Question about JVC GR-D370 Mini DV Digital Camcorder
Can not remove tape
I can not remove manually the tape from jvc dv camera . the unit has no power on DC or AC at all. there was a tape inside the camera that was very important but i can not get it out manually coz it has no power. help please.
I have the same problem but i have power in my camera and the tape is sticking in camera!
HELP US!!!
Posted on Sep 23, 2008
I have the same problem...anyone out there?
Posted on Aug 23, 2008
No power cord how to remove mini dv-tape jvc dvl720u
Use manual to see power requirements, get another battery or a p/s from one of your electronic repair locations.http://camera.manualsonline.com/manuals/mfg/jvc/jvc_gr_grd70u.html
Mar 18, 2013 | JVC Video Cameras
Condensation
Camera has a sensor inside to detect condensation
Condensation can occur if the camera is moved from a cold environment to a warm one.
So open the tape compartment, remove the tape to allow maximum airflow and wait for the camera to warm up
Regarding Condensation please wait
This message comes when your camera hasn't experienced a sudden change of temperature, this could indicate a possible fault.
Thanks for using Fixya
SAM ANDERSON
Sep 22, 2008 | JVC GR-D50 Mini DV Digital Camcorder
Camcorder broken , How to remove tape?
Hey,
I have the same problem and I found this fix in a service manual. It worked, but my tape motor adjustment is off. So be carefull.
The 3v dc is easy to make, connect 2 batteries 1.5v in serial, you get 3V dc.
Let me know how it goed.
Jan 23, 2012 | JVC GR-D350 Mini DV Digital Camcorder
It reads unit is in safeguard mode Eject and reinsert tape I need to see a manual of the inside of the tape housing unit because I found a black rubber wheel that I think needs to be put back in
Remove the battery while the camera is at the "on" position then put it back. Press the forward or rewind button then stop. This should solve your problem. It works for ither JVC owners. Are you try with other new tape?
Turn's out that JVC Does that to protect your camcorder some do it some don't because there might not be a problem and JVC will pay a tech to unlock this mode under waranty and you can get extended waranty by calling satis fusion at 1-888-269-6432 even your item is out of waranty.
Hop helps.
Jun 15, 2011 | JVC GR-D94 Mini DV Digital Camcorder
I HAVE A JVC GR-D820EK MINI DV VIDEO CAMERA AND IT IS DISPLAYING UNIT IN SAFEGUARD MODE 06, I HAVE TRIED REMOVING BATTERY AND DC PLUG BUT NOTHING HAPPENS IT WILL NOT WORK ON EITHER PLAY OR RECORD, PLEASE...
i HAVE A JVC GR-D820EK MINI DV AND IT IS DISPLAYING UNIT IN SAFEGUARD MODE 06, I HAVE TRIED REMOVING BATTERY AND DC PLUG BUT NOTHING HAPPENS IT WILL NOT WORK ON EITHER PLAY OR RECORD, PLEASE COULD YOU ADVISE
Feb 11, 2011 | JVC GR-D775, GR-D790, GR-D796, GR-D820EK,...
Tape loading mechanism jammed
Hi...Tape jam inside your Camcorder ...fi you look careful on the side of the door tray look for a little hole it release manually the door but carefully remove the tape.. it possible the tape is unroll around the mecanism see if you cant release the pinch roller inside it a little black roiling rubber,it holding the ribbon tape
Oct 18, 2010 | Sony HVR-Z1 Mini DV Digital Camcorder
I have 3 of these cameras. One is DOA. No power
This is a professional machine. No power? check the breaker at the bottom rear side, this is accessible you can even see its marking. Could be the breaker if not, there are fuses inside sometimes protects for some reason. This machine has two DC DC regulators one found at the rear side(near battery compartment, hard to access) and another one easy to access below the handle near center(PS BOARD), needs only four screws to open. Mostly PS board damage if no power symptoms shows with all fuses OK. Good Luck
Mar 12, 2010 | JVC -GY-DV500 w/lens, VF, Fuji 14x1:...
Tape jammed in jvc camcorder
The way I can get a tape unjammed on my Sony camera is to remove the battery, plug the camera into the AC charger that is plugged into the wall outlet. Then power the camera on, wait a few seconds. Then unplug the charger from the outlet, wait a few more seconds (camera still in "on" position) and then plug it back in. I have used this method at least 3 times to get the camera to release the tape.
Sep 08, 2009 | JVC GR-D250 Mini DV Digital Camcorder
Removed mini dv tape, reinstalled mini dv tape... cassette wont close, all power lost!
internal power supply fault, unit needs to be checked by a panasonic technician.
Jun 13, 2008 | Panasonic Palmcorder PV-DV53 Mini DV...
Removing dv cassettes manually
open the unit and look for a small motor that ejects the tape through a series of mechanical gears, slides and hinges. Now turn this motor by hand.
Jun 06, 2007 | JVC GR-D270 Mini DV Digital Camcorder
JVC GR-D370 Mini DV Digital Camcorder Logo
115 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
