I have a Noritz N o751-m heater where can I get a sequence of operation to troubleshoot it?
    Brigadier General:
  • 4,736 Answers
Here's a link to where you can download and print the Owners Manual. Your unit comes in 3 different configurations, so you'll have to chose the one that matches yours.
http://www.noritz.com/homeowners/products/view/nr98_n_0751m_series_residential_tankless_water_heater/
Hope this helped you. Please let me know. Thanks.
Posted on May 17, 2011
I have a Noritz tankless water heater (model n-132m). I am getting an error code of 71. What does that mean?
The Noritz Manual shows fixed for the following error codes:
11
21
90
99
For all other codes this is the recommendation:
Contact our sales agent if:
• Any other error code appears.
Sep 12, 2014 | Noritz Commerical Tankless Water Heater...
Heater starts when cold hose bib is opened and there is no cross over in the hot and cold pipes noritz
You are describing normal operation. Does it NOT work any other time? If so, go to your remote and hold in the up and down arrows at the same time and hit up until you find number 14. this shows the flow rate. your flow rate has to be above 005 in order for the unit to start. try running a bathtub. if this starts it the problem is your faucets not allowing enough water through them. if this doesn't start it then you probably DO have a cross connection and you just haven't found it yet. Especially if the unit is running but the water never gets hot. Either way, call Noritz for them to walk you through it and you'll get it working.
Oct 03, 2013 | Noritz Water Heaters
Vibrating when the heater starts to heat water
Things to Check:
1. incoming gas pressure (minimum 5" when unit firing)
2. Make sure damper on top of unit isn't sticking
3. check vent length and #elbows versus installation manual specs
4. if above 2000', disconnect high elevation termination
If these all check out, you'll probably need to do a manifold adjustment. Call Noritz for assitance on this.
Apr 09, 2011 | NORITZ Natural Gas Tankless Water Heater...
Can we change the orfice on our Noritz N-0751M natural gas to liguid propane?
There's a field conversion kit available. Contact Noritz to get more information.
Mar 30, 2011 | Noritz Residential Heaters Tankless Water...
Noritz Tankless error code 16
The trick with these hot water heaters is to keep the filter screen clean and flush the system with CLR periodically. Code 11 is ignition error. Is your gas valve turned on?
Oct 17, 2009 | Noritz 6.9 Gallon Residential Direct Vent...
Leaking Noritz water heater.... I have a Noritz N-069m water heater. When i purchased the unit 3 years ago, i was told that if i installed a water softner unit it would void the warranty. A year and a half...
Check your water pressure and the diagnostic codes on the controller to see if there is computer failure or another problem with the unit. send me an e mail i might be able to help im a nortiz certified service tech scott@bridgeplumbing.net
Jul 27, 2009 | Noritz 6.9 Gallon Residential Direct Vent...
What is error code 59 on a noritz tankless water heater lp?
The 59 code is typically caused by insufficient gas supply to the unit. It can also be caused by obstructed exhaust flow, stuck exhaust damper (located directly on top of the unit's exhaust), insufficient makeup air, or improperly installed venting (i.e. too long or too many elbows).
I would recommend initially checking the incoming gas pressure at the gas connection on the unit. The gas pressure should not drop below 5" water column for a natural gas unit, 8" for a propane system (the unit need to be operating at its maximum output).
Apr 29, 2009 | Noritz 7.1 Gpm Propane Lp Gas Tankless Hot...
Noritz tankless water heater not producing hot water
I called Noritz error code 16 is a overheat problem. Noritz say's to flush your coil with vinegar or CLR.
Use a small pump to recirculate the CLR or vinegar through the system for 45 minutes and flush with fresh water. This worked for me.
Jan 04, 2009 | Noritz 6.9 Gallon Residential Direct Vent...
Heating & Cooling Logo
50 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
