I have a maxtor 250GB black usb 2.0 hard drive that is no longer recognised by my PC. The usb port works OK with other USB appliances. Its not a high speed 2.0 port but thats not been a problem in the past. I have Gbs and Gbs of homemade film and artwork on this back up drive!! Youre help would be invaluable.
  • 21 Answers
Try connecting this drive to another PC/laptop. If the hard disk does not get recognised, you may have to seek help from Maxtor / authorised service personnel to diagonse the issue with the hard drive. Given that there is circuitry in between the actual physical disk and its USB port connector, chances are that the data on the hard disk would be safe and the intermediate circuitry may have suffered a brown-out. Good luck!
Posted on Aug 14, 2008
My Maxator hard drive is plugged in and I got a message on the screen saying the "Hard drive has malfunctioned and is no longer recognised by the computer". The light was on, then blinked a few...
plug the hard drive into a different usb port, or take it to a friends computer and try it there, if it works the problem is in your usb ports, these issues are hard to solve, but first make sure the drive is actually ok
Mar 16, 2011 | Maxtor OneTouch 4 500GB External USB 2.0...
I have Windows XP with service pack 3. My system no longer recognizes the Maxtor 3200 external hard drive. Do I need to get an updated driver to the hard drive? When I first connected the Maxtor HD. ...
When you plug in via USB, does the USB recognize it and not display as HDD? If that is the case, then it's probably disabled somehow. Access Computer management, and check from there.
If that doesn't work, try on a different computer. If it doesn't work, your HDD has gone faulty. And if you recently changed your board, make sure you have a high speed USB port.
May 24, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
The blue light on my Maxtor is blinking really fast and my Mac no longer recognizes the connection. How can I fix this?
Have you tried restarting your Mac (with the Drive still connected)?
Otherwise try:
1. Disconnect the USB cable from your Mac.
2. Restart your Mac.
3. Reconnect the USB cable to a different USB port on your Mac (like the keyboard USB port for example).
See how you get on. Let me know. Regards,
Feb 16, 2010 | Maxtor OneTouch II 300 GB Hard Drive
Maxtor one touch 4 mini 250GB hard drive beeping
I had the same problem and the Maxtor/Seagate website did not have any solutions. I finally got in touch with Tech Support and got a fix. I was using it with a Dell tower and plugging into a USB port in the front. I also was using an after market cable.
I learned the Maxtor is a power hog and beeps and shuts down when it is not getting enough power. I did not know but the USB ports on the front of a desktop/tower computer do not provide as much power as a port on the back (the back ports are sometimes directly connected to the motherboard). I got a USB extension cable and connected it to a USB port in the back and it solved the problem.
I also learned that most laptop USB ports are not powerful enough to run the Maxtor. Mine would also not work if you attempt to share it by using an unpowered USB hub. I have gotten it to work with a powered desktop USB hub (Belkin).
I believe that this may explain why you get a "Y" cable with the drive. I could not find an explaination for the cable or how to use. There may be an accessory to purchase that attached to the cable and powers it.
Oct 15, 2009 | Maxtor OneTouch 4 Mini 160GB External USB...
Driver wont start
I devised these simple steps that tend to remedy quite a few common USB problems.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability.
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again.
If you suspect a cable never get one longer than the one you want to replace
If you checked and fixed anything there and still have issues it may well be due to the device itself or a weakened usb port, a loose usb port.
To remedy the last two consider a new usb card if it for a PC
Aug 24, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Xp computer wont recognise new 250gb elements ext hard drive
use it on a differnet usb port
these portable hard drives have some issues with 1.1 usb ports
Jul 12, 2009 | Computers & Internet
My maxtor 200GB drive is not recognized by my CPU anymore!
Hi Crkinard.. i think you shuld first find out whether the problem is with the external device or your computer... so check if the device is recognised by another system... as you have been using the device dor couple of years i think yours computer's drive for external devices should have been corupted.. so check out the device with some other computer.. if it is recognised in that computert then you can easily reinstalled the software for your device again..
Oct 13, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor OneTouch 4 Mini 250GB External Drive Does not show up on my computer
Are you connecting Drive via a USB hub or direct into two separate USB sockets on PC?
May 05, 2008 | Maxtor OneTouch 4 Mini 160GB External USB...
Computers & Internet Logo
David Payne
David Payne
