Question about Maytag Neptune MDG9700A Gas Dryer
I had my Daughters Bra in it and it caught somewhere and now the drum doesn't turn. I am thinking that since it ripped the bra to **** maybe a pce of it is caught in the drum runner. When I tried to mannually turn it in on position ...something clicked and now it doesn't turn at all...please advise...I have taken dryers apart before to repair the Teflon guides.
    Master:
    Sergeant:
  • 385 Answers
When you turned it mannualy it probably popped the belt off the pulley.Also if it was a bra with a metal stay check to see that they are both still in the bra. Hope this helped.
Posted on May 17, 2011
The washer just started making this real loud high pitched noise while running the spin cycle?
have u lost a bra wire ?? it could be caught under drum or your bearings are gone in drum ... turn drum by hand it should run smooth .
Feb 27, 2011 | Whirlpool Washing Machines
Clicking noise during wash run
Assume if you hand turn the drum noise still ,present could be bra/wire caught in the drum further advice needed....
Jan 22, 2011 | GE Washing Machines
How do I remove a piece of metal from bra which has got stuck under the insiden cylinder and drum
it completely has to be pulled apart and once you have done that you will probably find the bra wire while spinning around has ripped into the plastic outer tank so bad it will now leak and have to be replaced & this is the most expensive job to have done it sounds silly for a bra wire but you should honestly consider buying a new machine it often ends up cheaper to do so rather than spending 3/4's of the price of a new one fixing your one.
Jan 12, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bra wire caught in back of tumble dryer drum
We got a bra wire stuck in ours it actually went through the tiny holes at the back and bridged the earth and live on the heater coils, and the rcd kicked in to cut it out before it could of caught fire. Never in a millions year would you think that could happen !
Jul 25, 2009 | AEG Dryers
Indesit 1600 WIE167 washing machine
locate element and remove you should then be able to remove bra wire they normally get caught around element
Jul 01, 2009 | Washing Machines
Bra wire stuck somewhere in machine
You will not see it as it is trapped between the inner and outer drum, what you need to do is remove rear panel and the large hose from the pump to the bottom of the drum,
Then reach in with your fingers and see if you can feel it , if you can't then short of removing the drum (not recommended) ther is not a lot you can do, hopefully it will find it's way into the filter, where it wiil not be a problem
Plz rate this solution.
Dec 15, 2008 | Washing Machines
Under wire from bra cuasing noise in dryer drum
I'm not sure we have enough information yet, but I do believe that the bra would be more comfortable in its relaxed state.
Jun 01, 2008 | Bosch Dryers
Intermmittent buzzing noise
IT COULD BE SOMETHING CAUGHT IN THE DRUM UNPLUG THE MAINS AND OPEN THE DOOR AND TURN THE DRUM BACK AND FORWARD YOU MAY BE ABLE TOPUT THE CAUSE EASIER LIKE WORN BEARINGS SOMETHING CAUGHT IN THE HEATER OR A BRA WIRE?
May 11, 2008 | Hotpoint Aquarius WD63 Front Load...
Bra wire gone inside drum!!!!!!
DLB POST!! SEE ANSWER below From old post Solution #1 posted on Jan 26, 2008 0%20stars.png
1ad4dee.jpg Master_Tech
Rank:guru_s.gif Guru
Rating: 85%, 47 votes
you will have to open the bottom of the unit there is a pump clean out and a hose to the tub you maybe able to get it from there REMOVING the tub is not an option at this point
Jan 26, 2008 | Washing Machines
Washing machine Drum rattles
It is probably between the clothes tub and the outer tub. To remove it from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub and try to remove the clothing through the port. Good luck
Aug 03, 2006 | AEG Lavamat W1050 Front Load Washer
Maytag Neptune MDG9700A Gas Dryer Logo
254 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
