Not picking paper for printing - Out of paper error
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 145 Answers
The wheels might have mis-placed or a small piece of paper may be stucked with in it better check it.
If this solution helpful/useful for you please rate mysolution. THANKS FOR USING FIXYA.
Posted on May 17, 2011
When i try to print it takes shows error, what do ido?
That suggests that the problem was not with the feeder or shaft, but with a sensor.
Can you check the sensors, or cal a service agent?
May 26, 2016 | HP LaserJet P2015 Printer
Paper jam error
This error apear usaly on this machine , when the cloutch sistem of paper feed roller are obsolete , to fix this issue you must clean the sponge out the clutch or replace-it becouse this is already sticky
Feb 02, 2014 | Kyocera Mita FS 1010 Laser Printer
Getting a constant "Paper Jam 071-100" error when printing from Tray 1 (no jam found).
You need to replace the paper pick up, feed rollers and separation sub-assebly.
Nov 27, 2012 | Dell 3115CN
Printer does not attempt to pick up paper but gives out of paper message and or flashing paper sign on panel
steps:
(a) driving a pickup roller, picking up printing paper stacked in a paper cassette, and then, feeding the picked up printing paper to an image forming unit
(b) after picking up the printing paper in step (a), checking to determine whether or not the printing paper has been fed to the image forming unit(c) when it has been determined in step (b) that the printing paper has not been fed and a paper feed error has been generated, again driving the pickup roller, so as to attempt to pick up the printing paper stacked in the paper cassette again.
Apr 21, 2010 | HP Officejet Pro K5400 All-In-One InkJet...
What is message: 41.3 paper error ?
Hi there
41.3 on a lj 4+ is a paper Feed related error normally caused by dirty or worn paper feed tyres if you are getting this error whilst feeding from the paper tray at the bottom of the printer stack a few sheets on the manual feed tray on the front if you dont get the error
clean all your feed wheels or order a service kit and replacement replacement tyres
Regards AL "alstech"
Jun 07, 2009 | HP LaserJet 4 plus Printer
Re HP Laserjet 4P after inserting envelope to print, upon giving PRINT command, printer will not print and indicates PAPER JAM. However, there is no real paper jam. No problem printing regular 8 1/2 x 11...
Most likely a bad pick up roller these machines will give a jam error if the paper or envelope is not picked up. Try cleaning the roll for the tray you are having the trouble with if the condition improves you have found the problem.
Hope this helps
Apr 19, 2009 | HP LaserJet 4 plus Printer
Printer busy or error
So are you saying that the printer looks like it's about to print but then gives you a red error light? If so I think I had the same problem. It is to do with a faulty part (very cheap). The part is a kind of roller that picks up the paper. In some CLP-300s the rollers surface is too coarse, thus not picking up enough paper.
I had a service department change it for me, did it in 5 mins.
Hope this helps.
Jul 25, 2008 | Samsung CLP 300 Laser Printer
OPTRA T610 NOT PRINTING FROM TRAY1
What happens is that the rubber roller that's supposed to pick paper up and load it in doesn't pull the paper from the tray anymore, hence it gives the paper jam error message. If you want you can replace that rubber roller to fix the problem, however first thing I do is to take that rubber roller out (remove tray and look underneath to find the roller) and turn it inside out then fit it back. This will give the rubber roller the grip that it missed and solve your problem.
Jul 13, 2008 | Lexmark Optra T610 Laser Printer
Problem with hp psc 1410
My printer will scan and print , but it wont print from the computer, I need to activate it but I lost my disk.
Jan 17, 2008 | HP PSC 1410 All-In-One InkJet Printer
Paper Feed Problem
This is caused by the solenoid that is activated when picking up the paper. The solenoid is activated and the device goes through the motions of picking up the paper. It fails to pick up the paper or fully feed it past the leading edge sensor resulting in a jam error. You should replace the pick up solenoid assy and also the pick up roller and friction pads.
Jun 27, 2007 | Konica Minolta magicolor 2300DL Laser...
19 people viewed this question
jasbo
jasbo
