Question about Eagle Fishelite 502c Igps Fish Finder Combo
My eagle 502c wont turn on any more but has power to the plug
2 Suggested Answers
SOURCE: The screen on Eagle 502c turns on then immediately
Scott, mine does the same thing must be a flaw. I will let you know if i fix it
Posted on Sep 12, 2010
1995 eagle summit 2.4 fuel gas Put new spark plugs new distributor cap swap fuel pump Still won't start Can u tell me is a 14 valve car is it 1.8 or 2.4? Check all fuses all relays are good check power...
Most likely its the spark coil inside the distributor, under the rotor.Its a replaceable part. If your engine says 12valve on the rocker cover, and it a sedan, its most likely a 1.4L. If you have a Summit wagon, its a 1.8L.
Aug 25, 2017 | Eagle Cars & Trucks
Lot of interference with unit transducer mounted on trolling motor when trolling motor is being used. Then clears up when not used.
Some how you have Radio Interference conflicting with your unit. The RF as it is called, may be coming from the engine. Try to connect to an INDEPENDENT power supply for the Eagle and not the same source your trolling motor. You seem to be getting line interference.
Feb 02, 2015 | Eagle Fishelite 502c Igps Fish Finder...
1991 eagle talon wont rev past 2500rpm
May not be getting enough fuel to the engine
Mar 16, 2013 | 1991 Eagle Talon
Car will turn over but wont get fire to anything
If you mean it does not get spark to the plugs, you would check for power and a ground signal at the coil. No power could be a faulty ASD relay.
Jan 14, 2013 | 1996 Eagle Vision
I've 1995 eagle talon esi non turbo 2.0 dohe I was driveing it and it stooped running it will turn over but won't start what can Ido
check the timming belt. it sounds like you have broken the timming belt remove the belt cover and make sure that the camshafts are turning when you are cranking the engine, if the belt has broken you will most likly have to remove the cylinder head and replace all the valves, when this engine brakes the timming belt the valves will hit the top of the pistons and bend the valves...good luck
Dec 30, 2011 | 1995 Eagle Talon
The Eagle 640c will not show the second Menu any ideas
try whats called a "soft start reboot"it worked for same prob on my one. with unit turned off hold down pages and power keys until it starts up and map of usa appears,release keys. you wont lose any waypoints or data but youll have to reset units of measure etc.
Dec 23, 2010 | Eagle Intellimap 640c Marine GPS GPS...
The plug going into the back of my Eagle 350c got hot and partially melted. It still works now but for how long I don't know. Can I splice a new plug in or do I have to buy a whole new transducer?
Well, if it is still working ok now with the partially melted plug, then the transducer itself sounds like it is fine... Attach a new plug and it should all work the same (just with a nice new plug).
Also make sure your power supply to the Fish Finder is properly fused.
Feb 07, 2010 | Eagle Fishelite 502c Igps Fish Finder...
Machine does not acquire its GPS position. If it does it can take up to 45 mins to achive. Can I put an external antenna on it? The unit is used in an open boat, so has clear access to the sky, so should...
your antenna is probably original and obsolete see if you have a RayStar 120, if so, it is junk. The RayStar 125 is plug and play for you and sells around 300. Your GPS is a self contained receiver, that means it uses 12 V and output computer language. If you have no power to the seatalk antenna, you get nothing. If it is intermittent as you describe, 90% chanace it is the antenna, (mushroom or puck). 847-746-0100
Dec 28, 2009 | Eagle Seacharter 502c Df Igps T/M, Hst...
Eagle Fishelite 502c Igps Fish Finder Combo Logo
60 people viewed this question
Top Eagle Boating Experts
Steve
Steve
ray gallant
Phil Walker
Phil Walker
Are you an Eagle Boating Expert? Answer questions, earn points and help others
