Question about Cuisinart DGB-600 Coffee Maker
The coffee does not go into the pot instead it pours all over our counter top and floor. This is very frustrating as my wife and I wake up early in the morning to clean up a mess and are not able to enjoy our coffee. We are very dissappointed as this was an expensive coffe maker, to our standards. I have made sure everything is in place and secure but this does not solve the problem. We are open to any suggestions offered.
3 Suggested Answers
cammedic
  • 667 Answers
SOURCE: I forgot to place my coffee filter back in the coffee maker
Just an idea, but you could use a turkey baster to remove some of the water first. I doubt if you've harmed the coffee maker.
Posted on Jan 11, 2008
SOURCE: The plastic top of the glass pot on two coffee makers drip.
This is a design flaw and can be corrected by enlarging the lid spout. First remove the plastic lid. Then use a fine grinder or sandpaper to remove approximately 1/8 inch of plastic from the lid spout. Follow the exact same contour of the oval spout. However, do not take off so much material that you disturb the small plastic tabs that hold the lid to the pot. Finish by slightly rounding the edges where the material was removed with fine sandpaper. No leaks - no drips.
Posted on Mar 03, 2010
My Bunn coffee pot seems to pour out so quickly. The grounds come out the back and all over the counter and in the coffee.
if the coffee is ground too fine, it'll take longer to brew through. either grind more coarse or call bunn for a flow restrictor (800) 352-BUNN (2866)
Jan 12, 2015 | Bunn Coffee Makers & Espresso Machines
Coffee pot spills when pouring
This is a back flow problem.
the pressure of the fluid being push by air.
the small lip on the pot can't handle the flow.
go with a small tilt and you should be fine.
May 17, 2010 | Black & Decker Brew N Go DCM18 Coffee...
Will not percolate. Water is poured, it heats up, no coffee brew
Bunn Home brewers don't perculate. They work the same way that commercial brewers do. Fillit with water, let it heat for about 20 minutes, then put your filter and coffee grounds in the funnel, pour a pot of water into the machine, put the pot on the warmer, and let the water run through. Then enjoy a nice hot cup of coffee.
Apr 12, 2010 | Bunn BX HOME BREWER 10-Cup Coffee Maker
My Survival Guide To The Dreaded Err2 Disaster
An ERR 2 may be cleared by a simple reset of the coffee maker. This means unplugging the unit and plugging it back in. When powered back on, select a brew function to see if the error reappears.
If it does, ERR 2 indicates an internal error with the computer of the warming plate. This may be covered under Kitchenaid's 1 Year Hassle Free Warranty. I would advise you to call Kitchenaid Customer Service to see what options are available to you. Repair is not recommended, as it is not cost effective for the company or the consumer.
Their toll-free telephone number is 1-800-541-6390.
Thank you, have a nice day.
Aug 30, 2009 | KitchenAid KCM511 Coffee Maker
Coffee in Cuisinart grind and brew ends up all over counter
once and a while the filter door will come ajar and make the coffee leak all over. (allways try to jigle it open after closing, because fine grounds will make the door not close right) Also if the carafe is not in all the way you'll geta mess too!
Jun 29, 2009 | Cuisinart Thermal DGB-600 Grinder
Our church received a Bloomfield Koffee King model 8571 and no instructions on how to set up and use the coffee machine.
Hi, Get 2 pots place one under the spray head with the filter cone in....now fill the other coffee pot and start to pour water through the lid top front...keep pouring water through (about two and a half pots) until water starts to pour through the cone....now the tank is full plug her in and turn on the power switch at the back and also the front if there is one....place filter in cone..put coffee in filter...pot on burner...wait about 25 minutes until water in tank is hot...when light on front comes on pour another pot of cold water through the top and you will get a pot of hot coffee in bottom....I also think this machine can be hard wired into water main....get plummer to hook up...follow same procedure but instead of pouring water through top for coffee..hit brew switch. if it poors too much of too little you will find a timer in the machine you can adjust to allow more or less water...hope this helps.
Jun 25, 2009 | Bloomfield 8571 Coffee Maker
We bought a black&decker Spacemaker coffee maker last month and it has not worked properly but maybe a week. It seems to not want to flow correctly into the pot. We set it to come on and wake up to...
If the hole in the bottom of the basket isn't plugged, it sounds like the anti-drip feature isn't functioning properly. This is the series of levers that allow you to remove the pot while the coffee is perking without spraying liquid everywhere.
There is a vertical lever mounted at the back of the hollow where the pot goes, and the top end of that lever lines up with the spring-loaded lever that closes the bottom of the coffee basket. When the basket is in place without the pot, the bottom of the basket remains closed. When the pot is inserted it presses against the back lever and the series of contacts opens the valve covering the hole in the bottom of the basket, allowing the coffee to flow into the pot. If the sequence of contacts doesn't work the basket will overflow, and you get coffee and grounds everywhere.
Ensure all these parts align and are working properly. If there's a problem that can't be resolved, or parts are broken or missing, removing the spring-loaded lever from the basket will allow the coffee to flow into the pot. You will no longer be able to remove the pot while it is perking, but you'll have your morning coffee.
Apr 16, 2008 | Black & Decker SpaceMaker ODC150 Coffee...
Bubbles in measuring column
I had the same problem. How Frustrating. What I discovered is if you pour the water in really slow, the bubble do not appear.
This was one of 3 problems I had this this maker. The other two were.
  • Could never get the clock set correctly. The buttons are very cheaply made. Would push the time advance button and the numbers would not change. Started acting whacky, flipping between the hours, minutes and program functions.
  • For 3 mornings straight the removal of pot lid gave me troubles. Was like trying to crack a safe. Needless to say, after the forth morning attempt, it lost the battle and broke.
I have been a Krups fan for many many years, dating back to the early 80s. After this even, I have become VERY disappointed with the quality of their consumer product line.
Jan 05, 2008 | Krups FMF5-14 Stainless Steel 10-Cup...
Coffee on the Countertop!
This is how my husband pours: he holds the lid open with the thumb lever and pours. It seems to work better if you pour slow. (I am always in too much of a hurry:)
Jan 30, 2007 | Mr. Coffee TFTX85 Coffee Maker
Cuisinart DGB-600 Coffee Maker Logo
43 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
