Question about Hitachi 51F500 51" Rear Projection HDTV-Ready Television
I have a 51 inch 4/3 Hitachi SDX HDTV ready rear projection TV which is 10 years old. Two inch horizonal (black and white) line move from botton of screen slowly up the screen. Each line is about 24 inches apart. Also at times the picture will become dark with muted our of focus images. If you move the Denon SDX tuner slightly or jar it, the picture will return to its clear focus. However the horizonal lines will continue. At other times the picture is fine with on lines. I do not know if this is a TV problem or a Denon Tuner problem. The TV and the Tuner are 10 years old.
  • Albert Derden May 17, 2011
    If the horizonal lines continue after conecting the TV straight to the Satilite Receiver what would be my solution?
  • 760 Answers
Run your signal straight to the TV instead of your Denon. If the problem goes away, you know your issue is with the Denon and not the TV.
Posted on May 17, 2011
  • David Duncan
    David Duncan May 17, 2011
    I would check your ground. You might need to attach a 3 prong adaptor to your plug at the outlet. If problem persists you could have a main board issue. Another way you can check, is see if it does it on other inputs.
Two inch horizonal (black and white) line move from botton of screen slowly up the screen. Each line is about 24 inches apart. Also at times the picture will become dark with muted our of focus images. ...
The best way to determine what is at fault is to disconnect the Denon tuner and run the signal straight to the TV. If the problem goes away, the Denon is at fault.
May 17, 2011 | Hitachi 51F500 51" Rear Projection...
Whites and light blues are really bright and everything else dark?
Try Tv repair World.com for the Coolant replacement kit.If this tv is under 10 years old,if it 10 it end of it life span.
Feb 04, 2010 | Philips 51PW9303 51" Rear Projection...
I have a sony 50 in rear projection. 9 years old
Sounds like the CRT tubes are going out which is fairly common on Sony. Inside the back of the TV there are 6 knobs - 2 for each color...one is for focus - dont touch - the other for brightness...turn down the brightness just a hair untill the lines go away.
Dec 01, 2009 | Sony KP-51WS510 51" Rear Projection...
My Hitachi 52 inch Projection TV video goes one
hitachi 52' tv...the blue color is off...you can put magic focus on and it still want move the blue back where it needs to be
Sep 10, 2009 | Hitachi 51F500 51" Rear Projection...
Tv wont power on
I had the same problem Replace the IC's and it should fix this
Dec 31, 2008 | Hitachi 51F500 51" Rear Projection...
Black opaque line or bar
if its is viewable when off then yes its water or oil.between the screens.these screen don't normally come off from the front.
they have to be access from the rear.
could be big job.
only way to tell is to remove the rear cover.
Apr 13, 2008 | Hitachi 51F500 51" Rear Projection...
Blue haze on hitachi 51" tv
http://www.hdtvoice.com/voice/showthread.php?t=15263
Jan 12, 2008 | Hitachi 51F500 51" Rear Projection...
Black screen
Sounds like convergence, you can get more info at ctechnicians.com
Dec 22, 2007 | Hitachi 51F510 51" Rear Projection...
51F510 Screen is split in two
requires service, horizontal fold over and possible other problems to come .
Sep 13, 2007 | Hitachi 51F510 51" Rear Projection...
Hitachi 51F500 51" Rear Projection HDTV-Ready Television Logo
49 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
