Question about Frigidaire 27" Built-In Double Electric Wall Oven - White
Ovens will not heat or broil. Where are fuses located in Gallery Pro Frigidaire series?
  • Patricia Mervine May 17, 2011
    These are built in wall ovens - no burners associated with this unit. Controls are push button. Both upper and lower oven lights up, says it is heating after you set temp. then after a minute, shuts off. This happens for both units, for bake or broil. Heating element does begin to heat before units shuts down. Clock is accurate - so it has power. I saw someone mentioned fuses on the chat page, but don't know where they are.
    These ovens are wall units - no burners associated with them. The clock is working; the oven light comes on so it has power. All switches at touch conrol. When you hit bake, set the time, and then start, pre-bake lights up with the current temperature, and then it shuts down. Someone previously mentioned a fuse, but I see nothing about fuse location in my booklet. Any ideas?
  • Frigidaire Master
  • 1,902 Answers
Hello & Welcome to FixYa
This indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Posted on May 17, 2011
    Genius:
  • 1,196 Answers
If neither the oven heat nor the broiler heating elements heat, but the range burners still work, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for manual", push the knob in and try the baking and broiling elements again. If it still does not operate properly, you probably have a defect in the thermostat, selector switch, or common wiring.
If the oven does not have a separate bake/broil/etc. selector switch, the problem may be with the thermostat. If you are not comfortable working on electrical appliances, it is better you get someone who can because it's not easy to check the selector switch or thermostat for proper operation if you are not a good technician.
  • Ishola Olayemi May 17, 2011
    Since there is power to the oven, this not fuse problem, the problem is with either the thermostat, selector
    switch.
Wall oven needs a reset- wont heat
Hello John, thank you for allowing me to assist you!
I understand your wall-oven is no longer heating. The wall-oven has a safety thermal to prevent the oven from overheating. If the unit will not bake or broil, more than likely the safety thermal has tripped. Other possibilities are incorrect power supply or faulty main control board. I am fairly confident that an authorized service agent will be able to restore your appliance to its normal operating condition. You can often locate a qualified service technician on the manufacturer website.
Best regards!
Oct 27, 2013 | Frigidaire 30 in. Electric Gallery Series...
Why has both top elements stop working at the same time
Hello kimberlymaso - If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works; contact a professional to diagnose the EOC (electronic oven control).
Sep 25, 2012 | Frigidaire 30 in. Electric Gallery Series...
I JUST WANT TO REMOVE THE OVEN DOOR TO CLEAN THE INTERIOR SURFACE OF THE DOOR GLASS
If you mean between the inner and outer panes of glass; you will regret it. It's likely that both are mounted with a fragile heat-proof mineral (non-asbestos) gasket material that may crumble once the panes expose it.
Apr 22, 2011 | Frigidaire 30 in. Electric Gallery Pro...
My 30" wall oven oven won't heat up. the clock works and it allows me to put in bake, 350 degrees, but the elements don't heat up. we had a storm and the power flickered on and off several times. is there...
There is a safety thermostat (thermal fuse) on the back wall of the oven that interrupts power from L1 to the Bake and Broil elements. This fails open on an over-temperature or over-current condition. The oven needs to come out of the wall to replace it - best left to a tech unless you are experienced in such things.
Best Regards,
Bruce
www.fixyourboard.com
Jun 21, 2010 | Frigidaire 30 in. Electric Gallery Series...
The oven wont heat up.
Hi.
Since the oven has two heating elements, if the oven does not heat up on any condition, and both broiling and baking element are not working, then the most common fault causing the problem is a faulty temperature probe.
The temperature probe is located inside the oven cavity.
On most ovens there is only one temperature sensor, connected in line on the circuit from electronic oven control to baking and broiling element.
When the probe fails, it will affect both baking and broiling function.
The temperature probe is tested reaching the probe, cutting or disconnecting its wiring, and testing the probe at room temperature, with a multimeter set on impedance at Rx1. If the multimeter reads no continuity (circuit open), then the probe must be replaced.
If the temperature probe is good, then parts that may be responsible for the fault are oven electronic control and wiring. Having both elements failing at the same time would be rather unusual.
If only one element is failing, then the fault is probably the element. In that case you can test the element removing it from the cavity, and testing Ohms on the element. If circuit is open , then the element must be replaced.
Regards.
Mar 03, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire 27" Built-In Double Electric Wall Oven - White Logo
96 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
