Question about Garden
I have an old hozelock courier 5L 4045. over 12 years since i last used it. my builders filled it with a product. i now need to empty it, clean and refill but can't get the top off!!! don't think it's broken (may be a bit gummed up) - see it needs to unscrew at top by pump handle. have depressed pump handle in a tried to turn in direction of OPEN arrow but no joy. any suggestions?
  • 3 Answers
SOURCE: spacmaker xl sensor
If anyone wants to replace the whole door contact me. I've got an couple of extra ones in great shape. The door comes off really easy. Michael_Wassmuth@agilent.com.
Mike
Posted on Nov 06, 2007
mumma_1
  • 903 Answers
SOURCE: belling SGE12X broken door handlw
it's not an easy job to replace a door handle, but to release it for the door to open, turn off the machine at the outlet and unplug. Take the top of the machine off and slide your hand down to the door catch. Depending which type of catch it is, you should either be able to push down a small lever on top or push up a small lever on the bottom or the door catch.
I hope this helps
Posted on Oct 25, 2008
SOURCE: Bamix stick blender Handle vibrates but shaft does not turn
Old food residue and juices will have got into the shaft bearings, and have dried out enough in 9 years to stop it turning. Starting with the simplest solution, try immersing the shaft in hot, or even boiling, water nearly up to the top of the metal shaft. CAUTION - DON'T BURN YOURSELF! Let it stand in the water for a few hours, and then try turning the shaft by hand (with the machine unplugged, of course). This could be repeated a number of times. You may also be able to unscrew the blade guard after this treatment, bear in mind it has a left hand thread, so if you are looking at it from the bottom, turn it clockwise to loosen. Be careful not to lose any seals or springs when it comes off.
If this doesn't work, support the Bamix upside down, and pour a small amount of WD-40 into the blade guard, so that it pools around the end of the shaft. Leave to stand, and the oil should slowly seep into the bearings, dissolving the food residues. Again, try this a few times.
If neither of these work, the Bamix will need to be dismantled to clean the shaft and bearings. This is really beyond the scope of this forum and requires some experience of this type of work.
Posted on Mar 13, 2009
libaredneck
  • 119 Answers
SOURCE: I have a 15.5 Briggs and Stratton engine. I used
you need to have the carb cleaned. sounds like the float is stuck
Posted on May 05, 2009
SOURCE: 2 year old Brother MFC 3240C = Black is plugged
I getting rid of mine with the same problem. No more Brother products.
Posted on Nov 22, 2009
My steam iron has calcified outlets although have regularly emptied the machine through the outlet, therefore not working properly
its a great iron no argument there
de scaling products can only do so much
even if using demin water or filtered water
they dont last forever
Nov 09, 2016 | Tefal Irons
Hozelock pressure sprayer , when I pump the sprayer the pressure release valve pops up loosing all my pressure
That's what it is designed to do when there is too much pressure, usually sprayers don't get used that much to ware out that part. You might be having trouble getting spray out the wand, in that situation it is probably clogged. You have to remove tip and see if you can clean out a little particle blocking it. I know it is easy to occur and it happens if some dirt falls into the tank while filling. Hope that helps.
Jun 09, 2016 | Hozelock Garden
Hozelock instructions on product are as clear as mud. is there an idiots guide please?
You can check out our " how to video's" at www.hozelock.com - btw which product are you struggling with ? - from Simon at Hozelock
Jun 20, 2011 | Garden
Brakes are slipping and handles dont click in easily sometimes realy hard to lock in have to stand for at least 5mins trying to pull them up. any soloutions? thanks
Good Afternoon
Are you a UK customer?
If you are, and the product is under 2 years old, please contact your retailer with proof of purchase for them to send the product to our engineers for full inspection & any repair work required under the terms and conditions of the warranty.
If you are a UK customer but the product is over 2 years old or you no longer have your proof of purchase please contact the customer service department on 01284 413 141 Mon-Fri 8.30-4.30 to book it in for chargeable inspection and repair work required. Standard charge is £60 and this will include courier delivery service of the unit back to your address; in addition you will need to make arrangements and cover costs for the product to be sent by courier into our engineers.
If you're not a UK customer please visit www.maxi-cosi.com and select the country you're in and use the "contact us" tab to get in touch with the customer service department in your area.
May 01, 2011 | Maxi-Cosi Loola Stroller
Do u know where can i get my quinny buzz jogger stroller repair as it cant unfold automatically.thanks
Good Afternoon
Are you in the UK? If so, and your product is under 2 years old, please return to your retailer with your proof of purchase for them to make arrangements for the unit to be sent to our engineers for inspection and repair work required.
If you're in the UK and the product is over 2 years old, or you do not have your proof of purchase, please contact the customer service department on 01284 413 141 Mon-Fri 8.30-4.30 to book it in for chargeable inspection & any repair work required. The standard charge is £60 and this will include courier delivery of the product back to your address; in addition you will need to make arrangements and cover costs for the product to be sent by courier service into our engineers.
If you're not in the UK please visit www.quinny.com and select the country you're in, then use the "Contact Us" tab to get in touch with the customer service department in your area.
Apr 29, 2011 | Quinny Buzz Jogger
Quinny zapp lock can't be pressed down
Good Afternoon
If you're a UK customer and the product is under 2 years old please contact your retailer with your proof of purchase; they will make arrangements for the chassis to be sent back to our engineers for inspection and repair work required.
If you're a UK customer and the product is over 2 years old or you no longer have proof of purchase please phone the customer service department on 01284 413 141 Mon-Fri 8.30-4.30 to book it in for chargeable inspection and repair work required. Standard charge is £60 and this will include courier delivery of the product back to your address; In addition you'll need to make arrangements and cover costs for courier delivery of the product into our engineers.
If you're not a UK customer please contact www.quinny.com and select the country you're in - then choose the "Contact Us" tab to get in touch with the customer service team in your area.
Apr 22, 2011 | Quinny ZAPP Stroller
The motor in my hozelock ac2 keeps opening and closing and the display is blank. I've put in new batteries but the problem persists. Any advice on how to fix this?
Same problem for my Hozelock ac2 after two years working couple times everyday. No warranty, no Service Center nearby. Two options: discard it or repair it myself. Using a small screwdriver I removed the front cover and then the sealed transparent lid covering the keyboard. Humidity was damaged all contacts so I cleaned using compressed air, put new batteries and set up all again. My Hozelock ac2 is working again. I think the product life cycle is two years and as usual also has "planned obsolescence". -Arthur RS
Apr 20, 2011 | Garden
I bought a Hozelock Ultra 9 (model 2684) last year for watering the garden and cleaning the car.It now leaks very badly from around the trigger. Can I take it to bits and mend it? Are there any...
HI - Simon fom Hozelock. I am afraid they are not repairable in this area. The most common cause of this failure is due to ice forming inside the gun and forcing the internal plunger and O rings out - causing a leak. All sprayguns should be protected from freezing. If this isn't the cause (only you know !) And it is 1 year old, we would replace it under warrenty contact us for help www.hozelock.com for details. Simon
Mar 09, 2011 | Hozelock Garden
Garden Logo
90 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
