Where can I get a schematic for the motherboard and/or powersupply
  • john_mcdonou May 17, 2011
    I have an Icebox TV flip screen V2.0. It is made by Salton or Westingouse. It might also be called the Beyond. I have a constant amber light and hum in the speakers but no screen lights up and the faceplate on/off switch does not work. It will not boot up.
    John
  • 760 Answers
I will be more than glad to assist you with your request, however I need to know the make and model of your Television. Please provide me with the info. Thank you.
Posted on May 17, 2011
  • David Duncan
    David Duncan May 17, 2011
    It appears that this set was designed for factory repair only. The is no service literature or parts information available.
Every time i plug the p4 wire in to the motherboard power stop
There is a short somewhere, either with your motherboard or your powersupply. Test your powersupply to another motherboard that has the 4pin 12volt adapter if you have one. Most likely your motherboard is trying to prevent circuit overload to the cpu.
Jan 15, 2011 | Biostar NF61S MICRO AM2 SE...
Not getting switching on.
Make sure that all the power cables required are connected properly to the motherboard, test the powersupply on another motherboard for example or use a powersupply tester.
Check that the power switch is connected on the right pins on the motherboard and that the switch works.
The motherboard should turn on - spin fans even if there is no memory, cpu or video card installed. So something is not connected properly, or either the powersupply or the motherboard is faulty.
Sep 20, 2010 | Intel Motherboard
Green led lights up on motherboard no fans or anything will start
It means there is a flea power on the motherboard, but i suspect the powersupply is faulty since the fans is not working. Try to check the power button led light if it is "amber" if yes, Powersupply needs to be replaced.
Hope this helps.
Feb 19, 2010 | Compaq (253219-002) Motherboard
Errore codeoxe0000227
1. Full power down. Unplug the power cord from the Power supply. Then hold down the pc power button.
Try to boot the pc.
2. Open the case and reseat the graphics card, hard drive, and RAM.
3. Take out one of the RAM sticks if there is 2 or more. Swap the RAM sticks in different RAM slots.
4. Set the Cmos jumper to clear. Power up the pc. Power down the PC. Set the Cmos jumper back to normal position, power up the PC.
5. Unplug and replug all the power supply cables.
6. Check the powersupply function. Either by a powersupply voltage checker, put the powersupply in a different pc, or try a different powersupply in the problem computer.
Could be bad ram, motherboard, cpu, powersupply, videocard.
Jul 06, 2009 | ASUS P5P800-MX Motherboard
Mother board Issue
U CAN BUY IT IN ANY COMPUTER HARDWARE STORE NEAR YOU.JUST MAKE SURE U BUY THE EXACT POWERSUPPLY COMPATIABLE WITH YOUR MOTHERBOARD.
Apr 02, 2009 | Intel Motherboard
Battery replacement
hi there;
hey try to unplug the power cord from the powersupply now open the case and unplug the powersupply to the the motherboard and then press the reset button on the front for 15 seconds and than connect the motherboard powercable and plug in the powercord back in to the powersupply and try to restart the computer. please tell me if this works and ANY thing that happnes ok best regards mike
Jan 28, 2009 | EliteGroup P4VMM2 Motherboard
No power for Compaq desktop after moving to another room
Try pushing it back in, making sure that it clips into place. You might have shorted out your motherboard though when you moved the pc into the other room. Are you getting power to the powersupply, ie - can you hear or see the powersupply fan spinning? If the power supply is not going on, you may just need a nore powersupply. I hope that helps.
Dec 07, 2008 | Compaq Computers & Internet
Motherboard
ya definetely....i will help u out in solving the problem.
first of all open the side cover of the cabinet.....here i am first instructing you how to check the power supply in the system..
as soon as you open the side cover of the cabinet the remove all the wires coming to the motherboard from the powersupply.then there u can see a 20 pin connector coming to the motherboard from the powersupply.in that bunch of 20 wires shot the green colour wire and the black colour wire...and give the power to the powersupply. if its ok and the fan of the powersupply is working then the smps is ok other wise u need to get it repaired by giving it for chiplevel servicing.....
if powersupply is ok then check whether there are any burns on motherboard if so and even if not u need to give the motherboard for chiplevel servicing.....
Dec 29, 2007 | Dell Dimension 4600 PC Desktop
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
