Question about Maytag MAH9700AWM Neptune Front Load Washer
E3 and be error on maytag washer - Maytag MAH9700AWM Neptune Front Load Washer
  • 17,970 Answers
E3 error code is indicating that the motor should be running but the hall sensor for the motor is not sensing the turning of the motor.
If the error code comes up all the time as soon as you press the power on button, then it means your control board is bad and reading incorrectly. If it only happens during a cycle, then you need a new motor unfortunately.
Note - You could disconnect the power supply for few minutes, say 15 minutes and see if that resets the control board and solve the problem unless follow what was mentioned above.
For replacement instructions you can download this repair manual for your front load and follow the steps given in the manual and here the search parts.
Hope helps.
Posted on May 17, 2011
  • 3 Answers
SOURCE: ERROR CODE E3
Here is what it says in Maytag's Technical Info Guide: Machine control is
attempting to drive the
motor but is not seeing any
tach response. Visual
check shows motor is not
moving. (Locked, Hall
Sensor fault)
Here is the web site for the guide:
http://www.servicematters.com/maytag_library/docs/16026736.pdf
Try this: take off the back panel and check the motor connections. Unplug them and look for any corrsion.
Hope this helps.
Posted on Jun 16, 2008
SOURCE: what is e3 error on
Why e3 fault message in samsung front loading machine
Posted on Sep 21, 2009
  • 34 Answers
SOURCE: e3 keeps poping up
Hello leggettelect,
The e3 code has to do with the Hall Sensor. This is a sensor that looks at motor RPM. There have been some issues with the wire harness or the harness connectors being loose. You can also get the code if the sensor itself is loose and cant read the motor RPM. Here is a link to a tech bulletin from Maytag explaining it in more detail and has some pictures so you can see what to check. Hope this will fix your problem.
http://www.servicematters.com/maytag_library/docs/TDL-0078A-B.pdf
Thanks,
edgin96
Posted on May 13, 2009
techbuster
  • 5081 Answers
SOURCE: maytag neptune washer will not get up to speed in
E3 means that the control board is detecting current going to the motor, but the motor won't turn properly. If the error code somes up all the time as soon as you press the power on button, then it means your control board is bad and reading incorrectly. If it only happens during a cycle, then you need a new motor unfortunately.
Posted on Jun 09, 2010
richroth
  • 9472 Answers
SOURCE: hello, i have a maytag
The Machine control is attempting to drive the motor but is not seeing any tachometer response or motor action. It could have a failed tachometer/hall sensor which is part of the motor, failed motor or machine control. It could be a loose wire connection at the motor or at the machine control board.
Posted on Apr 21, 2011
What does the E3 code mean on the 540 model and is there a fix?
Troubleshooting the "E3" error code in Maytag MAH6700 ...
fixitnow.com/.../troubleshooting-the-e3-error-code-in-maytag-mah6700-...
Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
I have a samsung frontload washing machine. A code E3 is ...
www.shopyourway.com > Denise LaGrasse > Questions
Mar 15, 2014 - My samsung front loader is not working. do not no what E3 means. ...code F26 mean on a Kenmore Elite model 110.4708 washing machine?
How To Fix 3E Error Code On A Samsung Washing Machine
www.appliancerepairlesson.com/.../how-to-fix-3e-error-code-on-a-samsu...
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
Jan 06, 2016 | Washing Machines
MY MAYTAG NEPTUNE FRONT LOADER WASHER KEEPS SHUTTING OFF AND THE E3 ERROR MESSAGE IS ON THERE
Transmission or clutch assembly not engaging due to going out or slipping. even bad door switch
Sep 20, 2014 | Maytag Washing Machines
I have a maytag fav6800awq it has an e3 fault code what does this mean?
Never see the e3 error code
Service Manual for the FAV6800A/FAV9800A page 13 Google ""16022808.pdf"" to find.
error codes start on page 13. Any other info on the failure. Do you know what part of the machine wash cycle you were in with this error code.
Aug 24, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag laundry neptune front loader washer MAH6700AWW. It is showing a E3 code error. what can we do for that
Hi, the E3 error means that the control board is detecting current going to the motor, but the motor won't turn properly. If the error code comes up all the time as soon as you press the power on button, then it means your control board is bad and reading incorrectly. If it only happens during a cycle, then you need a new motor unfortunately.
Jun 16, 2011 | Maytag MAH6700AWW Neptune Front-Load...
E3 error code will not wash, what does this error code mean?
i have a maytag washer and it says E3 and it will not work,does anyone know what that means please let me know...thanks
Apr 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
509 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
