Compressor cut out after 5 minute aircond working
    Sergeant:
    Champion:
  • 229 Answers
Sound like the unit is going off on the high limit switch or low limit switch. If its going off on high limit your condenser coil is probably very dirty and needs to be cleaned. If it is going out on low limit its most likely low on freon and has major issues.
Posted on May 17, 2011
My 2005 f450 tubo diesel aircond is not cooling,and I need a fuse panels schematic
To answer your problem in 2 ways. First if you do an internet search with terms like "Ford F450 fuse schematic" you should find something. Second, you have 2 electric cut-off switches in the A/C lines. One switch is a low pressure cut-off and the other is a high pressure cut-off. Each switch is on the appropriate A/C line so nothing may be wrong with fuses; the switches are suppose to kill the power to the compressor clutch assembly.
Jan 17, 2018 | Ford F-450 Cars & Trucks
Amana apn14j-e stops working after a few minutes
More likely the pipe sensor is defective (a sensor inside the evaporator ,connected to the thicker gas line).... if it don't send any temperature changes to the control board after 5 minutes , it believes the A/C isn't working and cuts off the whole thing to safeguard the compressor from damage ....
Apr 27, 2014 | Haier Amana Apn14j-E Portable Air...
Put in a new thermostat and now cannot get the compressor to come back on hit the reset how long does it take to come back on
Most new thermostats have a 3 to 5 minute delay.
Check your wiring if it does not come on by then.
R=red (hot)
G=green (fan)
Y=yellow (cool)
W=white (heat)
C=blue or black (common) only on some thermostats
Also make sure "rc" and "rh" are jumpered together at the thermostat or the aircond will not work.
Jun 02, 2011 | Ruud UBHC Air Conditioner
I have a question on Capacitors.
Capacitors on a air cond help in starting the motor and the compressor. If the capacitor is shorted or open, the motor or compressor will not work. Capacitors also keep the motors running. Most domestic airconds have a capacitor for the compressor and most condenser motors also have a smaller capacitor.
Apr 11, 2011 | Heating & Cooling
5,200 BTU unit. Compressor and fan both work when first turned on, then compressor quits after 5-10 minutes of operation. Won't turn on again even after 5-minute fan-on cool down. Process repeats after AC...
this could be just a simple fix of cleaning the condenser coils. If semi-clogged, it can cause higher than normal pressures and cause the compressor to cut out on it protector. Check it out.
Jun 11, 2010 | Heating & Cooling
Daikin aircond cuts off i reset the circuit breaker and it works for ten minutes and cuts off again
What is happening is the a/c is overamping. This could be caused by a number of things. 1 Low air flow through coil, cause, dirty filter or evaporator coil, cure, clean both should look as if it is new. 2. compressor pulling more amps due to age or mechanical problems. Now depending on the area you live look at the wattage on the system. It may be in Kilowatts, if so take that number and divide it by the voltage that the system is required to operate on and this will give you a number which is your amps. Now go to the power supply to the house or apt and see if the breaker listed for the a/c is the same number as your past number that you had from the kilo watt calculation . This number shoould be below the number on the electical breaker. If it is higher than the breaker you need to have the breaker replaced for a high amp. draw. Make sure to check for air blockage first then proceed. Good luck on repairs
Dave
Dec 08, 2009 | Cfm Daikin R410a Split System Air...
So-low freezer try to start, but stops after a second
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Oct 23, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Engine idling gone crazy
check for lose vacuum hoses or lose throttle hose make sure you air flow meter ducks are tite if you see everything ok then the idle speed control valve could be dirty with a little carburetor cleaner spray while engine is running open throttle and spray into throttle till you can see throttle is clean you may have to do this a few time hope this information is useful good luck
Jul 27, 2009 | 1995 Toyota Previa
A/C compressor works intermittently
Hello< will try and help you.Try replacing the low pressure switch,and the high side compressor cut out switch,look on the low side for the low pressure switch(large line/hose).It will have to wires gong to it.The high side cut out switch will be on the high side line/hose,or in the back of compressor.If this doesn`t help Have the system pressures checked.If I can help anymore...roniecon@gmail.com
Jul 17, 2009 | 2000 Volkswagen Beetle
Hisense air conditioner
-If both compressor and fan motor starts and stop, thermostat is the defect.
- If only the compressor check for your outlet no sign of discoloration, check the voltage if normal, check the defective overload protector of the compressor it its external, or compressor itself is defective
Oct 26, 2007 | Heating & Cooling
Heating & Cooling Logo
61 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
