Question about Fisher and Paykel Washing Machines
I have a top loader, i have just replaced the water pipes (as one had split) then on turning it on it will not work, the water is on , yet nothing happens. The red light indicating the lid is locked is on, and only stops when i press pause, then when i press stert it just continuosly beeps !! PLEASE help... Thank you in anticipation...KIM
  • Fisher and P... Master
  • 713 Answers
Hi Kim just read your posting.To help you I need the model number of the machine which is located at the back of the machine up top on the top panel.Please reply with this information and I can help you rectify this fault.Looking forward to your reply.
Posted on May 18, 2011
Morning Samsung front loader wf1752 water is spurting out of were detergent is placed under door and now seeping out underneath, have pulled apart pipes, are not split what could it be
There are 2 solutions for this problem, the easiest solution is to turn the tap that supplies the water to the machine down so that it stops leaking, the second option is replacing the dispenser drawer housing, The housings warp slightly over time and allow water to leak out at higher pressures.
Apr 29, 2017 | Samsung Washing Machines
Hi I have lg WT H550 machine when I turn on the machine the water is not stopping come into the machine what should I do water level is coming upto the top
2 possible causes
the water solenoid control valve is split in the diaphragm and not stopping the water
the small hose from the base of the tub to the level control pressure unit is split or disconnected or the pressure unit has failed and is not activating the water control valve
Mar 25, 2016 | LG WM Washing Machines
Whirlpool WFW9150WW01 will not drain
New drain pump impeller maybe?otherwise complete pump i think
Jan 10, 2014 | Whirlpool Washing Machines
Frigidaire top loader drains water from underneath
You may have a split in a outlet pipe or a pipe has come off. If it's only leaking when it is emptying I would suggest it's probably a pipe after the pump and one that is higher then the level of water that is in the machine as otherwise the water would siphon out all the time.
Has the outlet hose been extended and have a coupling where it joins?
Dec 28, 2012 | Frigidaire FWS833A Top Load Washer
Hot water washing
You need to replace the water inlet valve.
Nov 10, 2012 | Washing Machines
Washer/dryer
It sounds like a split pipe or fault with the low pressure level switch.
This relies on being a sealed container below water level to build up pressure to turn off the water.
The switch and pipes need checking and anything defective needs replaced.
Only open up if you are competent with mechanical repairs. Turn off supplies before service.
Oct 13, 2009 | Washing Machines
Washer won't final spin
After charging me $275 to change the water pump, the repairman said I needed a new computer board for another $160. I went & bought a new washer - this time a regular top loader mechanical washer with no computer. The repairman said computerized washers & front loaders in particular have lots of problems. He said top loader Whirlpools have the least problems.
Nov 13, 2008 | Frigidaire ATF6000ES Front Load Washer
Overflowing washing machine
check the pressure switch . its circluar in shape with 6/8 wires attached, and a small nipple with a 10mm pipe attached. as the water rises in the drum air is pushed up thru this pipe which when working ok , eventually pushes against a switch .hence its name. so, if there is damage to this pipe( maybe rubbing against the drum) the passage of air escapes before reaching the switch. if the pipe is ok then check the switch by blowing up the pipe (with the power off ) and u should hear a small click inside the switch. if not replace
Feb 06, 2008 | Washing Machines
LG WFT1022TP top loader washing machine
the system which controls water level is an air chamber with a small diameter pipe which goes to a pressure stat. when the correct level is reached, the pressure in the air chamber switches the pressure stat and cuts the water off. the things to look for are: gunge in the air chamber split in the pipe. faulty pressure stat to test, get a similiar length of small diameter pipe and connect it to the pressure stat instead. with the machine filling, blow gently into the pipe and see if the water intake cuts off
Apr 02, 2007 | LG WFT1071TP Top Load Washer
Washing Machines Logo
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
