Question about Hobart ET27 4-Slice Toaster
Toaster Parts hobart ET25-27
Does anyone know where i can find parts to either a ET25 or ET27?
More specifically a Timer?
  • 640 Answers
Goto hobartcorp.com find your model then the part or call 18884hobart
Posted on Sep 10, 2008
Hobart toaster et27 one side does not work. Tested all elements, all showing resistance. 125V at all terminals when control is down. I am stumped
Check for corrosion at the contact points.
I suggest not "fiddle" with a toaster and instead replace it for safety reasons.
Nov 28, 2017 | Hobart Kitchen Appliances - Others
How do I order Handle, liver and Carriage?
through the proper website . which we are not
Feb 21, 2015 | Hobart Et27-4 Toaster
I have a old wall built in thermador toaster & need parts
I have a Thermador built-in toaster ( new in box). It has never been used but I have had it for many years. Willing to sell.
Mar 29, 2009 | Kitchen Appliances - Others
How do you replace the elements in a Hobart 4 slot toaster? I took off the bottom but there must be something I am missing. It's awfully small in there to manuever. There has to be a trick. Please share.
No Tricks. The elements are loaded and removed from the top.
DISCONNECT THE POWER CORD
Remove the crumb dtrawers, they are handy to put the parts on so the don't roll away.Remove the temperature knob after releasing the set screw, remove the lever knob after removing the pivot screw. Remove the 3 front and 4 rear cover screws with a philips driver. note the length of the screws from the locations.
Locate the element to change, disconnect the connections at front and back on the top of the element. With a small flat bladed screw driver, open the crimp tabs on each end of the bread guides and lift up. They come out of alignment holes in the lower frame. Replace the element/s, with the correct voltage replacement. 208 and 240 elements are different numbers. Reassemble in reverse order. Be carefull not to catch the element with the bread guard wires. It's common to see a bit of smoke during burnin of new elements for a short time.
Feb 24, 2009 | Hobart ET27 4-Slice Toaster
Hello, I am looking for a part for my Hobart Toaster
parts books are available at hobartservice.com for free and the locations Hobart offices for parts
Jan 23, 2009 | Hobart ET27 4-Slice Toaster
One side will not heat
check your timer board at the back of unit
Nov 27, 2008 | Hobart ET27 4-Slice Toaster
Only toast one side of the bread
The other side that isn't toasting has an open element. Usually, the good side will burn twice as hot, and may have stressed that element. You might want to replace both in that slot. make sure you check the voltage rating plate. 208 and 240 volt toasters use different elements.
I just posted the procedure to replace elements, in a similar post here.
Oct 12, 2007 | Hobart ET27 4-Slice Toaster
Hobart ET27 4-Slice Toaster Logo
526 people viewed this question
Top Hobart Kitchen Appliances - Others Experts
Treefrog15
Treefrog15
atva20
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Hobart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
