Question about Hitachi 51F500 51" Rear Projection HDTV-Ready Television
Two inch horizonal (black and white) line move from botton of screen slowly up the screen. Each line is about 24 inches apart. Also at times the picture will become dark with muted our of focus images. If you move the Denon SDX tuner slightly or jar it, the picture will return to its clear focus. However the horizonal lines will continue. At other times the picture is fine with on lines. I do not know if this is a TV problem or a Denon Tuner problem. The TV and the Tuner are 10 years old.
  • 760 Answers
The best way to determine what is at fault is to disconnect the Denon tuner and run the signal straight to the TV. If the problem goes away, the Denon is at fault.
Posted on May 17, 2011
I have a 50 inch Samsung plasma HDTV model LNT4071FXXAA version SS02 it has a small approximately 16th inch vertical line starting at the bottom of the screen and going about 4 or 5 inches up When looking...
Open the back of the tv. Inside you will find a series of connectors with ribbon connectors along the screen edge. look where the line is on the screen and open the ribbon cable clamp closest to the line. Move the ribbon cable a little and re-clamp it. Sometimes a little corrosion creates a bad connection.
Mar 20, 2014 | Televison & Video
One inch white line when booting slowly becomes solid
If you'r not expert fixing laptops send it to repair shop to check screen cable it might be screen data cable problem like it loose or need replacement if this not the problem then Ohhh time to change the screen...Good Luck
Feb 03, 2013 | HP Pavilion zd8000 Notebook
Toshiba L675D, black spots
Your screen is shot or partially disconnected. A lot of laptops have the vid card to lcd connect in bracket that connects the screen to the keyboard. I have fixed many by siimply taking it apart and reconnecting the clip but the spots dont sound good. Ebay to buy one or Cl to dump it as a fixer. Either way its a waste of money to have someone fix it for you unless you do it yourself.
Jul 06, 2012 | Toshiba Satellite Black 173 L675DS7049...
BLACK SCREEN WITH A BRIGHT HORIZONAL 1/4 INCH
HELLO
This is called Field Collapse and usually caused by the frame/field output going open circuit and/or the componants that surround that part.
Call a service centre in your locality who put it right (:-)
Nov 22, 2009 | Sylvania Televison & Video
Rca 32 inch tv
this is a frame fault
the fact that you can still see the line when the tv is off is because you have been watching with the line and it has burnt into the crt.
time to buy a new tv
Sep 04, 2009 | Sanyo DS24205 24" TV
Picture vertical output has reduced
TV has no cathode 200 volts supply.
If you have experience of CRT TV repair then let me know to guide you further or get help of near by TV tech person.
Nov 30, 2008 | Sony FD Trinitron WEGA KV-24FV300 24" TV
31'sanyo tv analog has a white horizonal line thru it
There is a failure in the vertical amp section. This can be the main output IC, or any of the support components in this area.
An experienced tech can troubleshoot the set, and determine and service the fault.
Jerry G.
Apr 27, 2008 | Sanyo DS31590 31" TV
Hitachi 51F500 51" Rear Projection HDTV-Ready Television Logo
81 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
