Question about HP Computers & Internet
I was working on my laptop and it just cut off
    Problem Solver:
  • 5 Answers
I've seen a number of different laptops and desktops just "cut off" over the years, and in my experience it has to do with overheating issues. Maybe one of the fans inside your laptop is not working properly, and in order to protect itself, the laptop will shut off immediately.
You can try and monitor this using an application like Speed Fan. Which can be found here:
http://www.almico.com/sfdownload.php
If you keep an eye on some of the temperatures after you install this software, and if the temps go up and then your laptop shuts off, it would be an overheating issue.
Has this happened before? Does it happen after having the laptop on for a long time, or a short time?
I would recommend making a backup of all your data as soon as possible just to be safe. And then follow up with a local repair shop or the manufacturer.
Hope this helps.
Posted on May 17, 2011
    Scholar:
  • 73 Answers
This could be from any number of things,
If your laptop was running on its battery its a good sign that the battery is on its way out or has not properly warned you of the critical battery status
If plugged in then its more then likely a heating issue as most laptops now a days (and for the past few years) have very powerful processors and heat up dramatically. If the laptop was not on a hard flat surface then its likely it was not venting properly and I would suggest getting a laptop pad or fan cooled pad for the bottom of it while your working on it
Or there could be a loose cord that you were unaware of and a small movment or gesture could have loosened it enough to unpower the unit.
How do I turn up the keyboard lights in my dell inspiron laptop with windows 7?
What is the model number? Has the laptop got the correct keyboard driver installed? Has it got keyboard lights?
Jan 06, 2015 | Dell Inspiron Computers & Internet
How to cut and paste with a dell labtop
Keyboard shortcuts for cut and paste are:
Ctrl+C=cut
Ctrl +v= paste
These work on every computer I have ever used.
Aug 21, 2014 | Dell Inspiron 1525 Notebook
Sound keeps cutting out
take to the repairers they will handle it parfectly
Sep 05, 2017 | Toshiba Satellite L755s5246 Laptop...
My charger is working perfectly fine but for some reason my laptop will no longer charge. When I cut it back on, it would only stay on for about 10 seconds before cutting off again. Now it wont turn on at...
I'm leaning to the fact that your battery needs replacing ,, to verify this,, remove the battery , plug in the laptop and turn it on... Put in battery and unplug it,, if it cuts off you need to replace the battery..
Oct 22, 2010 | Computers & Internet
Green light cuts off when plugging into laptop
Replace the charger, it probably overheat and died.
Try with a voltmeter to measure the output power (usually aroud 19 V DC)
Then the tricky part, try to power something else with the charger , something who might work with the output power (a car light bulb for exemple).
If it does work then you have a short cut on the motherboard of your laptop if it's the case replace the laptop, it's the hell of a job to repair the motherboard...
good luck
Dec 12, 2009 | Dell Inspiron 1501 Laptop
I have a lenovo laptop and Microsoft office. How do I do a screen shot on this thing? The office won't let me ''paste' it for some reason.
Sometimes when the right click options do not work, you can revert to the old DOS command short cuts. I am unsure of the Fn + "F" key stroke to take a screen shot but the keyboard short cuts for copy, cut and paste are: copy is Ctrl + C, Cut is Ctrl + X, Paste is Ctrl + V
Oct 01, 2009 | Lenovo ThinkPad SL500 Notebook
Laptop keep on cutting out
if it's not loosing power, random dropouts are usually due to an overheat. check to make sure that the fans are running and replace if necessary.
Aug 14, 2009 | Computers & Internet
IBM T40 2373 display cuts off.
When it cuts out can you still see the display very faintly or does it just go completely black?
Mar 10, 2009 | IBM ThinkPad T40 2373 Notebook
Can't cut and paste something then e-mail it
What you are trying to cut is probably write protected, therefore can't be cut. So, try to Copy and Paste instead, that should work.
Feb 09, 2009 | HP Pavilion dv6000z Notebook
I have major probs with both my laptops...
Hi
I think your problem is with the battery ac/power voltage.
Make sure of the right voltage for your Laptops is selected on the Ac/power device you are using.
In other simple words, the high voltage causes the laptop to cut off as yours, and the soloution is that you try adjusting the voltage into a lower voltage.
I hope this works!
Nov 03, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
41 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
