0671 220 VOLTS.
Please advise if you require instructions
Posted on Aug 04, 2008
SOURCE: Fuser Error
bought a new HP printer!
Posted on Nov 05, 2008
  • 3 Answers
SOURCE: Lexmark T642 Laser Printer error message922 02
Service fuser error requires a maintenance kit, this is approx $1000 + installed, if this is new, I would be taking it back because it shouldnt have this error. You possibly might be able tto fix it by replacing the fan in the back but thats only worked for me in approx 1 out of every 10 times.
Posted on Jan 30, 2009
My HP LaserJet printer 5200dtn is displaying error message "50.3 Fuser error" what is the solution to this problem because I can't print
50.3 means the fuser is getting too hot. It will either be a problem with the thermistor in the fuser or the power supply. If you can find a another fuser to test with you can answer the question pretty quickly.
Mar 02, 2015 | HP LaserJet 5200dtn Printer
Replace fuser E error
Reset Fuser counter Oki B6200 Action: Power on and wait until the ready to print message appears on the operator panel. Press "Select and the Down arrow button at the same time" The following Menu is displayed"Reset Counter Fuser U4" Press the right arrow button Operator Panel will display "Fuser U4 Use the SEL to Reset" Press the SELECT Button Operator Panel will read "Clearing" Press the Menu key to return to "Ready to Print Mode"
Apr 05, 2010 | OKI B6200 Laser Printer
I have a Lexmark E450dn displaying a "935.15 Service Printhead" error message and will not print. Seeing as Laser Printers do not have printheads, instead they have Scanners and Fusers, which should I be...
a 935 printhead error is a fatal error which means the scanner motor has failed to initialize. the term printhead is short for printhead scanner. this error can be caused by either the engine board or the scanner % wise 40%engine board 60% scanner ive done 120 repairs on lexmark laser for the last 7 years trust me one of these is the problem
Jun 16, 2009 | Lexmark E450dn Laser Printer
Getting error message when trying to print
"Fuser Error", needs to be reset in service mode, after the fault is fixed. could be heater lamp, fuse, thermostat, etc.
Mar 30, 2009 | Ricoh Aficio AP2600N Laser Printer
Kyocera FS-1920 error message: "call service 6400:0295998"
Your drum unit is not seated correctly. Look inside for a bent drum ground clip.
Oct 19, 2008 | Kyocera Mita FS-1920 Laser Printer
920 Fuser Error
Jun 26, 2008 | Lexmark E342n Laser Printer
Hello
A 50 Service error is a fuser error. Turn the printer off for at least 10 minutes, then turn it back on. If the error is still there, you can try reseating the fuser, but be sure to let the fuser cool completely before touching it.
If you still have the 50 Service error after reseating the fuser, you might need a new fuser.
You can access the fuser by opening the rear door. It's located directly above the paper tray. There are two screws that hold it in place. Remove those two screws, and the fuser slides outs.
Hope this helps.
Mar 20, 2008 | HP LaserJet 4 plus Printer
Sc error 380 and fuser breakdown
Hi there you will need to replace the development motor but first try the following.
Entering the Service Mode
There are two ways to enter the service mode.
Method 1: Turn the machine on while pressing the “On Line” key and “Escape” key
together until the above message in the illustration appears on the display.
NOTE: If you switch the machine off, any jobs stored on the hard disk using the
sample print and protected print features will be deleted.
Check first with the user tools to see if there are any jobs stored with these
features
(Menu key - Sample Print, or Protected Print).
Method 2: Press the “Up/Down arrow” keys together for about 5 seconds, then
press the “Enter” key.
The above message shown in the illustration appears on the display.
NOTE: The machine automatically goes off line when you enter the service mode.
Using the up down arrows select Engine and enter by pressing enter or # key.
Using the up down arrows select mode 5 then enter using enter or # key then select 810 (SC reset) press enter then if you want to select 809 (SC Detection ON/OFF) Enter and select 1 to disable. Escape or return key all the way out and exit. Turn the machine off then on again and test if the same problem then replace the Dev unit if still having the problem then replacement of the motor likely. I can email you the complete service manual if you like.
Thanks J
Jan 19, 2008 | Ricoh Aficio AP3800C Laser Printer
Fuser unit breakdown error sc380
features
Thanks J
Printer HP ColorLaserJet displays Fuser Error
My HP Color Laserjet 2600n Printer is giving me error as
" 50.2 Fuser error " . then every time i have to reatart my printer.
please give me suggestion.
thanks and regards.
ajinmumbai
Dec 05, 2007 | HP Color LaserJet 2600n Printer
Dell 5210n Laser Printer Logo
157 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
