Question about Metabo Drills
1/2" metabo hammer drill-
    Problem Solver:
  • 14 Answers
Did you check the carbon brushes?
Posted on Jun 27, 2014
  • 313 Answers
SOURCE: Repair service for Bosch 1 1/4" hammer drill
yes but its depend on the problem
Posted on May 29, 2008
  • 16 Answers
SOURCE: no power
Check the Cable between the plug and the switch for continuity using the ohmeter or continuity tester part of a cheap multimeter. Place one lead on each of the plug contacts in turn, and the other on the other end of that wire. If this is okay, check the switch for continuity by placing each lead of your tester on the in and out contacts and pressing the trigger. If still no joy, check the brushes. If still no joy, check the motor windings for continuity.
Posted on Jun 15, 2009
jmgldsmth
  • 1869 Answers
SOURCE: Faulty bosch hammer drill
a bad trigger switch; bosch sells a replacement part
Posted on Jul 24, 2010
SOURCE: how to dismantle a makita
Check out the split drawing on this page.
If your makita does not have any outside accessible brush caps, you need to dismantle it.
lay it on the side, where the side with the screws securing the to halves together is facing up.
Remove all screws (some may be hidden under labels etc.) Gently pry the halves apart, locate the brushes disconnect their leads if any, and remove. Install new brushes and make sure the move freely, and that they are springloaded when in place. Gently rotate the rotor to ensure everything is ok . Reassemble and test drill. If the brushes leaves long streaks of noticeably large sparks, something has gone wrong or the rotor was damaged in the first place, causing excessive wear.
Posted on Nov 29, 2010
  • 298 Answers
SOURCE: Model# 315.114110 (3/8 hammer drill with cord), It
Sounds like the switch.
Get a hold of sears to see if you can get a new switch from the appliance department.
If not I would re wire the thing so it would at least run forward.
Posted on Dec 02, 2010
Testimonial: "I will try the Sears Part for the switch. Thank you very much for your time."
Hi I have a metabo hammer drill une 2850 won't start
UHE2850 metabo first look if its the powercable have no phase fracture second is there depending 2 years warranty time on left ?
The switch or only dirt between brush and brushholder inside or an electronic assembly defect or the switch electric field armature . only a slide contact loose sometimes its not hard to find by metabo machines.
Mar 26, 2016 | Metabo Drills
How to do maintenance on metabo sbe710
for maintenance:
after use
1: cleanup with air pressure(inside of motor by motor vent)
weakly
2:clean chuck with brake cleaner and lubricate with metabo grease
at 3 month
3 check motor brush
when motor brush are worn,check ball bearing on armature,extended motor cleanup,gearbox check and grease change if it is dirty,
Oct 10, 2012 | Metabo Sbe710 1/2-in 0-1,000 / 0-3,100 Rpm...
Drill does not work when i press the trigger
Did you take a look at the carbon brushes?. Metabo has what they call Auto stop Carbon brushes. so if they are worn down they will pop away from the motor and the drill will simply not run. this happens when the brushes are basically worn out.
Mar 16, 2012 | Metabo SBE1010PlusC 1/2" 0 900/0 2,600 Rpm...
Metabo SBE 750 Have continuity through the trigger
IF you have continuity through the switch and the brushes look good then remove on brush and look at the commutator segments. There should be nice even gaps between each segment. If you have on that a goodbit wider than the others then your rotor is bad. If not then more than likley your stator is bad.
Aug 06, 2011 | Metabo Drills
It will not work with my power inverter in my truck, but it works when used on a regular 120v outlet. My power saw and my HILTI Drill work but the METABO UHE 28 Multi just will not work at all??? WHY ???
The inverter isn't putting up enough power to drive the metabo. You may be able to give it a "running start" by rotating the blade along a board while pulling the trigger. This isn't a good practice, however, as the board or the saw could slip, so be doubly careful if you try something like this. Your best choice would be to get a bigger inverter.
Best regards, (and be careful), --W/D--
Feb 06, 2011 | Rotary Hammer Drill Metabo Uhe 28 Multi...
Only full power for full trigger pull
I had same issue with Metabo hammer drill. It was faulty triggrer. Replace it and it shoul be fine.
Juraj
Jun 04, 2010 | Dewalt DW056 18 Volt Cordless Impact...
Metabo SBE750 hammer drill trigger sensitivity
The only possible sollution for this failure in this particular tool is to replace the switch. There are no additional electronics that could cause this.
Jan 14, 2010 | Metabo SBE560 1/2" 0 2,800 Rpm 4.5 Amp...
Hi, i hqave METABO 523 hammer drill that the
You're welcome to ship the unit to me for repair.
Contact me at info@taeckertindustries.com for more information
Nov 05, 2009 | Metabo Air Tools & Compressors
Drill and grinder only work upside down
The only time I have encountered this problem is when the field coil is loose in the motor housing, or one or more of the leads has come loose. By tipping the unit back the coil slides to the rear and makes contact. Then contact breaks when the tool in tipped forward.
Apr 28, 2009 | Metabo 600242420 BHE22 7/8" SDS-plus...
Drill quit working
what you are missing is a dewalt hammer drill.
Apr 25, 2009 | Rotary Ryobi 1/2" Hammer Drill ZRD551HK
Drills Logo
75 people viewed this question
Top Metabo Drills Experts
Colin Stickland
Colin Stickland
Dennis Key
Dennis Key
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Metabo Drill Expert? Answer questions, earn points and help others
