Question about Verona Ovens
Hello I have had my Verona upright cooker for 4 years and the stove ingition button for lighting the gas oven has pushed itself in to the compartment where it was fixed on the stove. The temperature gauge of the knob has bubbled/cracked/splitting and this has happened to the R) bottom burner as well .What can I do? How do I order these items? How much do they cost? What contact number can I phone? The dimensions of the oven w=900x d=600xh=900. The oven has a 139 litre gas oven capacity. Model AC596GSS. Thankyou
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 190 Answers
Shelley-
Parts for Verona ranges/ovens can be purchased directly from Verona. The following link will will take you to their parts webpage, Link. They will have the best information for you as to price and how to replace/install these items.
Best Regards,
DIYpro
Posted on May 17, 2011
  • Diane
    Diane Jan 05, 2014
    I have been trying to get a verona part through euro chef USA for months.
  • Diane
    Diane Jan 05, 2014
    Is there any other place to get verona parts? Customer service at euro chef is very poor.
The self gas ignition stays on and keeps clicking.
Request manuals and parts lists directly from Flavel.
Nov 04, 2017 | Stoves Ovens
Hello, i have a stoves q720 grf do double oven and the problem is with the lower oven, after about 20 minutes the oven switches itself off and the lights on the front of the oven flash on and off. van...
I have the same problem. After anywhere from 5 to 30 minutes the oven(s) switch off and the light and clock start flashing - I have to switch the cooker on and off to start using the oven again.
Any resolution please?
Oct 07, 2010 | Stoves 720EF Electric Double Oven
Oven won't light - electronic ignition oven
Hi, it could be your, electric heating element and oven burner gas valve. both are located in oven burner compartment, remove last bottom panel, locate oven burner, the valve that feed gas to burner, has two wires connected to it, that's oven valve could be faulty, also look on side oven burner, you will see electrical heating element, could also be faulty, it's better to replace both oven valve and element, that's the most common problem, but first check oven thermostat, that's knob you turn to light oven, if thermostat o/k, then it's your oven valve or heating element, (used to ignite oven burner) or call a mechanic, good luck.
Aug 12, 2009 | Kenmore 33169 Gas Single Oven
The pilot light works and gas in oven is on, but no gas ingition
bad thermal bulb, try moving the bulb into the flame more.
Jun 25, 2009 | Ovens
My igniter doesn't work
The battery holder is located under the cooker, on the right handside. It swivels forwards and holds two AA batteries.
Dec 13, 2008 | Stoves Premier 900GRa Gas Double Oven
Pilot light
When you smell gas...is it all the time? If so, this is dangerous. If it only happens when you're trying to start the oven, no problem. Push the red button and hold it while lighting the pilot. Hold for 30 REAL seconds more. Release. The pilot should stay lit. If not, get a service tech.
Jun 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
How to light our gas cooker
Modern gas cookers use an electronic ignition switch rather than a pilot light to light the gas for cooking. This means you can light your gas cooker with the touch of one button instead of using several matches or a flint lighter. Of course, you still have the option to light the gas cooker by hand with matches or a flint lighter if the ignition switch does not work the first time.
1.Open the gas regulator valve by pushing it in and turning it to a low setting.
2.Push the ignition switch once.
3.If the gas cooker does not light on the first try, close the gas regulation valve for one minute by pushing in on it and turning it back to the "Off" position.
4.Open the gas regulation valve, set it a bit higher than you did on the first lighting attempt, and push the ignition switch again.
5.Light the gas with a match or a flint lighter if the gas cooker does not light when you push the ignition switch again.
Feb 23, 2008 | Ovens
Lighting a pilot light in a 30 year old roper gas range
Lift the top lid and look for a cylinder or something similar with tubing going into it there should be a button of some sort on the side. if you are lucky the button will have a red cap on it. press the button in and light the pilot inside the oven. hold the button for a minute or so until the pilot stays on. kind of like lighting a water heater.
Oct 31, 2007 | Ovens
Stoves Newhome GL916
The timer has broken and needs replacing
I had the same problem, we checked all the wires inside and all ok, so phoned stoves and they said that the it sounds like the timer as this is the first port
Replaced the timer and cooker is now working fine - only thing to remember when ordering the timer - my cooker is green and now has a red light instead of green
Hope this helps
Cost of timer from stoves £56.83 inc vat and delivery
Oct 28, 2007 | Ovens
Ovens Logo
149 people viewed this question
Top Verona Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you a Verona Oven Expert? Answer questions, earn points and help others
