Question about Procom ML060HPA Heater
Pilot will not light, seems to not be getting any propane to it. The regulator on my propane tank works fine. What could be the cause?
    Genius:
  • 1,015 Answers
I would trace gas line out and determine were you are getting gas and where it is not. With the gas on I would carefully loosen union or flex fitting going to gas valve.If you have gas there then retighten union and go to fitting on pilot line and check it.You should be able to get gas there by depressing pilot light button.If you have gas there then go to pilot assembly and remove it from gas valve and burner. Remove pilot orifice and carefully clean and blow thru pilot line to make sure it is not obstructed.
If you cannot get any gas thru gas valve then shut off gas before valve and remove inlet line. There should be a fine mesh steel screen there. Make sure it is clean.If you are getting gas to gas valve but not thru it then you probably need to replace gas valve. Thank you
Posted on May 17, 2011
Desa heater
For (fire) safety, there is usually a thermostat that will turn off the gas if pilot light goes out.
So when you try to light the pilot you will have keep press & hold the pilot gas supply for at least 10 sec until the thermostat is heated up. Then only when the pilot light stays on continually, can you turn on the burner.
Forget about changing to a High pressure regulator!
Dec 24, 2013 | Heating & Cooling
Emberglow ventless gas logs (set to burn on porpane gas). Pilot lights, but not logs.
It needs 14'' wc to work , hose could be too small for load .
Dec 06, 2012 | Heating & Cooling
Pilot light too big, how do we adjust pilot light on a Vanguard KV1800?
There is no adjustment for a Pilot Flame's Length on a Vent-free Gas Appliance. However, if you're using Natural Gas and it's a Natural Gas Heater, the normal length of the pilot flame is 2 to 2 1/2".
If it's a Propane Gas Heater and the pilot flame is as long as previously stated, you probably have a pressure problem from your tank. Contact your Propane provider to have them check the pressure on their tank regulator.
Jan 31, 2011 | Vanguard Heating & Cooling
My refilled 60 # propane tank leaked and then stopped flowing.
Rick, if the tank is normally plumbed for a horizontal position, and you have it standing vertically, then you are feeding liquid propane to your pilot light, hence the frosted hose etc., and a tendency for the pilot light to go out as it has too rich of a fuel to burn. There should be no vent to allow air in as propane is pressurized, and only attains zero pressure at 40 below zero farenheit. The valve you speak of should have been the liquid vent valve which is used during filling only, and is closed during any other use. Your supply valve should be in the wide open position. The pressure relief valve is only operational when the tank has been overfilled or overheated. You should have a pressure regulator between the tank and the appliance you are trying operate. Hope this helped. Marvin
Jan 04, 2010 | Bosch AquaStar 125FXKIT-LP 125FX Liquid...
I'm getting spark but no ignition on my Endless Summer patio heater. It's an older model. Any suggestions?
I am guessing that this is a propane model. If so, when it is sparking, can you hear any propane flowing at the pilot. It will sound like a light hiss. If not, either the pilot is plugged, caused my many reasons, or the regulator on the propane hose is stuck. If you are able to access the pilot assemble, you can take a small wire, or even a sewing needle to clear the orifice. If that does not help, you may need to replace the regulator or the connection for the tank.
Sep 10, 2009 | Heating & Cooling
Pilot light will not light in the first place
Thermocouple only has an effect after the pilot is lit to keep it lit. either the pilot supply line is clogged the valve is bad or the regulator is failed shut. Try moving the regulator to your gass grill or vice versa to eliminate the regulator. Blow out the pilot tube with compressed air. If these dont work it's the valve.
Aug 08, 2009 | Stainless Garden Sun Steel Propane Patio...
Can't get propane heater to lite
Not enough information to solve the problem correctly but I'll take a guess at it......
This heater requires a 100lb propane tank (approx. 25gal) with 1/2" or larger piping to deliver the correct volume of gas to the heater. If you are using a smaller tank (like a 10gal) or the piping is not the correct size you will not get enough gas to the heater to light the pilot. Also you should have a regulator set at 11" to 14" of water column installed between the tank and the heater. If the tank is connected directly to the heater you may have damaged the internal regulator in the heater.
Jan 02, 2009 | Procom ML300TBA Heater
Pilot light keeps going out
Dan, Since you just had the tank filled and the heatewr installed a tinty piece of trash could have entered the pilot orfice. Un do the lower floor panel take off the pilot assy. Blow out the small pilot orfice. Blow reverse from normal gas flow to unlodge the debre. Re asemble and light.
If this dosen't work It may be the pilot air intake is too open causing the pilot to blow itself out.If thats the case close off the air adjustment some. It will be located behind where the flame exits the pilot orfice.
ljtomega
Nov 21, 2008 | Rinnai Unvented Gas Zone Heater. 99% fuel...
Empire corcho ventless propane wall heater 15000 btu
LOL.... your fuel is not boiling.... the closer propane gets to its vaporization point (-44%F) the less vapor it produces. clean the snow off of the 100# or lay it on its side to give it more surface area for vaporization.
David Lawrence the propane dude
Oct 04, 2008 | Reddy Heater RLP100 Portable Forced Air...
Procom ML060HPA Heater Logo
243 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
