does the printhead assembly move at all? try taking off the ribbon and moving it by hand with the power disconnected. try moving it to the right hand side before turning it back on, if it does not go all the way back to the left again try to find what is jamming it.
In my own experience, Okidata printers have a nasty habit of collecting a lot of paper dust. To start out, I would suggest a really good cleaning, with no paper in the machine, with a can of compressed air. If that does not solve your problem, you might have to replace your feed wheel assembly. Hope this helps!
First, make sure that paper feed switch is set accordingly to the paper path you are using (rear feed, bottom feed or friction). If you make a change, turn the unit off and on.
If it is set correctly, there might be an obstruction on the printer top cover that interferes with the cover sensors. This forces the printer to think that the lid is still open and will signal it as you have described.
The last option will be a damage to the sensors or to the mainboard. This is rare, but if the case, you need a repair center.
We swapped out the printer for another one we had in the office that was working. The new printer also got the alarm light. From that we concluded that it was a bad serial card. We swapped the serial card from another printer, and the original printer started working perfectly. Now we just need to find out where we can purchase another serial card, as we have no more 'spares' around here.
i have a same problem
