My sky plus box is linked to my samsung lcd tv and the no signal message keps appearing - is there a problem in my area - postcode GUI6 6PU?
  • 157 Answers
Helo sir
Posted on Aug 14, 2008
  • John Smith
    John Smith Aug 14, 2008
    yes seems to be a problem from ur provider. Give them a call and they may have to reset your connection
Where can I find an online copy of the Sky+HD box "User Guide" please
Click the following link or cut and paste it into your browser:-
http://www.sky.com/helpcentre/export/sites/www.sky.com/helpcentre/tv/anytime-plus/__Content/hd_manual.pdf_1314843347.pdf
I've assumed you're asking about the regular Sky+ HD box and not the Sky+ HD 1TB box, if I'm wrong then use the next link:-
http://www.sky.com/helpcentre/export/sites/www.sky.com/helpcentre/tv/anytime-plus/__Content/1TB_Manual.pdf_1314843347.pdf
I hope that my free answer has been prompt and helpful, if so then please take a brief moment to rate my reply.
Mar 07, 2011 | Televison & Video
I have a Bose 3.2.1. GSX Series 3 system. Recently, when playing DVD's I am getting sound only and a message on the TV screen saying 'No Signal' and on the 3.2.1. display 'communicating with your TV'....
Possible faulty lead or a poor connection. Has the new Sky Box been fitted to the HDMI socket the Bose had? Try switching sockets if there is more than one HDMI socket.
Jun 02, 2017 | Bose 321GS Series II System
Sky is saying there is no signal. Turn box off and on again. I have done this but still get no signal. I have freeview only channels on my sky box
Firstly, you don't get Freeview through your Sky box. If you are watching Freeview channels then it's from an aerial connection. If you are getting a 'No signal' message on your TV, the first things to check are:
1. Check that you have selected the correct input source on your TV. If you are using a 'co-ax' connection (standard aerial cable) you will have to select this manually from the remote. If you are using a SCART connection, all you need to do is turn the Sky box off and back on - but you've done this already.
2. Check the connection from your Sky box to your TV - disconnect it, check that the cable and connectors aren't damaged then re-connect it.
3. Check the cable between the dish and the Sky box. Unplug this from the Sky box and reconnect it.
4. Check that your viewing card is correctly inserted. This is unlikely to be the problem as it doesn't usually result in a 'no signal' message, but remove it and re-insert it anyway.
Finally, it's very windy tonight and this can affect the Sky signal if your Sky dish isn't properly secured. It's possible that your dish has been moved by the wind and is no longer aligned with the satellite. If none of the above work, you should inspect the dish as soon as conditions are safe enough to do so. If you can move it by hand, it can probably be moved by the wind.
Try these tests and post back and I will try to assist further if the problem has not been resolved.
Regards,
BElectric
If your problem has been solved, please be generous and award this solution 4 thumbs-up. This service has been provided FREE - your simple acknowledgement is appreciated. Thanks.
Nov 09, 2010 | Televison & Video
Within the last two days I have lost the signal for ITV1 4 & 5 tried retuning but no signal received, my Postcode is BD20 9AL
Have you tried a complete reset of the TV, since the switchover date in some areas, transmiters have changed too. ry this ad let me know.
Good Luck
Stuart
Jan 12, 2010 | Samsung LN32A330 32 in. LCD TV
Lost ITV channels and C4
I think you need to get Sky because it will give you 100% coverage of all terrestrial channels. You may need to retune the television otherwise just get sky
Dec 31, 2008 | LG 32LX1D 32 in. LCD Television
Connections for DVD Recorder/LCD TV/ SKY PLUS
Connect the AV output of the Sky box to the AV input of the Panasonic combo.Look at rear of the Combo and you will observe input and output RCA connections.Using RCA leads, hookup the Av output of the Panasonic to the audio/video input of the Sony tv. Power up Appliances, and you should be OK.
Apr 11, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Samsung LE R88 BD LCD TV / digibox problem
Hi.
Its a long shot but try this,
It can cause problems when you switch set to & from stand bye.
Check that you are viewing a digital TV channel
Enter the menu and navigate to:
Setup > System > Software Upgrade > Standby Mode upgrade
Change the setting to Off.
I cant gteee that this will sort your problem out so post here if it doesnt & I will check samsung data base.
http://dysonmanuals.llc.nu/
Chris..
Jan 08, 2008 | Televison & Video
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
