Question about Novation Xiosynth 25 Midi Controller Keyboard Brand New
I see that something is registering when i hit the keys. when i record i can see the notes on the timeline so it did record, but i get no volume during recording or playback
  • Novation Master
  • 5,603 Answers
Check that you have appropriate devices set in "sounds and devices" in the control panel of the PC and that they are not muted.
Posted on May 17, 2011
Some notes on keyboard leave a horrible piercing static noise when volume is turned three quarters up.
Sounds like feedback from your monitors, the speakers can't be pointing in the direction of the mic.
Sep 09, 2017 | Yamaha Piaggero NP11 61 Key Digital Piano
While using korg m50 editor using usb data cable there is no sound from my lap.the sound is only from my head phone connected to my keyboard directly?
Are you connecting to the laptop and using it as a midi controller? You can record midi notes from the keyboard and send them to your laptop via USB using any midi sequencer program (reason, logic, etc). Create a midi track, select the input of that track as your keyboard, then hit record to play some midi notes. To hear what you record, you have to set the output of the midi track to whatever midi sounds or instrunents you have installed on your laptop.
If you are trying to record the actual audio sound the keyboard makes, use an audio program such as cubase, sonar, audacity, pro-tools, and either mic the keyboard, or connect one of the other audio outputs (1/4" TRS) to an audio input on your DAW, and record an audio track that way (as opposed to a midi track).
Apr 13, 2012 | Korg M50 61-Key Music Workstation Keyboard...
Hi Folks - I have a Roland Fantom G6 that produces no sound! Everything else seems to be fine - the display registers that I am hitting the keys & even the skip-back sampling feature produces a wav...
This probably is not a DIY repair... The audio comes out of the CODEC and is buffered by Op Amp used as filters and then goes through the volume controls, After that it goes to the jack board with buffer OP amps. First thoughts might be a damaged volume control, however, the "B" outputs don't go through volume controls...
About the only thing I would think you could do is to CAREFULLY open the unit and look for a loose cable involved with sending the audio to the volume control panel and then the cable that takes the audio to the jack board...
More than that you would probably need to take it to a shop equiped to troubleshoot.
Nov 23, 2010 | Roland FANTOMG8
How can i play BUP 06PK61 frm yamaha I425 on PC
how can i play .bup file in computer?
ok here is the solution!!!!!!!!
    • we should have a mic pin and audio cable as shown in this pic
    connect these cables,and connect big pin to the piano and small pin to the computer (mic or input jack)
    now take windows movie maker (start-all programs-windows movie maker). click on narrate timeline (as a mic icon below windows movie maker).
    now click start narration on the pc and play your song on the piano. you can see input level highlights. now your song is recording. when your song completes click stop narration and save to the pc. walah if you can't understand this say to me. i can add video. sry for my worst english
Jan 13, 2010 | Yamaha YPT400 61 Key Portable Keyboard...
Thomas jester 132 organ troubleshooting E-flat below mid c not working correctly on either keyboard or foot pedal all other keys ok volume pedal is scratchy but works ok
Here is where you can get the service manual:http://celedoniaorgan.netfirms.com/cosco/nfoscomm/catalog/product_info.php?products_id=1021&osCsid=3eaaa99d6bfceeaaf9b844687ba58d55 Since the problem is with the foot pedal note and the keyboard note I would suspect that there is a problem with the tone generation circuit for that note. You might try cleaning the key contacts on both for that note first to see if that works. The volume pedal probably just needs the volume pot cleaned with contact cleaner spray. I hope this helps. Let me know if it does.
Nov 26, 2009 | Music
BR-1180 Cd will not burn CD's does it call for
Don't know if this unit is sensitive to the type of CD, but my Phillips recorders will ONLY burn the "Music CD's" (harder to find, more expensive). Read up on the difference of regular vs Music CD's. ALSO some recorders will not burn disks rated at lower or higher rates.
Oct 10, 2009 | Boss Micro BR Digital Recorder
Yamaha 88 key piano grand plays wrong pitches w/ changing volume
If it has a sequencer/ recorder built in, you have the ability to change the pitch/ detune by using some key strokes after initiating the program mode. If your not sure how to do that, try unplugging the keyboard for thirty seconds and push the power button while it's unplugged, then plug it back in. Any better? What model is it.
Jan 01, 2018 | Yamaha Full-Size Keyboard
"Card Full" error when the card is in fact empty...
I had the same issue, and ended up solving it after trying many different things. So first you put the card in your reader, right click, and hit "format...". It should ask you if it's ok to erase everything. Say yes.
Then put the card in the recorder, and it should say "Unformatted". Hit Utility and TR4 to Initialize. That should do the trick. Hope that helps!
Aug 27, 2008 | Boss Micro BR Digital Recorder
Novation Xiosynth 25 Midi Controller Keyboard Brand New Logo
66 people viewed this question
Top Novation Music Experts
Michial Gueffroy
Are you a Novation Music Expert? Answer questions, earn points and help others
