Question about Nexvio ReelDirector
When attempting to upload the rendered video to you tube it says there is a problem. "failed to upload error=bad authentication". What am I doing wrong?
Cant upload video just cause 2 on ps3
hi i am asadshah i am the one who right this question i found the solution that is you go to you tube account and see on the top what ever you tube calls you (example you tube calls me asadsha) you write your account name on the paper and make just cause 2 video and try to upload it on the user name put your account name written on the paper and put your account password and try to upload it i now that it will work (reply)i asadshah671@yahoo.com ) if it work
Nov 25, 2012 | Video Game Consoles & Games
Tip
How to Render YouTube-Capable 720p HD Videos in Sony Vegas
Welcome to my tutorial on rendering or exporting videos in 720p high definition that you can upload to YouTube. [NOTE: Entire tutorial is available in video format at the bottom of this article]<br /> Required tools: <ul> <li>Sony Vegas HD video editing software - <a href="http://www.sonycreativesoftware.com/vegassoftware">http://www.sonycreativesoftware.com/vegassoftware</a></li> <li>K-Lite Video Codec pack - <a href="http://www.codecguide.com/download_k-lite_codec_pack_full.htm">http://www.codecguide.com/download_k-lite_codec_pack_full.htm</a> (install this codec pack after you've installed Sony Vegas and before you begin editing your video)</li> <li>Video file(s) you wish to edit</li></ul> Once you have Sony Vegas installed and the codec pack installed, open Sony Vegas. You will have an empty project window similar to this one: <img src="d3m0l1sh3r.jpg" /><br /> <br /> Now find your video files and drag them into the Project Media tab in Sony Vegas. <img src="d3m0l1sh3r_0.jpg" /> Next, drag all of your videos onto the video timeline at the bottom of the Sony Vegas window and align them in the correct order. <img src="d3m0l1sh3r_1.jpg" /><br /> Next, right-click all of the video files on your timeline, go to "Switches," and uncheck "Maintain Aspect Ratio" and click "Disable Resample." Your "Switches" menu should look like below. <img src="d3m0l1sh3r_2.jpg" /><br /> Last step of the editing process! Next, drag the yellow triangle <img src="d3m0l1sh3r_3.jpg" /> at the top-left corner of your video triangle all the way to the end of your video clips. This tells Vegas to only render that much of the timeline. Click File -&gt; Render As... and type in your final video name and choose the location you wish to save it to, but do NOT click Save yet! Click the drop-down menu next to "Save as type" and select "MainConcept AVC/AAC (*.mp4)". Next, click the "Custom" button, next to the "Template" drop-down menu. For each tab in this window, make your setting match exactly how they do in the pictures. "Video" tab: <img src="d3m0l1sh3r_4.jpg" /><br /> "Audio" tab: <img src="d3m0l1sh3r_5.jpg" /><br /> "Project" tab: <img src="d3m0l1sh3r_6.jpg" /><br /> Finally, type in a template name, next to "Template:" at the top, like "YouTube 720p HD" and click the save icon. This saves your template for future use. Then click OK at the bottom. Back at the Render As menu, make sure the template you just made is selected, and click save. Depending on the length of your video and the speed of your computer, this can take anywhere from a few minutes to a few hours to complete, so make sure your computer stays awake and has power to complete this job. Once it's done, Ta-Da! You have a YouTube-ready HD video ready for you to upload and share! (Or to FaceBook, or other popular sites, as well.) <br /> I hope you enjoyed this tutorial and it was helpful. <br /> Here's a video tutorial for further aid, however it also includes information for recording PC video games as well. <utube src="YFbuFM2HH3w">Adam Taylor, D3M0L1SH3R <p><br />
on Jul 10, 2011 | Sony Vegas Pro 9 Full Version for PC...
F-dl
If the door fails to lock after six (6) attempts "Fdl" will display. The "Fdl" error code indicates a bad lock assembly. Here is the lock to order.Below is a video to show you how to replace the lock assembly.
The part comes with a 365 day, any part, any reason return policy.
Nov 09, 2012 | Washing Machines
Belkin N150 Wireless USB Adapter is not connecting to Netgear WNR1000 N150 Router which requires secured access. Was working fine before with "Network Authentication: WPA-PSK" and "Data...
Put all your settings back to the way they were and check the time and date on your computer (also on the router), WPA uses encryption, if the time difference between the two is too great it can break the encryption (seen this often).
Mar 10, 2017 | Belkin N150 (F6D4050) 802.11g/b Wireless...
No matter what kind of file I trial to upload, AVI or WMV I always get a message that says "upload failed to an unknown error."
It is a well known YouTube bug. Just scroll down to the bottom of the page and look for the link called "Basic Uploader" (see image below). By doing it through this link you won't get an error.6_20_2011_8_07_29_pm.jpg
Jun 20, 2011 | YouTube Videos
"Packet Data Authentication Failed" what is
The error msg "packet data authentication failed" is displayed when connecting to internet via cell phone, even after having the original configuration settings provided by the supplier set to default. The problem can be solved by the following method or else contact the service provider. >Delete the old settings and then by switch off the phone. >Remove the sim card and reinsert it, after some time >gett the new settings and set it to default. Hope this helps. I had the same prblem. Even after calling cc, nothing helped. I tried all things but failed. Then unfortunately, i entered the url of the sp in the access point setting manually and wow it worked. I did this by using uninor.
Jun 17, 2011 | Nokia 2626 Mobile Phone
I have a problem with You Tube. I used to use it very often, but something happened and I can't watch videos. I used Mozilla Firefox, but I also tried with Opera. I have newest version of Adobe Flash...
I'm not handsome, but, I have a method.
You know streaming video is so slow, if you like, you can try to use iFunia Free Youtube Downloader to download YouTube video to your PC, then, watch the download video on PC.
Feb 18, 2011 | YouTube Videos
Flip Ultra is not recognized by FlipShare!
make sure all your computers drivers are up-to-date. If they are then make sure you have the latest service pack for your particular OS.
Dec 28, 2009 | Pure Digital Flip Mino Digital Camera
How to enter authentication details for the Document Server ?
Hi there if you type in the internet explorer the ip address there you will have the machine information. Then login usually the login is
User name = Admin
Password = password or just enter leave blank
Once you are in there you will be able to change the details you need.
Cheers J
Dec 26, 2007 | Ricoh Aficio 3025 All-In-One Laser Printer
Nexvio ReelDirector Logo
129 people viewed this question
Top Nexvio Apps Experts
Erin Wood
Erin Wood
Are you a Nexvio App Expert? Answer questions, earn points and help others
