Question about Maxi-Cosi Priori XP Booster Car Seat - Black
I would like to remove the whole car seat cusion to was it in the washing machine how do i do so
  • Maxi-Cosi Master
  • 1,629 Answers
Good Evening
Go to www.maxi-cosi.com and select the country you are in. Now choose the Maxi Cosi Priori XP from the list of Group 1 carseats, and download a copy of the instructions for the seat. Included in the instructions is a step by step guide for removing the fabric. Make sure you don't pull the harness out as well!
Posted on May 23, 2011
How to take back seat out of 2003 e500
to clips under seats one in each corner look like pices of thick wire push to one side and the base cusion will come up to remove the rear pice when the lower cusion is removed you can see three bolts 1 in the middle and 2 on the bottom corners when the bolts have been removed just lift the seat up and out hope this helps
Mar 23, 2013 | 2003 Mercedes-Benz E-Class
I want to fold down my back seat on my 1999 Chevy Cavalier but the hook/corded loop came off and i don't know how to get my back seat down ...any solutions???
You will probably have to disassemble the rear seat to fix the latch. The lower seat cusion has latches that can be pushed in with a flat-blade screwdriver. If you pull up on the seat a little, you can see them. They are made of white plastic. There is a button on the front of them that will release the lower cusion. I usually use a flat-blade screwdriver to push on the latch buttons because they can be really hard to push by hand. Once the seat cusion is out, you can access the bolts that hold the seat back assembly in. You can remove these bolts and remove the entire seat back assembly.. Once the seat back is loose, you will have to reach around the seat assembly to remove the push-clips that hold the trunk-side carpet to the back side of the seat. You will then be able to work on the seats to repair the latch. (pull cords)
Apr 06, 2011 | 1999 Chevrolet Cavalier
Top goes down but not up
the hydraulic pump /resevior is located behind the back seat.lift up front of bottom cusion,pull forward,remove.lift up on seat back,like it's hanging on hooks.remove.locate fill screw or rubber plug on top of resevior.w/ top down fluid should be 1/2'' to3/4''below top of fill hole.it uses automatc trans fluid,so if you see red fluid under the seat you have a leak.
Sep 23, 2009 | 1998 Chrysler Sebring
Washed the car seat cover and now can not get the straps back in place
if you can roll and tighten them, they shouldnt have ever came off lol.. but other then that, once washed and dried, the cusion shrinks... ive delt with lotsa car seats, im way over protected and cant stay with a seat for more then 4 motnhs lol so let me know and ill see if i can help
Jun 26, 2009 | Cosco Summit 22260 - Houndstooth
Third-row bench stuck in down position
check for seat belt stuck in crack between seats back and cushion.
remove seat cusion to see if soemthing is stuck. see owner manual for directions. here's explorer
Rear Seat Backrest —Third Row Removal and Installation
  1. Release the two seat levers located at the lower outboard edges of the seat cushion. Lift out the seat cushion.
Feb 25, 2009 | 2003 Lincoln Aviator
Ford focus fuel pump
remove the rear seat cusion, thare should be a cover under the cusion with 4 screws take these out and under should be the fuel pump.
Jan 16, 2009 | 2000 Ford Focus
I want to replace the rear struts on my 2003 Toyota Corolla. Removing the large bottom bolt is easy but how do I access the top part of the strut??
You will have to remove the rear seat.Go to the bottom cusion in the front and yank it up,about a foot in from the outside on each side.Once it out there are some bolts on the bottom of the back rest cusion remove those and push it up and remove.Then you cen get to three nuts on each strut top.
Nov 29, 2008 | 2003 Toyota Corolla
Third row seats
A little plastic bumper, located on a metal tab on the inside of the bottom seat cushions breaks off. It is supposed to hit the seat back release and allow the back to fold down when you push the bottom cusion in all the way. I finally just bent the metal tab up so it would hit the release and that fixed it. (Look for the broken palstic pieces under the seat cusion area as an indication) The dealer replaced the plastic part several times... a waste of time.
Jun 27, 2008 | 2003 Volvo XC90
Open broken trunk
There are 2 possibilities. 1. Persuade it from the outside. Depending on the damage you might be able to just stick a large screwdriver in to the tumbler and turn it clockwise. OR if the rest of the lock and tumbler can be removed without further damage to the metal around it then remove it. You can then shine a flash light in and see a small rectangle where the lock rod used to go in to. Use a screw driver to unlock the trunk by inserting it in to the rectangle and turning clockwise. 2. Remove the back seat. If you can't remove the rest of the lock cylinder, then you'll have to remove the back seat, crawl through the trunk and use a pair of pliers to grab and twist the lock rod that goes through the trunk lock. To remove the rear set you first push backwards and lift up on the bottom seat frame. You'll need to apply force to the lowest point possible on the frame. Tt is easiest to do one side at a time. Sometimes if you look under the seat you can see where the seat frame hooks in to the body of the car. Once the lower seat cusion is out you'll need to unbolt the lower corners of the seat. I believe on this car the bolts that hold the lower part of the upper seat cushion also hold in the seat belts. Seat Belt bolts require a large TORX bit. You might also need an impact wrench to get the seatbelt bolts out. I have seen people rip the seat back away from the bolts as it is only paperboard between the seat and bolt. Keep in mind though if you do this you will not be able to properly reinstall the seat and that could be hazardous in a sudden stop or accident. Once the seat back is unbolted it lifts off of a couple of hooks on the body. Then you'll need to remove some insulating materials and finally you can crawl in to the trunk.
May 15, 2008 | Pontiac Catalina Cars & Trucks
Maxi-Cosi Priori XP Booster Car Seat - Black Logo
143 people viewed this question
Top Maxi-Cosi Baby Gear Experts
Dorel UK
Dorel UK
Kristy Richie
Kristy Richie
Level 1 Expert
Bear Mark
Bear Mark
Are you a Maxi-Cosi Baby Gear Expert? Answer questions, earn points and help others
